Old 11-27-2012, 01:50 PM   #1741
OHjim
Oddometer: 377
JD - Do you know what the length (eye to eye) and travel is for the R1 shock? I searched the thread but couldn't find it. Also I know you changed to a 900 lb/in spring but do you know what the OEM rate is?
Thanks.
Current: '07 Tiger 1050
Past: 04, 05 & 06 Wee, 06 Tiger 955i, 04 ST1300, 85 Magna, 99 Bandit 600, 83 Nighthawk, 74 CB350four
OHjim is offline   Reply With Quote
Old 11-27-2012, 04:57 PM   #1742
jdrocks OP
Gravel Runner
Oddometer: 4,566
Thanks.
the R1 is just slightly longer, maybe 10mm, with about a 7mm longer stroke which yields about 6.5" of travel...except it's not usable since the tire will contact the fender liner first. the tire will hit the liner with the OEM shock too if the shock is bottomed.
the OEM Versys spring is 16kg/mm or 895#. i replaced it with the 900# custom spring, or 16.1kg/mm.
i think guys swapping in the R1 tend to use a spring that's a little too light for gravel road use, or any other condition where there might be a load on the bike.
jdrocks is offline   Reply With Quote
Old 11-27-2012, 07:43 PM   #1743
jdrocks OP
Gravel Runner
Oddometer: 4,566
the thing looks like a pile of goop, but it's the mold for the fiberglass rear fender. did i mention that i hate working with this stuff, but fortunately it doesn't take all that long. it takes longer to figure out what the shape should be than it does to mold the part.
while the resin was setting, i made up the plate mount. left a little room for a LED plate light.
Old 11-27-2012, 10:46 PM   #1744
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,774
lol. I like your stories JD, you do know how to drag them out for effect.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 11-28-2012, 03:43 AM   #1745
jdrocks OP
Gravel Runner
Oddometer: 4,566
David
i could write a report on my efforts making fiberglass parts, now there's a long rocky road.
that's nasty stuff to work with, next time i'm going to subcontract the work to this moto guy in Montana, he must be looking for some winter work, tired of forking hay to those cows already.
Old 11-28-2012, 12:10 PM   #1746
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,281
Originally Posted by jdrocks View Post
thanks, but man, have you noticed that there's some weird stuff going on in here?
It wouldn't be ADV without it.
How do you do this:
Threads: 602,598, Oddometer: 18,488,556, Inmates: 216,968
and not take advertising
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 11-28-2012, 03:20 PM   #1747
jdrocks OP
Gravel Runner
Oddometer: 4,566
How do you do this:
plus, they let guys sell LED lights and stuff.
Old 11-30-2012, 10:22 AM   #1748
jdrocks OP
Gravel Runner
Oddometer: 4,566
grabbed a little shop time to fab the last little pieces for the tail, a pair of light mounts. the small parts seem to take twice as long to fabricate than anything larger.
Old 11-30-2012, 03:58 PM   #1749
jdrocks OP
Gravel Runner
Oddometer: 4,566
then the light mounts get welded on the sides if the plate mount...
Old 11-30-2012, 04:04 PM   #1750
jdrocks OP
Gravel Runner
Oddometer: 4,566
then a little primer on the new fiberglass rear fender...
nothing like some primer to bring out things that need attention before the topcoat.
Old 12-02-2012, 03:43 PM   #1751
jdrocks OP
Gravel Runner
Oddometer: 4,566
painted a bunch of parts, always a challenge spraying urethane in a cold shop, and started reassembling the tail. i wanted more light on the bike after numerous long runs in the dark this season, surrounded by cager madness.
the first new lights were LEDs flanking each side of the plate that get tied into the brake light circuit.
the lights are tucked in tight, but visible from the rear and side, and have a wrap around gravel guard for bottom and front protection.
there's also a new LED strip light above the plate, way brighter than the OEM light.
Old 12-02-2012, 07:53 PM   #1752
jdrocks OP
Gravel Runner
Oddometer: 4,566
the next set of new anti-cager lights are 2" LEDs mounted in behind the Wolfman racks, and between the two will show plenty of red on the back of the bike. these are tied in on the running light circuit.
Old 12-02-2012, 11:22 PM   #1753
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,774
Looks good JD, when are you going to bring the horse out from from behind the barn and give us a full on picture?
How much weight did your horse gain in this procedure?
David
Old 12-03-2012, 04:12 AM   #1754
jdrocks OP
Gravel Runner
Oddometer: 4,566
David
not much net gain...unless you factor in urethane paint. i think the parts have around 5# of urethane tar stuck to them.
i need to wire the tail, and there's another set of lights too. then some other changes, and more paint. i need to hurry up, big expedition planned.
Old 12-03-2012, 10:46 AM   #1755
jdrocks OP
Gravel Runner
Oddometer: 4,566
new 2" amber LEDs mounted behind the Motech guards, out of harms way, also on a running light circuit. i think i'll put the ADVmonster LEDs back on too, help those cagers see me. it may seem extreme to add all these lights, but over this past season of travel, i've had more close calls than i could begin to count.
now, on to the rest of the plan to make the bike more visible.
Times are GMT -7.   It's 10:40 PM.
