Old 01-24-2011, 01:08 PM   #361
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,350
Originally Posted by jdrocks View Post
Impressive.
Laconic is offline   Reply With Quote
Old 01-24-2011, 02:35 PM   #362
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by buff36 View Post
Dude you need to keep a parts list and sell it to others that want to do the build.
naw, it's all in the build thread for anyone interested. coincidental that you mention "parts list", since just this morning i got a PM requesting that exact thing.
wishing you well on the job hunt.
jdrocks is offline   Reply With Quote
Old 01-24-2011, 02:39 PM   #363
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by freewheeler View Post
Just throw a couple 1/4" flat washers between the back fender mounts and the lower triple clamp ... problem solved ...
well, the problem is those are Versys clamps, no mounts at present. i'll dream up something, i'm good at that.
Old 01-24-2011, 02:45 PM   #364
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by johnwesley View Post
When the front lights and fairing is on I think it will look right its just the lack of mass infront of the forks that gives it that long broke beak look
i think you're right on the broke beak. not much of a fairing on this one, it's real naked.
...then a little mad max on the lights.
Old 01-24-2011, 02:50 PM   #365
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by fredgreen View Post
I can't imagine trying to work on a broke down Ducati out in the woods either.
me either, but then i don't want anything to break. riders that haven't been up on those northern road don't understand the price you could end up paying for an unreliable or poorly prepped machine.
PM on the way to ya.
Old 01-24-2011, 02:54 PM   #366
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by 257bob View Post
Impressive.
thanks, i should have taken some "before" photos. what a mess.
Old 01-25-2011, 04:01 AM   #367
freewheeler
Oddometer: 112
Oh Yeah ... I keep thinking you have the DRZ triple clamps installed ... any chance you could marry the bottom DRZ clamp to the Versys top ... that would solve 3 issues ... more clearence for the travel ... provide a fender mount ... no spacers needed for the bottom clamp ... still retain handle bar mount to get above the Versys tank ... what do you think ...
freewheeler is offline   Reply With Quote
Old 01-25-2011, 04:29 AM   #368
jdrocks OP
Gravel Runner
Oddometer: 4,582
i'll work something out with the Versys clamps. others have run a high fender on the Versys, but i think they just drill the bottom clamp, and i want to avoid that. i don't see where the DRZ clamps allow more movement anyway.
i did lower the forks in the clamps 15mm before i tightened them up.
Old 01-25-2011, 04:38 AM   #369
freewheeler
Oddometer: 112
I think the DRZ steering head is longer than the Versys head ... thus the gull wing design ... to make the spacing between the clamps the same ... meaning installing the DRZ lower clamp in the Versys steering head will raise the lower clamp area ... however the stem will stick out the top farther ... I'm sure you get the picture ...
Old 01-25-2011, 05:27 AM   #370
fredgreen
I'm a poseur
fredgreen's Avatar
Oddometer: 741
The pic in post 361 is impressive, looks cleaner than a new bike. I got this dirty KLR.........unfortunately it is -20 and my garage has very limited heating, so no detailing goin on. Can't wait to see this beast completed.
fredgreen is online now   Reply With Quote
Old 01-25-2011, 06:49 PM   #371
jdrocks OP
Gravel Runner
Oddometer: 4,582
here's the picture.
the DRZ uses about 235mm of space in the clamps and 15mm to the bottom of the fender mount. gull wing yes, but the difference doesn't look like much.
the Versys clamps are about 240mm with no fender mount at present. by the time the mount is in place, the overall dimensions will be almost identical.
so the DRZ clamp is really only worth about 5mm, less than a 1/4", with fork interference being the bottom clamp, if there's that much travel.
Old 01-25-2011, 06:53 PM   #372
jdrocks OP
Gravel Runner
Oddometer: 4,582
thanks. ya need to get a wood stove in there and burn up a bunch of spruce like everyone else.
Old 01-25-2011, 07:08 PM   #373
C-Stain
C-Stain's Avatar
Oddometer: 6,661
Spruce, Pine or Hemlock. We lost enough of those in that freak storm in early December. Christ Fred, you can come get some of the stuff bucked up in my front yard!
jdrocks...will you hurry up and make some progress already...I wanna see more pics!
Originally Posted by Mr_Gone View Post
C-Stain is wise.
C-Stain is offline   Reply With Quote
Old 01-25-2011, 07:47 PM   #374
jdrocks OP
Gravel Runner
Oddometer: 4,582
the UPS guy brought me my custom R1 shock this afternoon. man, what a beauty. stock spring on right.
i sent my stock R1 with the OEM spring still mounted over to Cannon Racecraft (http://www.cannonracecraft.com/) after talking by phone with Tony, the shop foreman at Cannon. they hadn't built a spring for this shock previously, and i wanted a spring built to this specific shock, not a generic spring that might need extra collars. Tony wanted the whole shock, so i put it in the mail thursday, a week ago.
i called Cannon at 9am the following monday, and caught up with Tony just as he was opening the box. i wanted a 16kg/mm or 900lb/in spring built, and Tony replied "let me check a few things and i'll call you back".
at exactly 11am, only two hours later, Tony is back on the phone "your spring is done and i sent it over for powdercoating. tests at 16.1kg/mm, say 900lbs/in". it took two days waiting in line until they powdercoated a batch in gloss black, but the elapsed time in the Cannon shop for this custom spring was only three days. talk about smokin' service from Cannon Racecraft, thanks Tony.
Tony kept the spec sheet for this spring, so if you want a custom R1 spring you can have it built to just about any rate and mailed directly to you. just call Cannon, and ask for Tony, he'll fix ya up.
the spring cost $109, powdercoated in your choice of color.
i still need to bore the bushings, but exclusive of postage, this custom shock has cost a whopping $134. not too bad.
i thought i better add a post script: the R1 shock i am using is a 2008 model. there are some differences in the R1 shock over the model years, and i am not 100% sure all the stock springs are the same. verify first, or you can send Tony the whole shock, as i did.
jdrocks screwed with this post 01-26-2011 at 04:36 AM
Old 01-26-2011, 12:00 AM   #375
SamM
Jeep Overlander
Oddometer: 1,471
jdrocks,
That's good information about Cannon Racecraft. I have two Yamaha R1 shocks like yours that I bought for a car project. My plan was to try using them on my 1964 Lotus Seven replica, as a low cost alternative to the expensive car shocks out there.
Thanks for posting their info.
SamM
SamM is offline   Reply With Quote
Times are GMT -7.   It's 10:24 AM.
