Old 06-24-2013, 02:02 PM   #1981
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by Roadracer_Al View Post
You don't dilly-dally around, do you??
Greetings from the Coal Mine Campground, on the Yukon river, north of Whitehorse.
sorry to miss you up there, but i was only in Dawson half a day, then across the river.
jdrocks is offline   Reply With Quote
Old 06-24-2013, 02:05 PM   #1982
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by Scubawerx View Post
JDROCKS, you said it, "JD ROCKS!!!" Nice build documentation. Keep it coming.
thanks, anyone with questions on the specifics, just ask.
Old 06-24-2013, 05:51 PM   #1983
4play
Next?
4play's Avatar
Oddometer: 2,620
Hello JD, While brushing up on Ninja's I stumbled across several Ninja road racers that were replacing the Ninja intake cam with the Versys. The duration is a bit shorter so no real surprise they were doing it for improved drive off the corners. I happen to have a Versys intake cam & since the motor is about to be on the floor anyway, I'm seriously thinking about trying it. I was going to check the valves anyway.
I got to ride mine quite a bit Saturday & other than one crossing the Hwy wheelie for those laughing at my calico paint scheme I never saw or needed anything over 6000 rpm, so moving the torque peak down a bit seems like a good idea. Your thoughts?
Family isn't always about blood
4play is offline   Reply With Quote
Old 06-24-2013, 06:41 PM   #1984
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by 4play View Post
Hello JD, While brushing up on Ninja's I stumbled across several Ninja road racers that were replacing the Ninja intake cam with the Versys...
Blue Ridge Racing came out with the cam switch when the Versys spec motor was introduced a year after the ER6 motor back in about 2007 for the euro models. they still sell the cam kits.
i haven't been tempted to do this modification, as i'm not racing , reliability is at the top of my list, and around 70hp is enough. i run stock ER6/Versys gearing too, and haven't felt the need to change that either.
if i had a stock Versys spec motor in one of these motos, i would be looking for some horses. i can definately say that the Versys spec motor is nothing like the cop motor, i just proved it to myself after a 5000 mile run.
Old 06-24-2013, 06:58 PM   #1985
4play
Next?
4play's Avatar
Oddometer: 2,620
I'm not looking for more horsepower I'.m not racing this thing either & I'm not talking about anything that would hurt reliability (stock versys intake cam). The net effect should be to shift the torque curve lower in the RPM range. Gearing, I went with a really tall rear tire & need to compensate for that some. After Saturday's ride I'm thinking about gearing it back to where the speedo is right, 15/49 would be pretty close with the increase in tire diameter.
Old 06-25-2013, 07:57 AM   #1986
jdrocks OP
Gravel Runner
Oddometer: 4,582
i just put all those miles on the Versys spec motor, the one that was factory tuned to produce maximum torque at lower RPM in a moto that the designers thought might be used differently than the sportbike with the similar motor.
my conclusion: big mistake. while the Versys motor is completely capable of pushing that bike down the road as tuned, i don't see a big rush to duplicate that performance.
most, but not all, of these ER6/Versys builds are set up differently, so in my case, when i say stock gearing, it's the OEM gearing with the OEM 17" rear wheel size. 80 cruise is still 6000RPM, and the gearing is still good for the gravel i would typically run. i was reminded of another reason for not using lower gearing just last week, fuel economy. i would have been parked on the side, out of fuel, at least twice. yes, the fuel stops were that far apart, and no, i wasn't carrying extra fuel at the time. that fuel can on the back was empty.
bone stock cop motor, no aftermarket tuners either. that's the recipe that has taken me out there and brought me back.
Old 06-25-2013, 08:23 AM   #1987
4play
Next?
4play's Avatar
Oddometer: 2,620
Good points.
Old 07-10-2013, 02:02 AM   #1988
nononsense4857
Oddometer: 45
It has been close to a year i have been to this place.
After this there have been three instances of 650s trying to make a trip and returning mid way on the back of trucks due to "radiator fan failure".
All three are separate instances.
JD,
In some of your pics, your ride is neck deep in running water.
