12-16-2010, 06:52 PM
#46 |
Gravel Runner
Oddometer: 2,837
#47 |
wanta be
Well come on bolt something on already.
![]() with the v sub will the seat heigth change ? |
12-16-2010, 06:53 PM
#48 |
Purveyor of Light
Oddometer: 3,711
fix'd
Are you gonna use a bunch of steel on this one? Rode the dirt ninja today after having been off of it for 3 weeks. I've forgotten how light it is and oh my the wheelies .
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
12-16-2010, 07:03 PM
#49 | |
Gravel Runner
Oddometer: 2,837
it will be a tall mofo. if i fall over it will be about the same as getting bucked off a twenty hand horse. might see ya in the yukon, you can check it out. |
12-16-2010, 07:10 PM
#50 |
wanta be
Awesome
![]() not sure what I am taking yet a kawi green tiger or a beat in 08 KLR either way I'll recognize your beast. You'll have to slow down to let me catch up though
12-16-2010, 07:12 PM
#51 |
Gravel Runner
Oddometer: 2,837
there's just nothing much to cut on that frame, sorry. it needs to carry some serious weight way out there, can't have it break in half.
i like steel for any fabbed parts. if you need a repair, you can find someone to weld steel just about anywhere, not so with aluminum. send me some of those fancy lights, i'll do a product review. |
12-16-2010, 07:24 PM
#52 | |
Oddometer: 1,464
Honestly jd, I'm on your side with this. I like what you are doing. Here you go! SamM |
12-16-2010, 07:43 PM
#53 |
Gravel Runner
Oddometer: 2,837
i know that weight can be taken off a stock ninja, versys, or klr.
we're talking about a bare versys frame here. a few ounces of light gauge bracket steel, nothing more. if you think more of this frame can be removed, please point it out. 60# frame, 130# engine...this build is not going to be a light bike. it will be a good gravel runner though...and cheap. |
12-17-2010, 09:48 AM
#54 |
Oddometer: 1,464
It's really hard to see what, is exactly what just looking at the bare frame. Without knowing where everything goes, I would just be guessing. I sent my Versys manual to my builder. I need to get another one. The Versys frame looks like it has a couple of cast sections to it. One at the steering head and another at the back of the subframe. There's no way to remove those. That subframe just looks way overbuilt to me. I know that your not interested in doing this but I would cut off the lower tubes and add my own. Probably won't drop much. Easy to say for a guy letting someone else built his bike. When my bike sees the light of day, people will understand why I went to a professional.
![]() When I dropped the 60+ lbs from my original KLR build, what I did was remove the fairing, tank shrouds and sidepanel bodywork tabs and mounts. The heavy frontend parts were all removed too. Getting rid of the stock bodywork removed more weight than just the tabs but there were a gazillion of them. It did add up! Some of those parts (sidepanels) may go back onto the bike with the new KLE engine but weight won't matter much with this new version. I'd still like to keep it as light as possible. SamM
12-17-2010, 11:57 AM
#55 | |
Gravel Runner
Oddometer: 2,837
when you think about it, for a steel frame that has been proven to survive under very rugged use, it's pretty minimal already. the engine assembly substitutes as the down tubes. other than questioning some of the welds, i don't see anything to change. |
12-17-2010, 04:01 PM
#56 |
Gravel Runner
Oddometer: 2,837
put the frame up on the operating table, stripped all the grommets, harness clips, and miscellaneous parts. preliminary degrease, and then marked the brackets that get cut off. they didn't put much of a paint job on the frame at the factory. anything that was not in direct view looks like it never got a finish coat.
![]() most of the custom parts are done in steel, but these little gems were done in aluminum. if they work i own the design, but if they don't...heck, ain't never seen them things before. amazing what can be turned out for very little $.
12-17-2010, 04:57 PM
#57 |
wanta be
What are they?
12-17-2010, 05:07 PM
#58 |
Gravel Runner
Oddometer: 2,837
12-17-2010, 05:09 PM
#59 |
2x College Dropout
They look like adapter cups of some sort. Are they to mate the Ninja fork to the Versys frame?
12-17-2010, 05:46 PM
#60 | |
Gravel Runner
Oddometer: 2,837
![]() versys usd forks on left, 650R forks on right. both have 41mm inners. you can see the relative size of the clamps. the 41mm 650R clamps allow the direct bolt in of the 08 and up 41mm KLR forks and this has been done, but those 650R clamps sure look small for a sustained offroad pounding. |
