Old 06-16-2011, 03:45 PM   #91
yellowbronco
yellowbronco's Avatar
Oddometer: 209
Uraberg,
Double check the year of your engine. It appears to have the newer SEM stator with the flywheel on the inside and the stator in the cover. If I'm not mistaken, that should make it a '98 or '99. I don't remember when they went to the hydraulic clutch but your's appears to be cable except for the Rekluse.
I like the newer plastic on the older frame. I had seen it done once before but it was a little ghetto because the guy chrome plated the frame. I was told that it was a lot of work to move mounts and cover up the second air filter hole on the left side.
Looks great!
Hmm...
I just had a thought as far as fuel capacity goes. The original Husabergs throughout the 90's had a small vacuum actuated fuel pump to deliver fuel to the carb when the level of the fuel was lower than the floats. This was necessary because the fuel tank was almost completely on the right side of the bike and the second air filter was on the left. That meant that the fuel tank, in order to get a decent fuel capacity, dropped almost all the way down to the engine case. Well, that fuel pump could be used in a custom setup with low fuel tanks like what the typical Dakar bikes use.
Now to get to work on the fuel tanks...
08 KTM 320 SXF, '07 Beta Rev 3,
Frankenberg 501, '96 Husaberg FC600, '68 Yamaha DT1, '74 Bultaco Alpina 250, '84 Husqvarna WR400 - My Dad says I've never seen a motorcycle I didn't want to own...
yellowbronco is offline   Reply With Quote
Old 06-17-2011, 06:20 AM   #92
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 692
I forgot to say that that is not the original stator cover ;). The plastic cap that came with it was very warped, and let in all kinds of water and dirt...
I have yet to figure out how to do the airfilter properly...
Originally Posted by yellowbronco View Post
Uraberg,
Looks great!
Hmm...
uraberg is offline   Reply With Quote
Old 06-17-2011, 10:26 AM   #93
Idle
Oddometer: 719
Heres mine, 05 fs550e ive had it three weeks now. Ive already looked in to a dirt setup, kinda spendy, but cheaper than buying another bike i guess.
Idle is offline   Reply With Quote
Old 06-27-2011, 08:23 PM   #94
spencergt66
Oddometer: 792
my collection
Im new here been reading a lot of the posts of the riding trips good group on here lots of activity
Heres some pics of my collection
the one in pieces is my 470FX it needs alittle help
[IMG]
From FX 650 E
[/IMG]
My 03 650 got it cheep and was already plated
[IMG]
From FX 650 E
[/IMG]
the 650 came with an auto clutch that I didnt care for took it off still have it though If anyone is interested I would be willing to let it go
spencergt66 is offline   Reply With Quote
Old 06-28-2011, 04:54 AM   #95
tomatoe333
tomatoe333's Avatar
Oddometer: 2,293
If it'll fit my 08 FE450, I'd be interested.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 06-28-2011, 05:24 AM   #96
spencergt66
Oddometer: 792
That im not sure I put a complete clutch basket and all off an 05 550 in mine to replace the auto clutch
Old 06-28-2011, 07:12 AM   #97
tomatoe333
tomatoe333's Avatar
Oddometer: 2,293
If it's a Rekluse, it'll work. I'll send a PM.
Old 06-28-2011, 08:40 AM   #98
spencergt66
Oddometer: 792
If you can use a outter clutch hub off a 550/650 it should work
Old 06-28-2011, 01:46 PM   #99
wallache
wallache's Avatar
Oddometer: 378
I had the day off of work yesterday, spent it riding and playing with my new camera.
wallache is offline   Reply With Quote
Old 07-03-2011, 10:48 AM   #100
spencergt66
Oddometer: 792
Clutch
I was told that the revloc clutch should fit a 450-650 berg Just hate to have it sitting taking up space
Old 07-05-2011, 01:25 PM   #101
Idle
Oddometer: 719
I need a 06+ up taillight, I don't suppose anyone has one, or knows of an aftermarket led one that will work?
I try not to look at mine for more than a second, it's obscene...
Old 07-05-2011, 01:36 PM   #102
spencergt66
Oddometer: 792
I think the OE one is only 40 bucks I looked at that option as well cause yes the tractor / trailer light on the back is quite ugly
Old 07-05-2011, 01:44 PM   #103
spencergt66
Oddometer: 792
Never mind its the same POS thats why I never ordered it
Old 07-05-2011, 07:12 PM   #104
Huskyfatman
Huskyfatman's Avatar
Oddometer: 1,398
I swapped a newer one onto my '05, much better. Rick should be able to get you one quick. http://www.offroadboss.com/welcome.htm
http://www.sharetrails.org/
http://www.americansandassociation.org/
"YOU KNOW. . . . . .WE ARE LIVING IN A HEAT LAMP SOCIETY!"-Ron Perez 2002
Huskyfatman is offline   Reply With Quote
Old 07-05-2011, 07:25 PM   #105
spencergt66
Oddometer: 792
Where did you get the Tank I've been looking for an oversize tank for my 650
Times are GMT -7.   It's 04:28 PM.
