Old 01-02-2011, 05:32 PM   #136
tragerbon
tragerbon's Avatar
Oddometer: 131
That's looks hot !
I want to see the front forks in place, what will they be...will the two spacers From earlier in this thread be holding them in place ?
Bike free : (
tragerbon is offline   Reply With Quote
Old 01-02-2011, 06:29 PM   #137
jdrocks OP
Gravel Runner
Oddometer: 4,492
Originally Posted by tragerbon View Post
I want to see the front forks in place...
i should have forks and wheels on in a few days. some business stuff is going to interrupt my bike building.
jdrocks is online now   Reply With Quote
Old 01-02-2011, 10:58 PM   #138
SamM
Jeep Overlander
Oddometer: 1,471
ya really do need a riotous sense of humor around this place...
I meant it to be funny! Nice build jd!
SamM
SamM is offline   Reply With Quote
Old 01-03-2011, 03:29 AM   #139
jdrocks OP
Gravel Runner
Oddometer: 4,492
Originally Posted by SamM View Post
Nice build jd!
thanks. you should be working on that Ural rig while the KLR is out getting built.
Old 01-03-2011, 06:01 PM   #140
dentvet
Oddometer: 1,369
jd probably knows all these but here's a shock length table i thought was useful
http://oldskoolsuzuki.info/perversep...ngth/index.htm
dentvet is offline   Reply With Quote
Old 01-03-2011, 07:30 PM   #141
jdrocks OP
Gravel Runner
Oddometer: 4,492
thanks, hadn't seen that. working on a couple shock options.
so when are we going to see your bike? you're holding out on us.
Old 01-03-2011, 08:05 PM   #142
jdrocks OP
Gravel Runner
Oddometer: 4,492
a while back in this thread i asked whether anyone owned a 2nd generation SV650, i needed some information. no SV650 owners showed up, but an inmate by the name of "badguy" stepped right up to the plate. "whatcha need?"
i'm running the DL1000 19" three spoke front and wanted a matching 17" three spoke rear in the correct width with a 20mm axle. i needed the whole assembly, it had to be cheap, and that narrowed it down to the SV650 rear. i needed "badguy" to research some fitment issues to make sure it was pretty close before i went out and bought one. "badguy" PM'd me back in no time with the info, looked decent, so i found a cheap wheel, near new.
there are some things to work out to make it go, but it doesn't look like a big deal. the SV650 runs 525, but there are 520 sprockets available that bolt right up to the SV hub. i might keep the parts bike wheels for a SM set.
"badguy" turned out to be a good guy. much grass, my friend.
jdrocks screwed with this post 01-03-2011 at 08:11 PM
Old 01-04-2011, 09:42 AM   #143
KLRnit
KLRnit's Avatar
Oddometer: 61
Thumb
JD I think I most have missed it so I'm going to ask. What do you do with all your other bikes. I know you layed one down (glad your alright) but I'm talking about the ER-6C you built??? You do some awesome work man and I got to admit it inspires the hell out of me
2009 Ebony KLR650
Wish list: KLX450 forks with Emig Racing front end conversion, KLE650 VERSYS engine swap,rear long travel shock, and a butt load of your typical "bolt-on's !!!!"
KLRnit is offline   Reply With Quote
Old 01-04-2011, 02:17 PM   #144
jdrocks OP
Gravel Runner
Oddometer: 4,492
bikes are history. build 'em, ride 'em...gone. time to build something new.
fixed your sig line for ya-
Wish list: KLX450 forks with Emig Racing front end conversion, 649HP engine swap,rear long travel shock, and a butt load of your typical "bolt-on's !!!!"
Old 01-04-2011, 05:17 PM   #145
badguy
Susan
badguy's Avatar
Oddometer: 1,681
Glad I could help
Maybe I'll get to see this one in person
badguy is offline   Reply With Quote
Old 01-04-2011, 06:01 PM   #146
jdrocks OP
Gravel Runner
Oddometer: 4,492
Originally Posted by badguy View Post
Glad I could help
sure, just plan a jailbreak from smibville this spring. you're probably tired of looking at all that BMW iron over there anyway.
Old 01-04-2011, 10:25 PM   #147
KLRnit
KLRnit's Avatar
Oddometer: 61
Thanks but the thing about that is the gearing. I doubt it would be great for single track riding. Hell come to think about it my rear shock is blown because of my riding style
2009 Ebony KLR650
Old 01-05-2011, 05:06 AM   #148
jdrocks OP
Gravel Runner
Oddometer: 4,492
huh? gearing? the 6 speed cartridge style transmissions are identical in the two engines. the stock versys and 650r bikes are even delivered with the same sprocket sets. the engines are identical in size, configuration, and weight.
the 649HP engine uses different cams and runs higher compression, the CPU is mapped slightly differently, and produces more horsepower and torque in what i think is a pretty trackable range, even on dirt. crack those throttle bodies WFO on gravel or dirt and you better be holding on to something 'cause you're goin' for a ride. you can lighten the front end easily in 5th and 6th, both over drive gears.
then there's the cost. the 650R has to be one of the most crashed bikes ever produced and can be found everywhere in the USA with low miles and in good running condition...DIRT CHEAP. if you say you can't find one cheap, you just ain't looking very hard. i could go out and find another one today if i had to. just takes some research.
buy the whole bike and build it, or part it out if you just want the 649HP swap engine and related parts. in my case, the parts bike was so inexpensive that by the time i sell everything i don't want from that bike, the low mile engine is FREE and i've even made some money i can put in the build. see many of the lower performance engine equipped KLE650s available like that?
that's why you want the 649HP. case closed, next question.
Old 01-05-2011, 06:48 AM   #149
dentvet
Oddometer: 1,369
my bike is coming along slowly. i freshened up my fuel tank scenario. Canned bedliner is now my new favorite finish. if somebody needs the fuel pump bung for a klre build off the old tank, let me know.
My peg situation is in flux. shown is versyse peg overlaying ninja peg, much better position. option 2 is the crf peg shown with custom mounts like the other mutant thread. hmmmm
i have a willing donor should i decide to go ala sanjoh.
Old 01-05-2011, 07:08 AM   #150
jdrocks OP
Gravel Runner
Oddometer: 4,492
my bike is coming along slowly...
you could have that ready to roll pretty quick. i'd concentrate on wheels and suspension, you can tinker with the pegs any time.
do you have a KTM cush drive rear also?
Times are GMT -7.   It's 04:35 AM.