Have you given thought to this and put something in place as a safe guard for the radiator fan?
nononsense4857 is offline   Reply With Quote
Old 07-10-2013, 04:07 AM   #1989
jdrocks OP
Gravel Runner
Oddometer: 4,582
great photo, where are you riding?
i haven't seen those reports on radiator fan failure in the field. getting the fan wet certainly doesn't hurt it.
the Versys comes with the 40mm larger radiator, compared to the early year ER6, and it's an advantage to have it. Engine Ice or similar could be used too, especially if you're on a slow road in hot weather.
i also think some of the radiator guards in use don't permit enough air flow, and without a stand off mounting system, the radiator and fan can't be kept clean easily. fine silty mud coming through the radiator can jam the fan.
get some full syn oil in that motor too, like M1 15-50, it helps.
seeing the temp light come on doesn't mean it's cooked, it just means some action needs to be taken, usually finding some water and flushing the core is the fix.
Old 07-11-2013, 12:04 AM   #1990
nononsense4857
Oddometer: 45
This is the northern most part of India - Ladakh. This area borders China in the east and Pakistan west side.
The service center made the radiator fan swap free of charge. They attributed the failure to the fan taking a hit from a stone, or some foreign object getting stuck within and causing enough damage before being thrown off or falling down. The fuse was perfectly ok in all the cases - thus taking out electrical defects as a cause.
Once the fan failed it was a no go because most of the destinations have a treacherous route usually involving just the first two gears and a rare third gear stretch. So even with freezing temperatures outside, the temp light used to start off as soon as the journey got underway.
Getting things changed under warranty is definitely heart warming. But the pain of getting the bike prepped to your liking and then see this happen is really frustrating. Adding fuel to fire, my friend's bike took a bad beating during the transportation back to civilization.
Right now it appears that the best way to mitigate this problem is to have a spare fan and the experience to do the fan swap.
JD and the rest of the 650 riders,
Can you check if there is any factory protection for the fan? Some forums say that there is some sort of mesh protecting it from the rear side. Some clarity regarding this would be very welcome.
Old 07-11-2013, 04:01 AM   #1991
jdrocks OP
Gravel Runner
Oddometer: 4,582
you got the bike prepped, now you're the adventurer dude, good job. i don't know of a fan protection kit, but i doubt you need one. i would mark down that stone in the fan shroud as bad luck. as i said, you do need to keep checking the radiator core for mud, a clogged core will cause the temp light to come on faster than a bad fan. if mud gets into the fan assembly, it will not operate.
safe travels on your trips.
Old 07-12-2013, 08:16 PM   #1992
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,689
Indeed, too bad to miss you, JD.
Speaking of overheating problems, my wife's '09 Versys had the radiator cap go bad just before Osoyus, the Canadian border crossing in Eastern Washington. The internets to the rescue, found a part number for an automotive replacement available at NAPA.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 07-13-2013, 05:05 AM   #1993
jdrocks OP
Gravel Runner
Oddometer: 4,582
yeah, i missed some riders at D2D, but i needed to get down the road. i'll catch up with you somewhere out there, that's always the plan.
i hadn't thought about carrying a spare radiator cap, i have an extra or two in the shop. my radiator problems have all been mud clogged cores, nearly unavoidable on long runs over muddy roads. if you've used a standoff guard, mud can be carefully removed from the face of the core, then flushed with whatever water is available...ditch water, for instance.
Old 08-03-2013, 05:23 PM   #1994
4play
Next?
4play's Avatar
Oddometer: 2,620
My temp light came on today on a long but fairly mild climb. It was in the high 90's outside but something seemed off. I went ahead & topped the hill & down the other side thinking it would cool quickly & the light stayed on. I shut it down & looked things over it all looked good, no fluid loss> I fired it back up, light off for now went a few miles & it came back on the FI light came on as well. I remembered reading about this & sure enough there was a small pebble stuck in the fan. I dislodged the pebble, replaced the blown fuse & rode 200 more miles today. I wasn't riding in anyone's roost, so I'm assuming it came from my front tire & over the top of the radiator.
Old 08-04-2013, 04:49 AM   #1995
jdrocks OP
Gravel Runner
Oddometer: 4,582
My temp light came on today on a long but fairly mild climb...
that makes two jammed fan housings, but with completely different front ends. our Indian friend is 17"/low fender, you're 21"/high fender, and only the event in common. i've run both 17"/low fender and 19"/low fender over 12K plus miles on gravel, no fan problems. i like the low fender because it does a better job of keeping the crap off the bike, but then again, maybe i've been lucky.
i'm working on a pass from the XO and if it comes through, the V649 is hoppin' the border again.
Times are GMT -7.   It's 02:27 AM.
