Old 09-11-2012, 06:04 AM   #1621
jdrocks OP
Gravel Runner
Oddometer: 4,278
i continue to get many inquiries, primarily from Versys riders, about swapping in the DRZ400 49mm conventionals. the fork swap is easy, the wheel and brake setup also fairly easy, with the variables mainly revolving around wheel selection.
the photo of the 52mm to 49mm sleeves required to reduce the ID of the Versys lower clamp is way back in the thread, so here it is again. the sleeves are upside down in the photo, but you can see that a lip was left on the top so that the sleeve self aligns and self trims when placed in the clamp.
the sleeves are slotted top to bottom, with the slot aligned with the pinch slot on the clamp to achieve concentric clamping pressure, very important. the sleeves were set in the clamps with a few drops of Loctite cylinder sleeve locker.
the upper clamp was reduced from 50mm to 49mm with roll formed sheetmetal of the appropriate gauge and cut to size, only takes a few minutes, and was not glued in place.
jdrocks is offline   Reply With Quote
Old 09-17-2012, 06:05 PM   #1622
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,673
Well I'm back home, another 2500 miles on the F8. After following all those moto's around, I'm going to take back my harsh words about the Ohlins suspenders. I think they kept the ride as soft as could be expected, and kept the pig pointed in the right direction most of the time. I didn't think I'd make it a couple times.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 09-18-2012, 11:06 AM   #1623
jdrocks OP
Gravel Runner
Oddometer: 4,278
David
i thought that was the gripe against the OEM forks...too soft.
Old 09-18-2012, 07:22 PM   #1624
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,673
Sounds about right. I didn't feel them bottom, but yet it soaked up some pretty rough stuff. Centerstand hit a couple of times on g-outs.
David
Old 09-19-2012, 10:43 AM   #1625
kajj
kajj's Avatar
Oddometer: 192
Hey JD. Do you any close up pic`s on how the versys caliper bolts to the adapter and DRZ fork?
kajj is offline   Reply With Quote
Old 09-19-2012, 02:47 PM   #1626
jdrocks OP
Gravel Runner
Oddometer: 4,278
spacer is nominal 1/4", 6.3mm steel. layout, then drill and tap as necessary for full pad contact on the rotor. spacer mounting bolts may need to be clearanced to avoid interference with the rotor.
Old 09-19-2012, 02:52 PM   #1627
jdrocks OP
Gravel Runner
Oddometer: 4,278
David
at least they're adjustable now. too soft, and the front end wants to dive into Montana trouble before ya can get on the gas to yank it back out.
Old 09-19-2012, 06:51 PM   #1628
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,673
I'll keep that in mind. My lack of suspension knowledge is now out for everyone to see.
David
Old 09-20-2012, 09:53 AM   #1629
kajj
kajj's Avatar
Oddometer: 192
Ok. Thanks.
I did manage to find a used swingarm bolt from a ER6 to use as the front wheel axle.
The build will continue in a few weeks when it gets to cold to ride.
Old 09-20-2012, 02:33 PM   #1630
jdrocks OP
Gravel Runner
Oddometer: 4,278
David
lucky for you, it's a very small world in here. you're safe.
Old 09-20-2012, 02:37 PM   #1631
jdrocks OP
Gravel Runner
Oddometer: 4,278
Ok. Thanks.
that's the easiest and least expensive solution. cheaper than buying a bolt or turning a custom axle. it's a true 20mm, no slop on the bearings.
i thought you guys mounted studded tires and rode all winter.
Old 09-21-2012, 10:15 AM   #1632
kajj
kajj's Avatar
Oddometer: 192
hehe. When will I have time to work on the bike then. I guess it would work for a while.
But when the temperature drops down below -30 degrees Celsius in mid January It`s a bit to cold to ride.
I would be fun thou.
Old 09-22-2012, 05:51 AM   #1633
jdrocks OP
Gravel Runner
Oddometer: 4,278
i was riding at Michaux yesterday, just scouting the gravel since i hadn't been there before.
stopped for fuel on the way back, and a twenty something guy in a beat to crap Jeep Cherokee leaned out the window...
"does that bike really have 649 horsepower?"
"yeah son, it really does."
"oh, way cool."
Old 09-22-2012, 08:42 AM   #1634
kajj
kajj's Avatar
Oddometer: 192
"oh, way cool."
Old 09-22-2012, 09:38 AM   #1635
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,242
"oh, way cool."
Some peoples kids.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Times are GMT -7.   It's 11:45 AM.
