Old 12-13-2010, 06:07 PM   #1
jdrocks OP
Gravel Runner
Oddometer: 4,498
V649HP-Kawasaki's new gravel runner
can't buy one. ya have to build it.
so with all these Kawasaki Ptwin powered bikes popping up all over, i figured i'd throw my hat in the ring once again...with a twist. this bike is going to be a gravel runner, not a dirt bike, and follow along the lines of my previous bike builds on this platform. proven performers over 25,000 miles and 6,000 miles of gravel roads. there might be a little fabrication work needed, as well as a little machining required. the emphasis will be on building an inexpensive bike that's still a good performer and easy to build. sort of an everyman's bike...fun, fast, and cheap. ya know, for those of us that are cheap SOBs, either through necessity or choice.
let's see how much bike can be built for 10% of the cost of a new Tenere. ambitious i know, but the budget for this build is going to be a grand total of $1200 initial cost. $1200 for a new rock and rollin' gravel runner, ready to ride.
when i got back from the maritimes in september, i knew i was going to build a new bike over the winter, and the long search for a suitable project bike began. months went by, but i finally found this one cheap. near new, scraped up plastic, and the price was ridiculous.
all i wanted from this bike was the engine and related items, the rest is being parted out. some parts already sold, and by the time it's gone i hope to have more than doubled up on the purchase price. now i have a new sport bike engine and everything required to make it run properly, plus some cash to get going on the rest of the bike.
gotta have a frame, let's sell the ninja frame and try a versys frame instead.
engine should bolt right in...think i'll hold onto the ninja frame while i try it out.
off to a good start. engine, frame, and the budget looks manageable at this point.
(stay tuned)
jdrocks screwed with this post 01-24-2011 at 04:17 AM
jdrocks is online now   Reply With Quote
Old 12-13-2010, 06:13 PM   #2
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,639
Thumb
love your builds
johnwesley is offline   Reply With Quote
Old 12-13-2010, 06:31 PM   #3
jdrocks OP
Gravel Runner
Oddometer: 4,498
Originally Posted by johnwesley View Post
love your builds
thanks. newfies snowed in yet? it's looking like another old time winter in the states.
Old 12-13-2010, 07:18 PM   #4
SamM
Jeep Overlander
Oddometer: 1,471
jdrocks,
Are you going to try to minimize the Versys frame? There seems to be numerous metal tabs and brackets that could be removed. What about going with a conventional swingarm and shock from another bike? Will it have spoked wheels?
Looking forward to seeing what you come up with!
You guys have me thinking about doing one of these.
SamM
SamM is offline   Reply With Quote
Old 12-13-2010, 07:33 PM   #5
jdrocks OP
Gravel Runner
Oddometer: 4,498
Originally Posted by SamM View Post
jdrocks,
yeah, frame gets shaved, then repainted. don't need or want spoke wheels. i run tubeless, and building a set of wheels for the size tires i run is a budget buster for this bike.
i have both swing arms, not sure which one i'll use. i'm not going to build a custom swingarm. undecided on shock.
you should have considered the 649HP for your KLR.
Old 12-13-2010, 07:47 PM   #6
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,639
Sorry about my confusing location NF is National Forest. Your not the first to say that. I should change it.
What do you do with the old builds? this is your third, right?
Old 12-13-2010, 07:47 PM   #7
SilentRay
Rebuilt
SilentRay's Avatar
Oddometer: 564
Yet another 650r converted to d/s thread
Lurkin again. You guys are killin me with the ninja conversions. Wish i had the fab skills.
Really enjoyed ridding the ex's 650r on pavement. But once on even just gravel, that lay down shock really sucked.
As much as i like the SV 650 v twin, the parellel twin is smoother. Great all around engine.
SilentRay is offline   Reply With Quote
Old 12-13-2010, 08:00 PM   #8
jdrocks OP
Gravel Runner
Oddometer: 4,498
one of the reasons you can find these bikes cheap is that they get wrecked regularly, many times after just a few miles on the road. this bike still has the nubs on the tires.
when i know a kid has had his hands on something automotive related, i'm naturally suspicious. sorry, that's just the way it is based on my experience. 999 out of a 1000 just can't turn a wrench these days. video games yes, wrench no.
this is the second bike in a row with a botched generator cover repair. in both cases, the kid tried initially to patch it up with JB Weld. predictably, it didn't work.
when that didn't work, the cover was removed. why a replacement cover wasn't purchased is anyone's guess, just don't know. the damaged cover was reinstalled and the bolts snugged up, no gasket, no RTV...except this is the way it was left inside the now attached cover.
the stator coil was left loose and not bolted to the back of the generator cover, while the leads were not secured behind the clamp. the leads were actually pinched on the mating surface and need a little repair.
i wasn't sure how much oil was in the engine, and looking at that cover, i wasn't tempted to hit the starter button. close call for sure.
Old 12-13-2010, 08:07 PM   #9
jdrocks OP
Gravel Runner
Oddometer: 4,498
not a newfy? darn, i was about to ask if it would be ok to change tires in your garage the next time i'm up there.
old bikes are history.
Old 12-13-2010, 08:15 PM   #10
jdrocks OP
Gravel Runner
Oddometer: 4,498
ya don't need super fab skills on these gravel runners. these are more of a bolt together build. what you do need is the ability and patience to find cheap parts.
the custom parts can be fabricated with inexpensive tools, then have a buddy weld things up if you don't own a welder.
machine work is just jobbed out. nothing expensive.
Old 12-14-2010, 03:52 AM   #11
jdrocks OP
Gravel Runner
Oddometer: 4,498
As much as i like the SV 650 v twin...
do you happen to have a second generation SV650, 2003 and up? need a favor.
or anyone else that that has this model bike. PM me please.
Old 12-14-2010, 04:10 AM   #12
SilentRay
Rebuilt
SilentRay's Avatar
Oddometer: 564
No, sorry. Son in law had one a couple of years ago and sold it for a Busa.
Old 12-14-2010, 04:11 AM   #13
A_Vasiliev
M-ass-ter Craftsman
A_Vasiliev's Avatar
Oddometer: 1,384
That is one hella fugly fairing on the first pic.
I will be watching the thread, though.
Originally Posted by A_Vasiliev View Post
Please, stop acting like a child.
Originally Posted by NJ Moto View Post
Not going to happen.
A_Vasiliev is offline   Reply With Quote
Old 12-14-2010, 04:17 AM   #14
jdrocks OP
Gravel Runner
Oddometer: 4,498
the "fairing" you mention is the stock 650R headlight assembly/windscreen attached to the tab on the frame stem. that's the parts bike, not the build.
Old 12-14-2010, 04:18 AM   #15
jdrocks OP
Gravel Runner
Oddometer: 4,498
no problem.
anyone else?
Times are GMT -7.   It's 05:33 AM.
