Old 12-22-2012, 09:49 AM   #1396
nwcycle
nwcycle's Avatar
Oddometer: 1,194
Awesome but............
Ktms dont like the ice tires, since they have no cush in the rear sprocket it tends to rip the main drive shaft in half....
I replaced about 3 in the last 2 years for buddys.... FYI
nwcycle is offline   Reply With Quote
Old 12-22-2012, 10:51 AM   #1397
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 634
Tweaked the front fender....
It got hung up on the header under full compression of the forks and did not work so good. I just put some foam between the fender and mounting screws on the front. This angled the fender closer to the tire in back and now it does not hang up anymore. Looks a bit......off but it works.
SCExpat screwed with this post 12-22-2012 at 10:52 AM Reason: pic size.
SCExpat is offline   Reply With Quote
Old 12-22-2012, 11:31 AM   #1398
2whlrcr
gooligan
Oddometer: 6,700
Originally Posted by Gordy View Post
I'm glad that I don't live anywhere that I have to stud the tires on my KTM, but that is bad-ass!
I bet you don't own snowshoes or roller skiis either.
2whlrcr is offline   Reply With Quote
Old 12-22-2012, 11:36 AM   #1399
2whlrcr
gooligan
Oddometer: 6,700
I don't do ice, just normal off road trail riding stuff. Tire still spins easily, if you want it too.
Old 12-22-2012, 12:45 PM   #1400
nwcycle
nwcycle's Avatar
Oddometer: 1,194
Dats Coo
Just wanted to give you a heds Up !!
Old 12-22-2012, 05:03 PM   #1401
Gham
Gham's Avatar
Oddometer: 1,373
That looks soooo easy sitting here at my warm kitchen table! I took my street bike around the block this week and lost my breath by the end of our driveway
Member 6204
Society Historicus Revisioniscus
Gham is offline   Reply With Quote
Old 12-22-2012, 05:33 PM   #1402
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,157
Nope, and I barely have a use for a snow shovel. Just the way I like it. But, if I want to go skiing, there are some great places only 2-3 hours away.
Going riding on "dry dirt and rocks" tomorrow!! Oh yeah, got some backyard trials in today too!
Gordy is online now   Reply With Quote
Old 12-22-2012, 06:40 PM   #1403
2whlrcr
gooligan
Oddometer: 6,700
I like the change of seasons and ability to change up sports. Helps to keep things fresh and exciting. Although the older I get, the less I like dealing with the cold. Love the snow, but you can have the below zero stuff. Today was 20F and sunshine. Very pleasant for XC skiing today. I'll take the KTM out tomorrow again.
I probably won't ride my trials bike again until March, with the exception of some balance practice. I try to get on it at least once a week through the winter, for a few minutes of balance practice.
Old 12-22-2012, 10:08 PM   #1404
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,132
Wicked Wife's first day outside of the yard.
Wife, the Kid and I went riding. Still have to get the kid a trials bike but we are working on it.
jonnyc21 screwed with this post 12-22-2012 at 10:08 PM Reason: wrong link
jonnyc21 is offline   Reply With Quote
Old 12-23-2012, 03:53 PM   #1405
amcross
Career Rookie/Novice
amcross's Avatar
Oddometer: 203
I'm NOT a capable static balancer. I haven't worked on it in several weeks b/c I was SOOO frustrated at last effort.
today must've been "the magic day"....
CHECK IT OUT! kick starting my little GG80 from a static, shift adn GOOOOOO!!!
AnnMarie Cross, permanent Noob! & proud wife of "macattack"
Join us in 2014 at the 2nd annual Tilton Trials, Illinois!
Novice owner of "GheeGhee", '01 GG 80big & also '01 GG280 "TriXTer"
amcross is offline   Reply With Quote
Old 12-23-2012, 07:33 PM   #1406
dmay
Oddometer: 256
Head angle mods on Fantic twinshock
I love my 240 fantic but to make it turn well the rear shocks had to be at max preload and the forks sagged as much as tolerable plus slid through the crowns a bit,so since I wanted to clean it up and repaint I decided now was the time to pull that head angle in a couple of degrees. Never having done this before I was very careful and thought through every step before attempting.
First secure the frame to a reliable stand,needed to be on wheels since snow is in the forecast and I don't want the cars outside if I don't complete the job in time.
Next cut away all the gusseting to allow for the bending.
Slid a thrashed set of forks through a equally thrashed set of clamps upside down,used the bottle jack from my engine hoist,axle slid right through the hole in the end of the jack,small tubes over the axle to keep the jack centered.padded the rear frame loop.
Cut out a 5mm thick "biscuit"-scientifically determined by finding it under my workbench,whatever the headangle ended up would be better than stock
Mounted angle gauge so results could at least be monitored.
Then just as I needed a extra hand a buddy showed up(Bill Super)
So I forgot to take pics of the cut and sliding the biscuit in place,but here's the post welded toptube.
A total of two degrees change,should allow me to run the suspension for best hookup while still turning well.
Will be adding in some reinforcements and fabricating new gusset plates.
Then on to lower footpeg brackets and stripping and repainting(I paint everything with Appliance Epoxy so it's either black or white)
My engine hoist jack plus forks for a lever made this a non-event,no heating of the downtubes not necessary,VERY little force on the jack opened the gap right up,had Bill open the release valve while I held the biscuit in place and the top tube aligned--easypeasy!
Doug
2011 Sherco 250 trials,83 Fantic 240 trials,1992 Fantic 309 trials,09 Kawasaki KLX250s,1984 SWM 320TL,03 KTM 640 Adv
dmay is offline   Reply With Quote
Old 12-23-2012, 07:40 PM   #1407
andrewgore
Gremā
andrewgore's Avatar
Oddometer: 3,671
Finally picked up another trials bike after a 2.5 year hiatus. Less than 24 hours I managed to explode the rear fender after looping out in the snow.
Its a 1999 gasgas 270. Much improvement over my old 1994 250.
Andrew
andrewgore is offline   Reply With Quote
Old 12-24-2012, 05:33 AM   #1408
amcross
amcross's Avatar
Oddometer: 203
Andrew
Welcome back, Andrew! Hope you love your GasGas as much as I'm loving mine!! (2001 GG 80)
Old 12-24-2012, 06:09 AM   #1409
Gham
Gham's Avatar
Oddometer: 1,373
Very nice idea,hope it works out as planned!
Member 6204
Old 12-24-2012, 06:27 AM   #1410
joe cool
joe cool's Avatar
Oddometer: 980
Doug, Tell SUPER Bill Hi! for me.
Kirby
"One more day I find myself alive
Tomorrow maybe go beneath the ground"
Garcia/Hunter
joe cool is offline   Reply With Quote
Times are GMT -7.   It's 06:08 PM.
