Old 01-14-2011, 08:24 PM   #241
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,049
That was my first ride after the suspension was installed. Figured I'd test it
It passed
Bike building is on hold for a while.
Old 01-15-2011, 07:51 AM   #242
jdrocks OP
Gravel Runner
Oddometer: 4,327
you better get movin'. departure date will be on ya before you know it.
jdrocks is offline   Reply With Quote
Old 01-15-2011, 09:32 AM   #243
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,049
Proally gonna end up with stock suspenders and wheels with some gravel protection on the girls bikes. They don't care to follow me off road anyhow.
Old 01-15-2011, 05:05 PM   #244
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,697
JD, I sure do enjoy reading about your motorcycle build up projects.
Well, I'm starting my adventure. Not quite as ambitious as JD's, but a first step for me.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 01-15-2011, 06:02 PM   #245
jdrocks OP
Gravel Runner
Oddometer: 4,327
David
great way to spend a montana winter, and fun. so you're going to make what into something? nice set of forks, what are they from?
...then the beast world will need some pix.
Old 01-15-2011, 06:05 PM   #246
jdrocks OP
Gravel Runner
Oddometer: 4,327
they still need to be able to ride gravel, those construction zones can be brutal sometimes.
Old 01-15-2011, 07:16 PM   #247
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,697
Forks from the F800GS. I'm sending them off. At least they should have pretty stickers on them when they come back. We'll see if the guts live up to the sales hype.
David
Old 01-16-2011, 06:47 AM   #248
jdrocks OP
Gravel Runner
Oddometer: 4,327
damn, just when i change the whole suspension on the rat to help me keep up with the big guys, they go out and up the ante again. now if you show me around montana, you'll be over the hill and five miles ahead.
those forks need help. where are they going to get the treatment?
from my 2010 ride report up near the labrador border, there was an 800GS rider ahead of me that went down hard in one of the big soft spots in the road surface i call sand holes. they could be 5M long or 300M long. when the bike suddenly hit that sand at speed, those soft forks bottomed and the bike was down. bike and rider patched back together and continued on. bike had $5000 plus damage.
good that you're getting them tricked.
Old 01-16-2011, 07:00 AM   #249
jdrocks OP
Gravel Runner
Oddometer: 4,327
the 650R wiring harness is longer than the Versys harness in the subframe area because the CPU connections face the rear, while on the Versys the same connections face the right side. i didn't feel like cutting and shortening the whole damn harness, so it took a little jiggling around to get everything in there so that the fender liner fit.
i stuck more of the trim pieces on to see how it was shaping up, and i also wanted to get it off the stand to check the seat height. tall, almost 36", but i can get my toes down at least, no flatfoot.
this is turning out to be a lot of bike for the budget money involved, my most inexpensive build so far.
Old 01-16-2011, 07:23 AM   #250
DanVFR
Continent Crusher
DanVFR's Avatar
Oddometer: 156
Very smart!
Was interested in how you'd compensate for the extra rake but it's not as bad as exspected!
Aprilia RSV Mille
Ducati 749s - sold
Honda VFR 800 VTEC - sold
DanVFR is offline   Reply With Quote
Old 01-16-2011, 08:14 AM   #251
jdrocks OP
Gravel Runner
Oddometer: 4,327
Originally Posted by DanVFR View Post
Very smart!
i should have taken some better photos when the stock parts bike was parked next to the rat. both bikes have the 650R swingarm and are on stands the same height. if you look at the forks in the photo, you can see how much the front end has changed. hard to tell in the photo, but the main frame tube on the rat is at least 5" above the same tube on the 650R.
Old 01-16-2011, 08:18 AM   #252
freewheeler
Oddometer: 110
JD ... Did you check the fork travel yet ... better do it before you get to far along ... just unscrew the fork caps and let the forks collapse ... then adjust the tubes accordingly ... based on how I have mine set on my DRZ ... I have the feeling that you will have to raise them a little ...
freewheeler is offline   Reply With Quote
Old 01-16-2011, 08:27 AM   #253
jdrocks OP
Gravel Runner
Oddometer: 4,327
you make a good point. i'm waiting until i get my new R1 shock back from the spring guys to set the forks in the clamps. that shock is just slighly longer and will raise the rear a little. i haven't even bothered to tighten the clamps yet.
hope to have a shock at the end of the week.
Old 01-16-2011, 08:34 AM   #254
ktmklx
ktmklx's Avatar
Oddometer: 689
JD, looking pretty nasty! What handle bar risers are you using? What handle bars do you have on it?
ktmklx is offline   Reply With Quote
Old 01-16-2011, 08:45 AM   #255
freewheeler
Oddometer: 110
JD ... Would you do me a favor .... Measure the wheel base on the Versys ... and the Ninja ... I'm curious as to how much you gained ...
Times are GMT -7.   It's 12:05 AM.
