Old 05-01-2014, 09:29 AM   #2266
ridenm
not waiting anymore
ridenm's Avatar
Oddometer: 2,658
With advice from Ryan Young as well as Canadian and Australian Scorpa vendors, replaced the Long Ride tank on our street-legal 2008 Scorpa TY-S175/200F with the newer, slightly smaller stock tank the 125 comes with. The tank swap restores the lost steering lock and allows the bike to turn much tighter like a real trailer should. Next step will be investigating fitting a hydraulic clutch.
I've learned to live with reduced expectations--I'm a Vikings fan.
ridenm is offline   Reply With Quote
Old 05-01-2014, 01:15 PM   #2267
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,672
Originally Posted by Gordy View Post
The Domino grips beat me up though!
I have been using clear spray paint inside grips for a long time. You have about 10 seconds but has always worked for me.
AteamNM is offline   Reply With Quote
Old 05-01-2014, 03:58 PM   #2268
brewtus OP
Buffoonery, Inc.
brewtus's Avatar
Oddometer: 2,946
After riding the Team TY in competition this past weekend, I DO NOT recommend the Chinese hydraulic clutch. It sucks, and I do mean sucks something awful. It's going in the trash.
The next step for the 80, one you should look into. Heard lots of good things about it -
http://www.magura.com/en/powersports...allgemein.html
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
brewtus screwed with this post 05-01-2014 at 04:06 PM Reason: Chinese junk: Not just a catchy name!
brewtus is offline   Reply With Quote
Old 05-01-2014, 04:14 PM   #2269
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,382
The value of that bike is going up about 25%.
Gordy is offline   Reply With Quote
Old 05-02-2014, 10:10 AM   #2270
Longboardr
Longboardr's Avatar
Oddometer: 143
I use cheap hairspray and safety wire.
Longboardr is offline   Reply With Quote
Old 05-02-2014, 10:32 AM   #2271
tomatoe333
tomatoe333's Avatar
Oddometer: 2,280
AquaNet is useful for more than just scary 80's hairstyles!
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 05-02-2014, 12:38 PM   #2272
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 846
I ise standard Domino grips. They look nice the rubber is sticky and soft too, bit still don't wear as much as any other. To get them on I use brake cleaner which had worked very nice but you have only seconds for mounting.
PSchrauber is online now   Reply With Quote
Old 05-02-2014, 12:55 PM   #2273
ridenm
not waiting anymore
ridenm's Avatar
Oddometer: 2,658
Stupid question: have youse guys ever heard of grip glue?
Old 05-02-2014, 02:08 PM   #2274
PSchrauber
PSchrauber's Avatar
Oddometer: 846
Yes but spending many €€€ for a tubec were you only need 1/20 of the containment and which will then dry out if you try to use it again after two years.
Instead brake cleaner, I believe I use around 5 cans a year ... and so cheap!
Old 05-02-2014, 02:19 PM   #2275
brewtus OP
Buffoonery, Inc.
brewtus's Avatar
Oddometer: 2,946
Windex. Not any of the knock-offs either. Genuine Windex. Spray in the grip and on the bar, then install rather quickly. It'll dry in a couple of minutes, and the grips are there to stay.
I understand it also cleans glass.
Old 05-02-2014, 03:32 PM   #2276
Huzband
Team Dirt
Huzband's Avatar
Oddometer: 4,118
Yellows various iterations of plastic windshields as well. Not that that's been a problem on the Sherco. So far.
'07 R12GSA (Moose)
'04 Sherco 2.9 (Sherpa)
'97 KTM 400 R/XCe (needs a home)
'90 RM250
IBA #30344
Huzband is offline   Reply With Quote
Old 05-02-2014, 07:44 PM   #2277
Scubatoe
Trained monkey
Scubatoe's Avatar
Oddometer: 200
Probably the ammonia - fogs aircraft canopies, too. Rubbing alcohol.
Scubatoe is offline   Reply With Quote
Old 05-02-2014, 08:27 PM   #2278
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,382
Whodathought that you can trim up a EVO air filter with some scissors and it will fit an older Sherco pretty good?
You might want to try that if your dog chews up your Sherco filter.
Old 05-03-2014, 04:50 PM   #2279
Huzband
Team Dirt
Huzband's Avatar
Oddometer: 4,118
I can offer a home for the dog if need be.
'07 R12GSA (Moose)
'90 RM250
IBA #30344
Old 05-03-2014, 04:55 PM   #2280
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,382
We couldn't blame him. Poor guy, it just looked like one of his stuffed animal toys. All good and we are at an event now.
Times are GMT -7.   It's 12:20 AM.
