Old 01-26-2011, 03:55 AM   #376
freewheeler
Oddometer: 75
Originally Posted by jdrocks View Post
The DRZ clamp is really only worth about 5mm, less than a 1/4", with fork interference being the bottom clamp, if there's that much travel.
Thanks for taking the time to check it out ... I'm so inquisitive because I have an extra set of DRZ forks w/clamps sitting in my garage ... they were going to be for another project ... however now I think they will be applied to a ninja/versys build ... I still like the Idea of having the DRZ bottom clamp married to the Versys top ... are the stem sizes the same ...?
freewheeler is offline   Reply With Quote
Old 01-26-2011, 04:21 AM   #377
jdrocks OP
Gravel Runner
Oddometer: 2,780
Originally Posted by C-Stain View Post
jdrocks...will you hurry up and make some progress already...I wanna see more pics!
geez, the ADV nation never sleeps.
maybe i can bore the bushings sometime today and get that shock on there.
got a cheap used taillight sent in from the UK too. now the build has some international flavor built in.
jdrocks is online now   Reply With Quote
Old 01-26-2011, 04:43 AM   #378
jdrocks OP
Gravel Runner
Oddometer: 2,780
Originally Posted by SamM View Post
That's good information about Cannon Racecraft.
no problem. Cannon Racecraft people are great to do business with. Tony is top notch, not put off in the least by my request for a custom R1 spring, and then had it done in 2 hours.
Old 01-26-2011, 05:04 AM   #379
jdrocks OP
Gravel Runner
Oddometer: 2,780
happy to take a look at it for ya.
i thought about the DRZ clamps, and actually contacted a guy that could do the machine work for about $250, but in the end i stuck with what i had. as is usually the case, you would swap the Versys/650R stem to the DRZ clamps. the stem lengths are similar, but in this case it doesn't matter as much because there's plenty of clamping surface on these conventional fork inners. as you know, the DRZ uses a completely different steering bearing arrangement.
by sleeving the Versys clamps, i save the cost, keep the ignition switch in the stock location, and use Versys bar riser.
Old 01-26-2011, 04:22 PM   #380
JBird
Retriever
JBird's Avatar
Oddometer: 635
Couldn't tell from this photo - but do these bushings have a slot or cut down the length to aid in concentric clamping??
JBird
Aprilia Tuono Factory
KTM 950SMR
'02 Suzuki V Strom
'08 Goldwing
'08 CBR1000RR
'98 Golden Retriever
JBird is online now   Reply With Quote
Old 01-26-2011, 04:53 PM   #381
ric678
ric678's Avatar
Oddometer: 853
inspired
JD, I have followed your other builds, all great work I do like the direction of this one the best, I've been inspired to start my own, currently bidding on a 2010 650 with 1500 miles on it...layed down, the right side plastic is all scuffed up, don't need that anyway
Rick
ric678 is offline   Reply With Quote
Old 01-26-2011, 05:23 PM   #382
jdrocks OP
Gravel Runner
Oddometer: 2,780
astute observation. the sleeves are upside down in the photo. yes there is a slot, but it's turned away from the camera. the sleeves were set in the fork clamp with cylinder sleeve adhesive, and the slot lined up with the slot in the clamp. the lip at the top of the sleeve aligns everything at the top of the clamp and trims it out nice and neat.
Old 01-26-2011, 05:30 PM   #383
jdrocks OP
Gravel Runner
Oddometer: 2,780
Rick
thanks. the bikes are sure fun to build, and can run from mild to wild. don't be in a hurry to throw anything away. parts can have $ value to someone even if scratched.
hope you get your project bike, time to start building.
Old 01-26-2011, 06:59 PM   #384
jdrocks OP
Gravel Runner
Oddometer: 2,780
the weather was so bad around here this afternoon that i couldn't open the garage door without rain and then snow pouring in, so i put off starting the bike.
the needle bearing bushing for the shock was out getting bored, couldn't install that either.
that left the lights. the forks are different, but the Versys fork clamps are the same as last year, so that means that the centers are the same. it gets better yet. the Versys Showa usd outers were 50mm, and the DRZ inners are 49mm, which means that my 50mm ProTek fork tube clamps will work on the new conventional forks.
the second generation light and instrument mount from 2010 came back in good shape, as opposed to the first generation mount in 2009 which came back...well, it came back looking like it got hit by a truck. let's swap in the 2010 mount, see how it works. i swear on a big stack of them bibles that i really did plan all this in advance.
looks like this...
and then this...
Old 01-26-2011, 07:11 PM   #385
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,306
Send a message via AIM to johnwesley
Talking
you really gotta stop this, its making me want to change projects
johnwesley is offline   Reply With Quote
Old 01-26-2011, 08:08 PM   #386
KI6HNB
KI6HNB's Avatar
Oddometer: 141
Send a message via MSN to KI6HNB
How much travel do you think you are going to get out of the rear with the new shock and custom spring?
'09 DRZ400S
'08 KLX110 (now 177cc) pitbike
KI6HNB is offline   Reply With Quote
Old 01-26-2011, 08:24 PM   #387
jdrocks OP
Gravel Runner
Oddometer: 2,780
don't change projects, just add another one.
Old 01-26-2011, 08:34 PM   #388
jdrocks OP
Gravel Runner
Oddometer: 2,780
the R1 is the same length as the Versys shock, neither would be considered long travel. on the 650R framed bikes, the 150/70 rear would occasionally hit the fender liner when running hard. the subframe and liner are both different on the Versys, but there doesn't look to be any more room to move. the next step would be a longer shock or a modified lower mount.
Old 01-27-2011, 03:50 AM   #389
jdrocks OP
Gravel Runner
Oddometer: 2,780
when i didn't have a 3 axis CNC router to create a plug mold for the little fiberglass sport or rally fairing that i wanted, i used the results of someone else's mold making ability to create the compound curves and details i wanted.
pretty easy, i fished a Saturn bumper cover out the the ditch along the highway and cut off the shapes that i wanted.
the curves on these things are mostly symmetrical on each side of the centerline, so you cut the left and right pieces and then hot glue them together to get the plug mold. it's just plastic, easy to cut and trim, and the process moves quickly. i left plenty on the plug mold so that the piece could be shaped and fitted later.
the female mold was made, and then the little fairing done.
i used this fairing on the 2010 bike, all it is really meant to do is protect the instrument cluster and whatever else is hiding behind there. it looked pretty good on the old bike, so here it is again. i might cut it down some, haven't decided, and it gets repainted the same as the tank.
this...
and this...
Old 01-27-2011, 05:52 AM   #390
Lesharoturbo
Nerdly Adventurer
Lesharoturbo's Avatar
Oddometer: 1,034
Thanks for the write up of your fairing fabrication. I have been wanting to do a similar style design for my thumper, but couldn't figure our how to make a good symmetrical mold. Now to look for a dithec bumper...
Individuality is best expressed individually; you are conforming in your non-conformity.
Lesharoturbo is offline   Reply With Quote
Times are GMT -7.   It's 09:50 AM.
