Old 02-25-2013, 07:45 PM   #1606
2whlrcr
gooligan
Oddometer: 6,697
All you need now are streamers coming out the ends of the handlebars.
2whlrcr is offline   Reply With Quote
Old 02-25-2013, 08:28 PM   #1607
andrewgore
Gremā
andrewgore's Avatar
Oddometer: 3,668
My 280 head arrived today. I got down to business after dinner.
3rd kick, she fired up like a champ. Giggity.
Just in time for the snow storm we're about to have
Andrew
andrewgore is offline   Reply With Quote
Old 02-26-2013, 05:17 AM   #1608
joe cool
joe cool's Avatar
Oddometer: 980
Good to hear you got her running
"One more day I find myself alive
Tomorrow maybe go beneath the ground"
Garcia/Hunter
joe cool is online now   Reply With Quote
Old 02-26-2013, 05:51 AM   #1609
eyedragaknee
McGuyver
eyedragaknee's Avatar
Oddometer: 2,319
Streamers
You pokin fun at my accessories?
2008 KTM250-XCFW
2013 Beta 300 Trials
1966 Honda 305 Scrambler
eyedragaknee is offline   Reply With Quote
Old 02-26-2013, 10:14 AM   #1610
rotorhead511
Live and let live.
rotorhead511's Avatar
Oddometer: 496
Realized my clutch was dragging due to low clutch fluid. I can't find in the manual or on the GasGas web site what fluid it takes. Brake fluid is DOT4, anyone know what I should use in my '04 GasGas?
'12 450 XC-W
'11 300 XC
'04 GasGas TXT Pro 280
'89 Honda Transalp XL600V
rotorhead511 is offline   Reply With Quote
Old 02-26-2013, 10:17 AM   #1611
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,129
Thumb Mineral Oil!
Mineral Oil For Hydraulic Clutchs. Thers is a few, I am considering Magura to change out the oil in my wifes clutch.
jonnyc21 is offline   Reply With Quote
Old 02-26-2013, 11:37 AM   #1612
lineaway
Oddometer: 3,201
If it is the green lid , then it takes mineral oil. I thought `04 was the last year for dot 4 in the standard models. My `04 raga takes mineral oil.
lineaway is offline   Reply With Quote
Old 02-26-2013, 01:19 PM   #1613
rotorhead511
Live and let live.
Oddometer: 496
Well crap, just replaced old fluid with fresh mineral oil.
Lineaway, you are correct. I found it on the GasGas site. '04 Raga and '05 and newer take the mineral oil.
I flushed, re-flushed, back bleed and re-bleed with DOT4. What's the worst that could happen...? It's right now.
Lesson learn.
'12 450 XC-W
'11 300 XC
rotorhead511 screwed with this post 02-26-2013 at 03:26 PM
Old 02-26-2013, 05:25 PM   #1614
wb22rules
Bourbon Tester
Oddometer: 198
Finally broke out the Gas Gas for the first time in couple months and mixed up some fresh fuel with the Bel Ray Synthetic oil I had picked up last month. I had been using Motul when I first got the bike but had read up here that it will separate in the cold weather so am not going to use it again for a couple more months. Putted around the lot looking for trees showing signs of wanting to be firewood this spring, didnt find any volunteers other than the two that have already shown signs of being ill. Also I was reconning where to make some sections on the slopes to the side and rear of my 5 acres this spring. I will have to break out the camera next time and show you guys the area I have to work with for some ideas.
After it got warmed up I drained the fluid and changed it to some BelRay 75W two stroke clutch oil to see if I could help with the clutch dragging problem I have been having. It helped fairly well but I still would like to reduce the dragging so I could use two fingers instead of four on the clutch. I will start another thread on that subject and see if the brain trust can help me determine if I need clutch plates/springs or not.
2001 Gas Gas 321 TXT
1980 Yamaha IT 250G
wb22rules is offline   Reply With Quote
Old 02-26-2013, 06:35 PM   #1615
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,129
Lesson learn.
Sorry about that... I messed up on the year...
The diffrance between the two for the most part as I understand it is how they are affected by water, and what they would do to any of the rubber seals. Considering that it wasn't in there long it shouldn't cause any issues. But I admit I am not sure what type of rubber they use so am not 100% sure.
The last time I put in the wrong kind of fluid in a system it was on purpose to cause the rubber seals to swel and seal up better (short term fix to get a friends car home without leaking all the fluid out), after that we rebuilt the system and it was fine. The funny part is that was so long ago I don't even remember what fluid we used... but it worked great...
Old 02-26-2013, 07:22 PM   #1616
broncobowsher
broncobowsher's Avatar
Oddometer: 1,868
Brake fluid will swell a rear main seal to help keep oil in an engine. Used car lot trick.
Power steering fluid has been used to fix a leaky brake system in a friends Renault. Lasted longer then the rest of the car did.
AFT in a crankcase has been known to take a weeping seal and make it a pisser.
Not saying that these examples are always true. Just a few examples I have known from my (and my friends) mis spent youth.
broncobowsher is offline   Reply With Quote
Old 02-26-2013, 08:23 PM   #1617
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,129
Thats the ticket it was the Power steering fluid in the brake system trick.
Old 02-27-2013, 07:17 AM   #1618
mung
Oddometer: 618
Brake fluid
For brake fluid and clutch fluid in any trialer Dot 5 works very well.Silicone is inert so it is compatible with any type of seal.It is also very fade resistant.
mung is offline   Reply With Quote
Old 02-27-2013, 07:29 AM   #1619
rotorhead511
Live and let live.
Oddometer: 496
No worries Jonny, it was a quick fix. Worst case I change some o-rings in the distant future. I like tinkering anyway.
'12 450 XC-W
'11 300 XC
Old 02-27-2013, 10:52 PM   #1620
tifferes
tifferes's Avatar
Oddometer: 18
This pic was a few days ago, but finally getting back to work! In KS, this is the next best thing to a snowmobile or hills WB
tifferes is offline   Reply With Quote
Times are GMT -7.   It's 03:03 AM.
