12-24-2012, 10:00 AM
#1816 | |
Gravel Runner
Oddometer: 2,837
even though the motor has through bolt mounts in addition to the left and right front mounts, there must be enough rotational energy transmitted to this particular mount to cause it to loosen. i haven't seen other reports of these mounting bolts loosening, so it might be somehow related to the way these bikes are ridden, particularly offroad. i need to check them more often. |
12-24-2012, 10:48 AM
#1817 |
worldy traveler from afar
Oddometer: 245
JD........you could write the book for "severe usage" maintenance requirement on this bike.
BUT even RED Loctite has it's limitations. (off road racers have been known to put the welder to motor mount bolts/nuts in extreme situations) Prolly a better "note" to add to your mnx manual might be to "retorque" those pesky bolts on a more frequent schedule :nHey, right or wrong IS NOT what is important BUT instead, for the situations that you have put these bikes in-7-whatever works has become the new norm
When you have eliminated the impossible whatever remains however improbable must be the truth..
12-24-2012, 02:01 PM
#1818 | |
Gravel Runner
Oddometer: 2,837
from a lake campsite in southeastern BC in '09 on the way down from points north, i'd come all the way across from Bella Coola that day, and beat the heck out of bike once again on a long rocky logging road into the lake. nobody else there, wonder why. ![]() the bike had felt a little buzzy, and with 30 minutes of daylight left, i started looking over the bike and found the main M12 bolt loose, one missing M8, and one loose M8 that was about to fall out, all on the same right front motor mount. whatever the forces at work, the stresses are directed at that mount. the motor mount connections are structural on these frames, there could be consequences if you lose the bolts. the bike is just dirty in the photo, but two days later it would be upsidedown under a truck in Montana, not lookin' too sharp then. |
12-24-2012, 02:10 PM
#1819 |
Oddometer: 356
You're probably on top of this, but just in case, if you took out both your front top left and right motor mount bolts only, do you have any gaps between the motor and frame mounts? A bit of shimming may make these areas solid and eliminate some of the stresses your bike is seeing. Might be worth a check.
Just my .02, spend it anyway you want P.S. loosening all the mounts will expose your wiggle room and repositioning the motor/frame relationship may find a happy home, albeit of manufacturing tolerences is my experience, that'll be .03 pls TooFast screwed with this post 12-24-2012 at 02:41 PM |
12-24-2012, 03:13 PM
#1820 | |
Gravel Runner
Oddometer: 2,837
12-24-2012, 05:38 PM
#1821 |
Oddometer: 4,297
Is there paint on the surface of the mounts?
Paint on the compressed sections of the mount can cause bolt loosening. |
12-24-2012, 08:01 PM
#1822 |
louder, louder, louder!
Oddometer: 1,093
Safety wire. It's not just for racers anymore.
------------------------------ Suck, Squeeze, Bang, Blow ------------------------------ New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better! |
12-24-2012, 09:08 PM
#1823 |
Oddometer: 11
I'd second the safety wire then. The aircraft mechanics used it all over the engine bays of the general aviation aircraft. For some reason, pilots hate bolts coming off their engines
12-24-2012, 09:26 PM
#1824 |
Ridin' in MT
Oddometer: 1,009
Usually over stressed bolts stretch, or the holes they are in stretch. This is most easily seen if the bolts act like they are stripped or thread with difficulty. Casting the bolts are threaded into will pull out of the casting giving a raised appearance around the threaded hole.
If a bolt is loosening, perhaps it doesn't have enough stretch length. If there is enough stretch in the bolt it will usually stay tight even with vibration. Usually the recommended value is 10x the diameter should be allowed free to stretch. Another problem is the surface that is being clamped yeilding. High strength washers can help spread out the load when a soft material is being clamped by the bolt. Any of these sound familiar JD?
'07 VFR800, '09 F800GS, 07 CRF250X Riding roads in Montana - Big Sky Country www.mtrider16.smugmug.com Alaska Trip Report |
12-24-2012, 09:30 PM
#1825 |
Ridin' in MT
Oddometer: 1,009
You got a pic of the offending area? I happen to have a Verseys parked in my Garage. When I get done visiting my relatives, I can take a look on Thursday.
12-25-2012, 04:34 AM
#1826 |
Gravel Runner
Oddometer: 2,837
the M12 has paint at the outside, but mill finish aluminum at the motor. good point, but i don't think it's paint.
12-25-2012, 04:38 AM
#1827 |
Gravel Runner
Oddometer: 2,837
that's a thought, i've got some wire too.
12-25-2012, 04:42 AM
#1828 |
Gravel Runner
Oddometer: 2,837
a second vote for wire, you guys must not want to see a photo of a cop motor sitting in the middle of some far off gravel road.
12-25-2012, 04:47 AM
#1829 |
Gravel Runner
Oddometer: 2,837
nope...
whew, for a second there, i thought you were going to say, "if you slow down a little, the damn bike won't fall apart" ya know, somethin' like that. |
12-25-2012, 04:56 AM
#1830 | |
Gravel Runner
Oddometer: 2,837
those bolts are under plastic on the stock Versys, but exposed on mine, no excuse not to check them more often. |
