Old 12-10-2013, 06:29 AM   #1966
lineaway
Oddometer: 3,090
It really does not matter that it goes flat, as long as you make the time you ride without a flat. Everyone should be checking the air just before they ride anyhow.
lineaway is offline   Reply With Quote
Old 12-10-2013, 08:41 AM   #1967
BEEF706
King of the dumb dab
BEEF706's Avatar
Oddometer: 745
That's what I was thinking but I still don't know what I know about trials.
NMOHVA Member NMTA Member
04 Beta Rev3 270, 92 Yamaha Wr200,
BEEF706 is offline   Reply With Quote
Old 12-10-2013, 09:09 AM   #1968
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,010
What Lineaway is saying is:
Just imagine a tire going flat and you checking it before you start and then riding quick enough so that you finish before it goes all the way flat. Does that help?
Gordy is offline   Reply With Quote
Old 12-10-2013, 09:32 AM   #1969
Sting32
Trials Evangelist
Oddometer: 1,448
Ok first thing is air the tire up to 40lbs. spray soapy water on each spoke nipple, if leaks around nipples, the fix is simple. Take the rear tire off, remove the rubber band, clean all the little bits of dirt that snuck down through spoke nipples and the rim. if rim is corroded badly (saw it once on an old 99 321) you can put a really thin bead of silicone on each side of the rubber band (not on nipples, dotn ask why I know) each SIDE of the rubber band!
else it is the tire. you can put a tube, you gain like 1 lb of weight with a tube, no big deal, dont lose the tubless parts (schrader valve you have to remove) so when you get a new tires you can go back go tubeless.
X-Lites last about a year before the constant flexing around the knobs of the tire, crack and leak for me. but by then tire is worn to hell anyhow, only $200 to replace, pocket change for some of you, lol.
Sting32 is offline   Reply With Quote
Old 12-10-2013, 09:58 AM   #1970
toro618
toro618's Avatar
Oddometer: 982
Like I said in my previous post, I have the new style spoked wheel...there is no nipple to leak from, and the problem was my valve stem. But I did have a leak from a nipple on my dirt bike, which has the Nuetech Tubliss system, where the strip was no longer overlaping like it was supposed to...put a new strip and leak was gone.
toro618 is offline   Reply With Quote
Old 12-10-2013, 10:09 AM   #1971
Sting32
Trials Evangelist
Oddometer: 1,448
Well I missed reading that, by "that much" (using my Get Smart voice)... lol
Old 12-10-2013, 10:43 AM   #1972
lineaway
Oddometer: 3,090
The solid rims always went flat. You might do the old tire shop way and put in in a tub of water.( put it in the kitchen sink or if you have a deep sink.) Could just be leaking along the bead. You did not mention the tire. New michlen I would guess. Even my `89 Beta had solid wheels. Flat every time I went riding was normal.
Old 12-10-2013, 10:52 AM   #1973
StuInFH
Oddometer: 444
That is interesting if you mean the tape when you say strip, because the tape has nothing to do with sealing. It is a cushion between the spoke nipples and the inner bladder. The latest instructions also say to not overlap the tape ends. My apologies if you are referring to something else, but I didn't wish anyone to think the TuBliss system relies on a similiar rim sealing strip and/or suffers from leaking spoke nipples like old-style trials wheels.
(I have six Tubliss systems installed and two old-style rear tubeless trials wheels in service, so I am well-practiced in inflation!)
Cheers
StuInFH is offline   Reply With Quote
Old 12-10-2013, 11:04 AM   #1974
toro618
toro618's Avatar
Oddometer: 982
Originally Posted by StuInFH View Post
That is interesting if you mean the tape when you say strip, because the tape has nothing to do with sealing. It is a cushion between the spoke nipples and the inner bladder. The latest instructions also say to not overlap the tape ends. My apologies if you are referring to something else, but I didn't wish anyone to think the TuBliss system suffers from leaking spoke nipples like old-style trials wheels.
Cheers
Yes sorry, I meant the tape. I have a whole bunch of dirtbike and spare rims which all have the Tubliss system.....except for the front wheels of my trials bikes, non of my dirtbikes have tubes. I think most of the tapes on my rims overlap a little, but hasn't caused any issues.
Just to eliminate any confusion when referring to the new style spokes, this is what the rim looks like
Old 12-10-2013, 11:32 AM   #1975
lineaway
Oddometer: 3,090
Montesa came out with those long ago. I hated those short spokes, but they were easy to replace!
http://www.triallinks.com/montesa_history.html
Old 12-10-2013, 12:10 PM   #1976
StuInFH
Oddometer: 444
So you acknowledge then that you didn't fix any leaking spoke nipples on a TuBliss system by re-doing the tape? Because the tape has nothing to do with sealing in a TuBliss system. That's my point.
Old 12-10-2013, 12:53 PM   #1977
BEEF706
BEEF706's Avatar
Oddometer: 745
WOW . '95, did they keep doing it up until the 4rt?
Old 12-10-2013, 01:13 PM   #1978
Brewtus OP
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,159
Honda came out with that rim design in 1982 for the 450 Rebel. And yes, it's still on the 4RT's.
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
Brewtus is offline   Reply With Quote
Old 12-10-2013, 01:16 PM   #1979
lineaway
Oddometer: 3,090
Beta came out with the tubeless in `87 I believe, the Montesa 311 in `93.
Old 12-11-2013, 07:21 AM   #1980
ridenm
ridenm's Avatar
Oddometer: 2,788
Honda works in mysterious ways. Cutting edge tech (80's version) for a 450 cruiser you never see anymore.
"Coming back to where you started is not the same as never leaving. ― Terry Pratchett (RIP )
ridenm is offline   Reply With Quote
Times are GMT -7.   It's 01:01 PM.
