Old 12-08-2010, 07:28 AM   #1
rivercreep OP
Oddometer: 3,243
studding tires without a stud gun??????
Is there a way to do this!
I've looked at the screw in studs from Aerostitch = $$$$ OUCH!
Looked at car/truck studs and where the price is right, you need (or at least it appears) a studding gun.
My thought...
take a center punch and drill a hole in it to accomodate a regular stud end and use it and a mallet to hammer the studs into the correctly drilled tread on the knobbies, instead of a pneumatic gun.
Possible?
Anyone ever stud non-screw in studs into a tire WITHOUT a stud gun?
rivercreep is offline   Reply With Quote
Old 12-08-2010, 09:17 AM   #2
Range Motorsport
Junk collector
Range Motorsport's Avatar
Oddometer: 1,652
My thought...
Possible?
Not possible. You have to spread the hole open to fit the stud in. I have studded a few tires in my day and no amount of hammering was going to insert that stud.
2007 KTM Superduke
SNL Will Ferrell Yoga, google it.
www.adventuremine.com
www.upoverland.org
Range Motorsport is offline   Reply With Quote
Old 12-08-2010, 09:21 AM   #3
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Here is how wide the base of the stud is:
Old 12-08-2010, 09:23 AM   #4
ct-ktm
Oddometer: 3,352
There are pleny of good screw in type now...but from what I see you are better off buying them made..
You couldn't get a stud in by hand with a small enough whole to keep the stud in....!
ct-ktm is offline   Reply With Quote
Old 12-08-2010, 09:25 AM   #5
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,331
I've never studded tires (they are illegal in Illinois) but I understand that you need a pneumatic gun to fully seat them because of the shock the gun gives helps the stud set up fully in the rubber tire.
I'd try talking to a local shop to see if they can do it with their gun, or let you borrow/rent their gun. I suppose the other cheap way would be to make/modify a punch for an air hammer and try that.
GreaseMonkey is offline   Reply With Quote
Old 12-08-2010, 10:40 AM   #6
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,722
Nonwithstanding the impossibility of doing that with a hammer, I have to add the drilling part......You need a very high speed drill to do so, the one we had ran at about 20,000 RPM , anything less will just tear uneven holes into the rubber. But a Dremel should work.
In my early days as a grease monkey they were just starting with the studded tires, so most winter tires did not come with holes for the studs, we had to do it ourselves. To this day I'll always remember the annoying noise of that drill, the little burning rubber rockets hitting our hands and......the stench.
Have tools, will travel!
Old 12-08-2010, 10:58 AM   #7
ct-ktm
Oddometer: 3,352
I have never seen a tire come with wholes even now..??...
Old 12-08-2010, 10:59 AM   #8
Worroll
Worroll's Avatar
Oddometer: 782
I've read about people just using sheetmetal screws and screwing them into the knobs.
Worroll is offline   Reply With Quote
Old 12-08-2010, 08:26 PM   #9
Range Motorsport
Junk collector
Oddometer: 1,652
Lots of tires come with holes for studs in them but you have to get a winter or offroad tire to find them.
The gun itself does two things it spreads the hole open with 3 jaws and then jams the stud into that hole with a piston. So the important function that you can't do with any normal tool is spread the hole open.
2007 KTM Superduke
www.upoverland.org
Old 12-09-2010, 04:33 AM   #10
Guy Young
Guy Young's Avatar
Oddometer: 8,528
What the others said about getting them in without the proper tool - impossible.
I studded a set of TKC-80s for my KLR a couple of years ago, drilling the holes with just a standard drill, but clamped a depth gauge on the bit so the depth was correct and consistant. I used a Bruno Wessel gun to insert the studs themselves:
They worked well.... but the table turned somewhat. Icy/snowy roads I had decent traction. Dry roads was akin to riding on ice if the bike was heeled over too far.
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is online now   Reply With Quote
Old 12-09-2010, 05:25 AM   #11
ct-ktm
Oddometer: 3,352
Like which ones.??..I don't think you can get the in the USA.?. I have about 12 studded and spiked tires in my garage..
I was checking them out last night and seeing which ones will get mounted.
rivercreep I didn't notice you were in PA..you can buy the studded tires made for about $150.00 a tire..
Old 12-09-2010, 05:48 AM   #12
Guy Young
Guy Young's Avatar
Oddometer: 8,528
Here's one source
http://www.motorace.com/miva/merchant.mv?Screen=CTGY&Store_Code=M&Category_Code=SWT
Old 12-09-2010, 05:55 AM   #13
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,980
You'll have a helluva time getting any motorcycle tires that come with stud holes already drilled in them, if it's even possible any more. Some tire shops will do the drilling and studding for you, but it's gonna cost some $$. I can stud a set of light truck tires with pre-molded holes in about 15 minutes, but drilling adds an hour or more for each tire, and it sucks to do. Like H96669 said, the smell stays with you for a while afterwards.
Those tires from Motorace would be the hot ticket, but jeez-Louise they're spendy!
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 12-10-2010, 12:33 PM   #14
rivercreep OP
Oddometer: 3,243
Do you have any links to those other good screw in types?
Aerostitch seems pretty pricey to me.
James
Old 12-10-2010, 12:49 PM   #15
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,280
James
i run the 3/8" Kold Kutters for offroad (NOT FOR STREET!). 1 stud per knob and they last a while. multiple studs per knob and it'll shed 'em. ..you could try it on an old knobby first and see if you like them... the worst part is mounting/demounting the tire. wear heavy pants and gloves, they will tear you up.
anyone want me to stud up a tire for them? i can do one on a 1 or 2 race take off shipped to you for around $70.00
current bikes
stainlesscycle is offline   Reply With Quote
Times are GMT -7.   It's 03:13 PM.
