Old 01-24-2011, 06:20 AM   #106
RobertAmsterdam
GS 4 life
RobertAmsterdam's Avatar
Oddometer: 181
Me too
I am very curious how the tyre will perform on (wet) pavement! They certanly have the best looks ever!
If they perform good as a street tyre I will buy these.
2010 F800GS + Deus ex Machina replica
2004 R1200GS RIP
Youtube BMW R1200GS + F800GS videos : http://www.youtube.com/user/RobertMokum/videos
RobertAmsterdam is offline   Reply With Quote
Old 01-24-2011, 07:10 AM   #107
Motorman
Motorman's Avatar
Oddometer: 474
Due to their design, I suspect they might act a bit like the Conti TKCs and be a bit slippery on wet pavement. Anyone else?
"Put On The Armour Of LIGHT"
"Light Up The Darkness"
Motorman is offline   Reply With Quote
Old 01-24-2011, 07:22 AM   #108
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,254
I will assume they will behave similar to the TKC80 on wet pavement.
which means that after about 500 miles on the tires, you can no longer use your rear brake without locking the rear tire.
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Old 01-24-2011, 08:28 AM   #109
ghostrider1964
Edumacated Red Neck
ghostrider1964's Avatar
Oddometer: 5,485
Send a message via Yahoo to ghostrider1964
I know that is right My TKC is down to nubbs now and I don't even touch my rear brake
2008 R1200 GSA (Ghostrider), HP2E, 08KLR685,FOR SALE
"Fuck'em. I'm a lifer. " SlowOldGuy
TEXAS-ROLL THE BONES RALLY4 10/25-10/27/2013
http://www.rollthebonesrally.com/
ghostrider1964 is offline   Reply With Quote
Old 01-24-2011, 05:30 PM   #110
GapRunr
GapRunr's Avatar
Oddometer: 384
I don't know about wet pavement yet, but on dry asphalt they are a little more loose than the TKC80's were. They certainly feel like much more of a knobby than the TKC's do when you are running 60 mph. The ride isn't as smooth and they seem a little noisier.
I also got a chance to try them in some loose dirt and slippery mud. This was the kind of mud that is hard to stand on and gets caked up in your wheels easily. They certainly had decent bite in this situation. The front felt almost like it had to much traction, and was reacting to every little rut and groove. It might also be that it was really dark out. Maybe if there had been some daylight I could have been looking further ahead.
If the weather cooperates then I should have a chance to try these out in the rain this week. We're expecting rain and wet snow over the next few days.
GapRunr Dual Sport Touring
07 R1200GSA - 81 R80g/s - 88 Hawk GT - 06 TW200 SuperDuper Tenere
GapRunr is offline   Reply With Quote
Old 01-24-2011, 05:40 PM   #111
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 6,206
What pressure were you running? I didn't notice any looseness on the front with the front at 30/rear at 32. And I ran it pretty much all the way out. Bags on, unloaded, maybe 6 gallons of gas, 247 lb rider. It looked to me that running the highest allowable psi (36) might make it "skittish" so I figured I'd run a little lower. ( I run Tourances at 32/34 or 34/36 for "everyday".) My usual ride has some gravel and some high speed street and I hate stopping and adjusting air 2 or 3 times a ride. Well, actually I don't hate it, 'cuz I don't do it. I try to find an acceptable balance point and just keep it there except on a dedicated dirt/street ride. Gravel/rock roads on max psi is just no fun at all.
Roll The Bones IV- What's coming next?
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy screwed with this post 01-24-2011 at 06:53 PM
slowoldguy is online now   Reply With Quote
Old 01-24-2011, 07:07 PM   #112
GapRunr
GapRunr's Avatar
Oddometer: 384
I've got them at 32 front / 36 rear. Bike weighs 580 and I'm about 240 with gear. I may play around with the air pressure a little.
