Old 12-11-2013, 09:28 AM   #1981
toro618
toro618's Avatar
Oddometer: 987
Originally Posted by StuInFH View Post
So you acknowledge then that you didn't fix any leaking spoke nipples on a TuBliss system by re-doing the tape? Because the tape has nothing to do with sealing in a TuBliss system. That's my point.
Wow, dude. All I am saying, and I am not going to turn this into what caused the leak, is that I removed the old tape ran a new one (and over lapped it), and the tire no longer leaked from the spoke that was causing the leak in the first place. Can I make this any clearer for you to understand?
toro618 is offline   Reply With Quote
Old 12-11-2013, 11:19 AM   #1982
val4215
Oddometer: 45
Last Sunday San Diego Trials Association event at Motoventures.
Great day!
val4215 screwed with this post 12-11-2013 at 11:22 AM Reason: Add Stuff
val4215 is offline   Reply With Quote
Old 12-12-2013, 12:36 PM   #1983
StuInFH
Oddometer: 469
LOL, it is totally clear if you are going to keep saying that "and the tire no longer leaked from the spoke that was causing the leak in the first place" that you have no idea how the system works. Spoke holes can't cause a leak, you likely inadvertently fixed the seal at the interface with the beads when you took the tire off to play around with the tape. Is that clear enough for you?
Never hurts to read install instructions, try it some time.
StuInFH is offline   Reply With Quote
Old 12-12-2013, 12:43 PM   #1984
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,163
Maybe ease up a bit, eh? In all likely hood, when he dismounted the tubliss to fix the tape he got a better seat of the system (like you said) but there is no reason to be rude about it in this thread.
http://nuetech.com/tubliss/#durability
Gordy is offline   Reply With Quote
Old 12-12-2013, 02:37 PM   #1985
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,163
Originally Posted by brewtus View Post
I'm a bit confused here. Help me understand, Toro.
The rim that you showed in your photo is a tubeless rim. You keep talking about a Tubliss system. The tubeless rim in the photo does not need a tube of any type, Tubliss or not. That was the whole point of it being made in the first place. Tubeless tires mounted on a spoked rim as a "Look at our cool engineering" ploy Honda did on the utterly forgettable 1982 Rebel 450. The spokes mount to the rib in the center of the wheel, not the outer rim itself. Air cannot leak out of those, they never even come into contact with the spokes. About the only way I can see that air can leak anywhere near the wheel depicted is if you have a porous wheel, and I doubt that since those wheels are fabricated with extruded aluminum.
Help me out?
It's getting confusing.
I think some guys are talking about the Neutech Tubliss system that is on dirt bikes (but could be used on older trials bikes or in the front tire of any bike) and some are talking about tubeless wheels with rim strips and then, there is the "latest" rims that the spokes attach to the ribbed wheel.
Whatever the case, it doesn't leak anymore!!
Old 12-12-2013, 02:40 PM   #1986
Brewtus OP
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,196
Yup. Went back to his original post. Nuked mine. Thanks Laser and Gordy for quoting it....Woops, looks like Laser nuked his too.
Carry on boys. Without incurring the wrath of Nev, that is.
To misunderstandings!!
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
Brewtus screwed with this post 12-13-2013 at 05:57 AM Reason: Nuke and pave....
Brewtus is offline   Reply With Quote
Old 12-12-2013, 03:30 PM   #1987
StuInFH
Oddometer: 469
Originally Posted by rotorhead511 View Post
+1 Thanks for trying to help Toro.
Intentions notwithstanding, it is not helpful for someone to say his Tubliss system leaked through the spoke and he fixed it with tape. Anyone considering the system instead of a leaky rim strip type wheel on their TB should instead know they are not the same at all. I tried to correct the misinformation and I am told it can't be made any clearer to me?
Yeah, I don't suffer fools well.
Old 12-12-2013, 03:42 PM   #1988
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,163
You're right!!! You win!!!
Old 12-12-2013, 04:32 PM   #1989
Huzband
Team Dirt
Huzband's Avatar
Oddometer: 4,306
Is this the "what I did today" thread or the "argument over how to fix a Tibliss leak" thread?
I'm asking so I know how to post appropriately.
'07 R12GSA (Moose), '97 KTM 400 R/XCe, '90 RM250, IBA #30344
Huzband is offline   Reply With Quote
Old 12-12-2013, 05:40 PM   #1990
lineaway
Oddometer: 3,219
So did the valve stem cure the leak on the real tubeless rim? Like I said all the old ones always seem to have a slow leak. Twinshock anyone.
lineaway is offline   Reply With Quote
Old 12-13-2013, 05:51 AM   #1991
toro618
toro618's Avatar
Oddometer: 987
Yes, the source of the leak on the factory gasgas real tubeless rear rim was the valve stem, which did not show any sign of a leak with the water and soap technique. Nevertheless, a new one stopped the leak.
Old 12-14-2013, 01:11 PM   #1992
Brewtus OP
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,196
So, I have 3 Trials bikes that need tires, two need fork seals, one needs a shock overhaul, 3 need to have the top-end freshened up, all need a bi-annual service. Did I do any of that today?
No.
Instead, I dug out a 10-year old can of Honda red spray paint, and rattlecanned the sun faded seat base of my old 314R -
The front fender is next. Damn good use of my time this afternoon, I think.
Old 12-14-2013, 03:39 PM   #1993
lineaway
Oddometer: 3,219
That seat must have took 6 Tecate`s !
Old 12-14-2013, 03:54 PM   #1994
Brewtus OP
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,196
Oh please. It only took 2...
Old 12-14-2013, 04:22 PM   #1995
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,357
For a trials rider, you spend a lot of time making your 'seats', look pretty.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Times are GMT -7.   It's 01:51 AM.
