Old 01-10-2011, 03:48 AM   #211
jdrocks OP
Gravel Runner
Oddometer: 4,428
Originally Posted by siyeh View Post
If you mean Hyder? Yes, he will make it there easy. I hear there is good pizza there,,,,
nice pizza, but i was wondering if that 1800 could get across to your hangout in chicken, a little less upscale. more like a cage match with alcohol served.
jdrocks is offline   Reply With Quote
Old 01-10-2011, 03:56 AM   #212
jdrocks OP
Gravel Runner
Oddometer: 4,428
649hp
now i understand how these bikes get to 400# so easily. the motor weighs about the same as the equivalent volume of concrete. it's a handful moving that thing around.
Old 01-10-2011, 03:19 PM   #213
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,629
Originally Posted by jdrocks View Post
but i was wondering if that 1800 could get across to your hangout in chicken.
Oh Chicken. Yes of course we will make The Chicken Saloon. After D2D. . Chicken should be on every long rider agenda,,,,,
siyeh is offline   Reply With Quote
Old 01-10-2011, 06:01 PM   #214
jdrocks OP
Gravel Runner
Oddometer: 4,428
i decided to back up for a minute, clean up the harness and components, and get everything back in position before the motor gets mounted. there's all kinds of tight spots to make connections and it's easier to start without the motor in the way.
other than the routing, there shouldn't be a problem making up the connections, every single one is different.
Old 01-11-2011, 01:40 PM   #215
jdrocks OP
Gravel Runner
Oddometer: 4,428
i was able to round up a helper for a few minutes, so i changed direction again and stuck the motor in. much easier with an extra hand.
i'm not sure if it's the short wheel base or what, but these rat bikes start looking like snorty little SOBs, big chunk of motor wrapped in a little bit of tube...but i like it!
jdrocks screwed with this post 01-11-2011 at 03:29 PM
Old 01-11-2011, 05:17 PM   #216
ktmklx
ktmklx's Avatar
Oddometer: 694
Looks like your oil pan is missing something.
ktmklx is offline   Reply With Quote
Old 01-11-2011, 06:09 PM   #217
jdrocks OP
Gravel Runner
Oddometer: 4,428
your xray vision ain't workin'. there's oil in there where it belongs.
it's you single track guys that have to worry about what's missing.
Old 01-11-2011, 06:12 PM   #218
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
photochop
Old 01-11-2011, 07:00 PM   #219
old2wheeler
Former nb
old2wheeler's Avatar
Location: La Veta, CO except for the wind, it'd be heaven
Oddometer: 720
Rat bike, smat bike!
That is just plain beautiful!! It is gonna be a real winner!
Roderick (Rod) {AKA o2w} House
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
old2wheeler is offline   Reply With Quote
Old 01-11-2011, 07:24 PM   #220
Truckman
The almighty Beavis
Truckman's Avatar
Oddometer: 147
Laugh
That's nice that's neet but it's still not a KLX so keep tryin guys!!!! No matter what you all do it's just still not as thrifty! : ) and the smallbore part of it is nothing lmfao .........gear up, saddle up , go ride ......... Smile
why do kamikaze pilots wear helmets????
Truckman is offline   Reply With Quote
Old 01-11-2011, 08:20 PM   #221
ktmklx
ktmklx's Avatar
Oddometer: 694
So you're not gonna tell us how you did it?
Old 01-12-2011, 03:38 AM   #222
jdrocks OP
Gravel Runner
Oddometer: 4,428
thanks. stay tuned.
Old 01-12-2011, 03:54 AM   #223
jdrocks OP
Gravel Runner
Oddometer: 4,428
that KLX is a real nice bike, but right off the bat i can think of a reason why i don't need one. there's another bike parked ten feet from the rat that's called a WR250R.
Old 01-12-2011, 03:59 AM   #224
jdrocks OP
Gravel Runner
Oddometer: 4,428
nothing to tell. my bikes don't require the surgical enhancements you guys are planning. this rat is a gravel runner, not a stump jumper.
Old 01-12-2011, 04:09 AM   #225
jdrocks OP
Gravel Runner
Oddometer: 4,428
time to try a new shock, so i picked up a shock from a 2008 R1. this is a fully adjustable reservoir style shock, the right length, and can be found really cheap. the bushing sleeves need to be bored to 12mm, and it needs a heavier spring, but still very inexpensive for a semi custom shock. i'm looking for a spring with a 16kg/mm winding, same as the spring on the Versys shock.
Times are GMT -7.   It's 02:46 AM.
