Old 02-01-2011, 06:27 AM   #421
fredgreen
I'm a poseur
fredgreen's Avatar
Oddometer: 741
I think the Blue Gel is all that keeps my KLR together....Every fastener I remove gets it, because as everybody knows, KLR's don't drive anywhere, the move by vibrating through the air molecules.
fredgreen is offline   Reply With Quote
Old 02-01-2011, 10:47 AM   #422
jdrocks OP
Gravel Runner
Oddometer: 4,582
KLRs vibrate? can't be that bad, even though they're described as a washing machine on wheels.
the only bolts i neglected to loctite when up there last year were the two holding on the chain guard. lost one bolt and the other was a turn from falling out coming down from Quebec. reset both in loctite, but then the entire chain guard sheared off somewhere in Labrador, except for the little strip under the bolts still attached to the swingarm.
jdrocks is online now   Reply With Quote
Old 02-01-2011, 12:21 PM   #423
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Originally Posted by jdrocks View Post
thanks. i could have spokes i guess, but i don't want 'em for this bike. cast wheels have survived 6000 miles of gravel road in just the last two seasons with no problems. good enough test for me. besides, i want tubeless.
I hope I didn't jinx you. May your wheels stay straight and true.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 02-01-2011, 01:02 PM   #424
jdrocks OP
Gravel Runner
Oddometer: 4,582
hardly, the question has been posed a hundred times, maybe more.
all the rest of the ninja builders are using spokes, not me, don't need or want them for the way i run the bike.
Old 02-01-2011, 01:34 PM   #425
BuffWv
BuffWv's Avatar
Oddometer: 2,263
Wish I could find a set of 17s cheap enough I have found that 16s in a rough tread pattern is hard to come by.
What seemed fast on a KLR is slow on a Versys
BuffWv is offline   Reply With Quote
Old 02-01-2011, 05:14 PM   #426
jdrocks OP
Gravel Runner
Oddometer: 4,582
those 16s won't do it. you looking for the 250r 17" cast or some in spokes?
Old 02-01-2011, 05:20 PM   #427
BuffWv
BuffWv's Avatar
Oddometer: 2,263
I found some 17s for $160 shipped
Old 02-01-2011, 07:37 PM   #428
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,570
Just read through this thread..WoW Great work! I'm a Zuki guy traditionally but damn you make these budget Ninjas look great.
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 02-02-2011, 03:02 AM   #429
jdrocks OP
Gravel Runner
Oddometer: 4,582
thanks. hey, got Suzuki wheels and forks on there at least.
Old 02-02-2011, 03:34 AM   #430
fredgreen
I'm a poseur
fredgreen's Avatar
Oddometer: 741
Geez Dave, you're up too bloody early.......
Old 02-02-2011, 04:15 AM   #431
jdrocks OP
Gravel Runner
Oddometer: 4,582
not for me, that's only 6AM eastern, don't want the day to start without me.
Old 02-02-2011, 04:22 AM   #432
bikerfish
flyfishandride
Oddometer: 1,701
all this talk about KLR vibration, you guys must have all rode goldwings! I've got a 99, and yes, it thumps a little, I'd say it's actually pretty smooth for a big single.
you guys need to ride some old brit bikes or sportsters, you'll think the KLR is velvet!!
bikerfish is online now   Reply With Quote
Old 02-02-2011, 05:07 AM   #433
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by bikerfish View Post
...you guys need to ride some old brit bikes or sportsters, you'll think the KLR is velvet!!
rode all those back in the day, Triumph, BSA, Norton, HD...but that still doesn't make the KLR smooth, not that it bothers me at all. the KLR doesn't have a puddle of oil under it where ever it's parked at least.
the Kawasaki 649 ptwin, now there's a smooth runnin' motor.
Old 02-02-2011, 05:40 AM   #434
SamM
Jeep Overlander
Oddometer: 1,471
My 2008 KLR650 shook noticably less than my 2005 KTM 950 Adv did. I say shook, because it's now getting a 2008 Versys engine. That will all be history soon. The 950 was horrible. I couldn't believe that a 950 V-twin would shake like that. It wasn't as bad as the Buells, that I owned in the past but it was bad.
No critism here, just asking! Why did you go with the high handlebars? Do you plan to drop the footpegs any? I dropped the footpegs 2" on my KLR because the stock riding position was somewhat cramped for my 32" inseam. Even after raising the seat up an 1" or so. Do you plan to raise the seat on your bike any?
The build is looking great jd. For your planned use, I think this is going to be a great bike. I can see many guys here going down this path. The R1 shock is a great idea too. And a very inexpensive option. Very cool! I may give Cannon Racecraft a call today.
If anyone needs a red KLR fender like your's, I have one! Cheap!
SamM
SamM is offline   Reply With Quote
Old 02-02-2011, 06:05 AM   #435
fredgreen
I'm a poseur
fredgreen's Avatar
Oddometer: 741
As a matter of fact I did ride a Goldwing for years. An 81 1100, sold her with a hundred thousand miles, probably still running..In all truthfulness, the KLR doesn't vibrate that much, but is notorious for loosening off bolts, not sure if it is the made in Malayasia bikes or all of them. I would think JD's bike would be much smoother than any single cylinder bike though and damn near ideal for the kind of riding that he does.
Times are GMT -7.   It's 05:27 PM.
