Old 02-12-2011, 07:01 PM   #511
BuffWv
BuffWv's Avatar
Oddometer: 2,240
Found a rear shock off of an older 250 ninja, its about 2 inches longer. It set the rear of the bike up 6 inches higher. Its amazing how the dog bones work on the rear of these bikes, 1/4 in makes a big difference
What seemed fast on a KLR is slow on a Versys
BuffWv is offline   Reply With Quote
Old 02-12-2011, 09:56 PM   #512
jdrocks OP
Gravel Runner
Oddometer: 4,324
Originally Posted by fredgreen View Post
How soon until your beast is roadworthy....looks like chain and brakes are all that's stopping it from rolling.
more than that, still a long list to complete.
jdrocks is offline   Reply With Quote
Old 02-12-2011, 10:04 PM   #513
jdrocks OP
Gravel Runner
Oddometer: 4,324
the direct connected shock arrangement on the Versys/650R is similar, but the relationship easier to see with the swingarm pivot, shock mount, and axle all lined up on top.
Old 02-12-2011, 10:14 PM   #514
jdrocks OP
Gravel Runner
Oddometer: 4,324
i wanted to build a mold for the upper fender, but first i needed to slim that 2008 KLR thing down a little for both design and fitment considerations. this was a used fender, and i didn't feel bad about cutting it up.
2" should do it, so it was marked for the cuts and run through the saw.
the halves were hot glued back together with some backing, and then all the holes and so on will be filled and smoothed so the part is ready for glass. easy way to make a custom fender, and it should fit the bike well.
Old 02-13-2011, 02:08 PM   #515
fredgreen
Is it Spring yet?
fredgreen's Avatar
Oddometer: 667
If you're interested in maiking that fender out of kevlar instead of glass, shoot me a line, I have a bunch of kevlar cloth here waiting to be made into something. It would be much stronger that glass, it is a little hard on scissors, but not bad to work with for somethiing being molded like a fairing or fender.-Fred
fredgreen is offline   Reply With Quote
Old 02-13-2011, 06:03 PM   #516
jdrocks OP
Gravel Runner
Oddometer: 4,324
If you're interested in maiking that fender out of kevlar instead of glass, shoot me a line...
thanks fred, but already started in fiberglass. real easy, besides, that kevlar stuff will make the rat way too fast.
Old 02-13-2011, 06:18 PM   #517
jdrocks OP
Gravel Runner
Oddometer: 4,324
the radiator guard is very light and it mounts on just two tabs on the ends of the radiator. i don't want it rocking back and forth, so i add some urethane bumpers to the back. the bumpers are trimmed to fit, then set in JB Weld. i wanted them on there before the guard got painted.
Old 02-13-2011, 06:34 PM   #518
jdrocks OP
Gravel Runner
Oddometer: 4,324
the parts that were fitted and need a coat of black paint were pulled back off. sandblast or otherwise prep, primer, then topcoats. fussy work, but there's no way around it so i jumped in.
so that's how i spent the afternoon. now i've got a big pile of black parts, so y'all be sure to tell me how good they look from, say, at least 20'.
Old 02-13-2011, 09:08 PM   #519
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,689
No problem. Glad your back at it, I was worried the wolves of winter had carried you off. - David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 02-13-2011, 09:33 PM   #520
ktmklx
ktmklx's Avatar
Oddometer: 689
I have a feeling that is going to look pretty good.
ktmklx is offline   Reply With Quote
Old 02-14-2011, 04:17 AM   #521
jdrocks OP
Gravel Runner
Oddometer: 4,324
no wolves of winter yesterday, 65F.
local farmer lost 26 head of cattle over two days last week to what he said were coyotes. nobody saw them, and most of the animals were full grown, not calves. no coyote expert, but it looks more like dogs.
Old 02-14-2011, 04:24 AM   #522
jdrocks OP
Gravel Runner
Oddometer: 4,324
hope so.
you did some nice work trimming the ptwin oil pan. i'm not sure why the pan was designed with that drain leg in the first place.
Old 02-14-2011, 01:24 PM   #523
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Oil drain design is so you don't need to remove the fairings to change the oil, at least on the 650r.
Works great but Kawi should of known it was destined to be a dualsport
Old 02-14-2011, 04:49 PM   #524
jdrocks OP
Gravel Runner
Oddometer: 4,324
right side belly fairing has to come off to get to the filter doesn't it? if so, they didn't need that style of drain.
Old 02-14-2011, 06:07 PM   #525
fredgreen
Is it Spring yet?
fredgreen's Avatar
Oddometer: 667
If you drive one of these things
you'll burn oil so fast you won't have to change it, just keep adding it....
Times are GMT -7.   It's 10:12 PM.
