Old 08-21-2013, 10:10 PM   #2026
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,734
Originally Posted by jdrocks View Post
so what makes you think that the Ruckus can't out run the 800.
Well, I'm slower than snails, so it might have a chance.
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 08-22-2013, 09:35 AM   #2027
jdrocks OP
Gravel Runner
Oddometer: 4,523
Originally Posted by marguyo View Post
i put 100 can on ice...
that's a start anyway.
jdrocks is online now   Reply With Quote
Old 08-22-2013, 09:37 AM   #2028
jdrocks OP
Gravel Runner
Oddometer: 4,523
Originally Posted by Lonestar2112 View Post
Jd, you head west I'lll head east. Trade you a frankenbike (650L for Sasquatch) for a rat bike.
PM the Clown for a ride report anytime after Friday.
Old 08-22-2013, 09:39 AM   #2029
jdrocks OP
Gravel Runner
Oddometer: 4,523
it's the bike, not the rider...built a rat.
Old 08-30-2013, 07:19 AM   #2030
kilroy1
was here!
kilroy1's Avatar
Oddometer: 206
Hey JD got a question for you
Long time reader of your builds. It is neat to see what can be done with the Versys platform. I have a quick question for you and your experience with them.
My 09 Versys killed its stator, r/r, and battery a while back and I am putting the parts together to rebuild it. Looking at installing the Compu-fire r/r instead of the OEM stlye r/r. Any knowledge of this system or opinions on doing this mod? I have read the Versys forum stuff on the subject just looking for other opinions as well. The cost is more for the Compu-fire compared to an OEM stlye from Rick's just wondering if it is worth it.
Thanks,
Kilroy
09 650 Versys (The fast Green one!)
No matter how bad it gets just smile, because everyday above ground is a good one.
kilroy1 is offline   Reply With Quote
Old 08-30-2013, 10:23 AM   #2031
yokesman
Oddometer: 514
kilroy,there has been much research done regarding the electrical problems you went through,poor ground connections have been a common occurance.
clean any paint off any electrical components at the attachment screws,use a star lock washer to add grounding effectivity. keep them clean and tight. this is common in the world of bikes.
yokesman is offline   Reply With Quote
Old 08-30-2013, 02:04 PM   #2032
jdrocks OP
Gravel Runner
Oddometer: 4,523
Thanks,
Kilroy
nope, don't see the point of going after market when the OEM parts are available dirt cheap. the stator failure on the ptwin is documented, but it's such a low incident rate that it almost comes down to bad luck. remember, the Versys uses the same parts as the ER6, EX650, Ninja 650 and that's a lot of bikes out there on the road worldwide.
at least it's not a BMW 650 stator at a cost of $1100 plus related parts and special tools to R&R.
it's an easy fix. order the 2 SS dowels when you order a new gasket for the cover, 15cents each, cheap insurance. use RTV in clear, with 3M adhesive remover sprayed on paper towels to remove excess when the cover is in place. don't spray 3M directly on the part. when done, it won't look like anyone has been in there.
jdrocks screwed with this post 08-30-2013 at 02:15 PM
Old 08-30-2013, 02:11 PM   #2033
jdrocks OP
Gravel Runner
Oddometer: 4,523
Originally Posted by yokesman View Post
kilroy,there has been much research done regarding the electrical problems you went through...
true, but the electrical on these bikes is reliable overall. of course, it helps if the bike is checked front to back for chafe and routing, all the connections pulled apart and greased, switches lubed, and so on. a good rainy day job, that's what i do.
Old 08-30-2013, 02:24 PM   #2034
yokesman
Oddometer: 514
common problem no matter the brand,single ground to the vr.
Old 09-03-2013, 06:02 AM   #2035
kilroy1
was here!
kilroy1's Avatar
Oddometer: 206
Thanks JD.
I aggree with your thoughts on this. I was just making sure there is not a better mousetrap out there now. I figured with the amount of miles you have on these bikes that you would be a good resource for some info on it. I have a Rick's stator coming for it now and I am going to have the old one rewound as a spare.
Good luck on the new bike, I look forward to see what you make out of it.
Thanks,
Kilroy
Old 09-03-2013, 12:41 PM   #2036
jdrocks OP
Gravel Runner
Oddometer: 4,523
the V649HP was for sale here, but...
jdrocks screwed with this post 09-27-2013 at 02:34 PM
Old 09-04-2013, 05:37 AM   #2037
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,734
You are getting another one, right?
BTW, been busy in my shop.
In case you missed the mods; ADVmonster lights, Fuzeblock, Pivot Pegz, Wolfman racks, and Scotts damper.
David
Old 09-04-2013, 06:05 AM   #2038
jdrocks OP
Gravel Runner
Oddometer: 4,523
David
very nice. so, after reading the Farmer's Almanac, you decided to spend the winter in Baja?
Old 09-04-2013, 09:50 PM   #2039
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,734
Not really, Copper Canyon would be more tempting. If you bring your next rat out here around March, you could make it even more tempting.
Old 09-05-2013, 06:01 AM   #2040
jdrocks OP
Gravel Runner
Oddometer: 4,523
no riding in March in Montana, i'd have to meet you and the trailer queen 800 at the border.
Times are GMT -7.   It's 04:43 PM.