Keep in mind that all of this was the first 50 miles on these tires. I also didn't get a chance to ride in much gravel with them. I went from asphalt to mud.
I'll see what they are like after a good heat cycle or two. I live a few miles from Deals Gap so I should be able to get them heated up a little.
Did you notice how quick the front steers with these? It felt like an oversteer situation with a car, where you turn in and then the front turns so quickly that you feel the back end rotating a little, kind of like carving on skis versus sliding sideways, if that analogy makes any sense.
I'm curious to see how these handle after they are broken in a little.
Old 01-24-2011, 11:42 PM   #113
More CowBell
gotahave moreCowbell
More CowBell's Avatar
Oddometer: 212
The Big Block
Man I would like to ride Deals Gap!
I just got a Kenda Big Block, Man it looks wide. Ill be mounting it up soon.
13 KTM 350EXC, uncorked, race bike with a plate
08 Yamaha WR250R, adventure/Commuter
05 Montesa 4RT, everyone should have a trials bike
More CowBell is offline   Reply With Quote
Old 01-25-2011, 06:19 AM   #114
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 6,206
The turn in was noticeably quicker than the Tourances, or Shinko's, or Anakees. Can't really compare to the TKC's as I don't have enough miles on them on a 12 GS Adventure. As I was in the first 50 miles, I didn't push them either. Looking forward to your report from the Dragon.
Old 01-25-2011, 11:49 AM   #115
Get_Bent
Get_Bent's Avatar
Oddometer: 776
Picking up my GS today from the dealer and have already been looking for different tires.
What do you suppose it would take to get a set of the new Kendas to "tsiklonaut"
http://www.advrider.com/forums/showthread.php?t=480532
Those two seem to run the TKCs under all sorts of conditions and seem to be in the perfect spot to provide real world feedback on how the Kenda holds up.
http://www.getbent.net/adv
2008 KLR650 30,455m -- Bunch of Farkles
2010 R1200GSA 29,419m -- Not as many Farkles
Live in Minnesota and Ride? Read this
Get_Bent is online now   Reply With Quote
Old 01-25-2011, 02:56 PM   #116
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,458
Originally Posted by yellowbirdrs View Post
looks great! Now can someone put some thousand miles on them to see how long they last
the baseline is gonna be mileage & price vrs tkc-80
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
Old 01-26-2011, 09:36 PM   #117
GapRunr
GapRunr's Avatar
Oddometer: 384
rain riding
I finally got a chance to ride in the rain with these. It's been raining and cold (38F) the last few days. Traction seems pretty good. Tuesday night after dark a car with no lights on pulled out in front of me when it was raining pretty hard. I grabbed a handful an the ABS didn't even kick in. Seems to be plenty of traction. I haven't had much chance to get them leaned over much more than half way but so far they grip pretty well.
Old 01-27-2011, 05:52 AM   #118
Motorman
Motorman's Avatar
Oddometer: 474
That's good news! On all fronts.
Hope you had a chance to give her a toot or a one-fingered salute.
Old 01-27-2011, 08:11 AM   #119
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 6,206
That's real good news and better than expected. My rear wheel is headed for a tune-up, so maybe I'll get to join you in a ride report soon. It's just k i l l i n g me .
slowoldguy screwed with this post 01-27-2011 at 06:41 PM
Old 01-27-2011, 09:23 AM   #120
bigdave-gs OP
Explorer
bigdave-gs's Avatar
Oddometer: 1,900
Send a message via Yahoo to bigdave-gs
I'll pick up your wheel from Ghost tonight and head to Austin Friday. Maybe if he's not too busy he can fix it while I'm in town.....hopefully.
It is said, some lives are linked across time, connected by an ancient calling that echoes through the ages.
Currently riding a 2004 R1150GS Adv. but a very long list of others over the 30 + + years of riding
bigdave-gs is offline   Reply With Quote
Times are GMT -7.   It's 01:58 PM.
