Old 12-18-2010, 05:28 AM   #76
jdrocks OP
Gravel Runner
Oddometer: 4,551
Originally Posted by juames View Post
Carb flanges?
these ptwins are fuel injected.
jdrocks is offline   Reply With Quote
Old 12-18-2010, 05:34 AM   #77
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,533
Right...meant to say intake flange
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 12-18-2010, 05:48 AM   #78
jdrocks OP
Gravel Runner
Oddometer: 4,551
no, motor is bone stock.
hey, these things will be on the bike before too long, or not, in which case they never happened.
Old 12-18-2010, 06:42 AM   #79
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,709
hey mike, whatcha doing straying from orange city to the cheap as dirt rat bike section? maybe you need a lower ride height rat ninja version for your trip to Labrador. here's the old bike below the Churchill River on phase 3 of the trans lab.
agree with you on some of the welding you see on these frames. i could teach my grand daughter to do better in about 15 minutes. maybe less.
Like you, I'm always searching for something more suited (note that I didn't say necessarily better!) both for the ride and my preferences du jour. When I saw the Rat Ninja, the first thing I thought was "Perfect, this will do everything I need and I can make it fit me." Unfortunately, I don't have the tools or the space so I have to watch and learn and if I do get the space (Lord please let the market recover!), I'd definitely try to build one. I don't want a "dirt" bike Dave - I want something that I can run across Labrador or Alaska that is bulletproof, strong enough and comfortable enough that I can enjoy the trip without a constant adrenalin rush. I'm "In" for the duration and anything else you put together. Who knows, maybe some day I'll have a decent place to build one.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 12-18-2010, 08:11 AM   #80
jdrocks OP
Gravel Runner
Oddometer: 4,551
yep, these bikes can be built to fit ya, no problem. they can also be built as more of a single track bike, but that's not what mine are. here's sheila p****s' bike in front of my last one-
it's like a 3/4 size version of mine built standard ride height to fit her. before you say "chick's bike", this thing is a damn rocket ship with her on board, very fast and light. the fabrication work is outstanding. there are some additional things i would do for northern travel, but it gives you an idea of the different ways these bikes can be built.
you must know mike and sheila and could arrange to see it if interested.
jdrocks screwed with this post 12-18-2010 at 11:26 AM
Old 12-18-2010, 08:25 AM   #81
BSR
Happy at the back
BSR's Avatar
Oddometer: 232
my last one-
Do you have a build thread for the last one? Looks ace.
We have the Versys here ... ah, the road bike is the ER6N.
Sure as hell wont find one for what you're spending.
Please continue, can't wait to see the result.
BSR screwed with this post 12-18-2010 at 08:38 AM
BSR is offline   Reply With Quote
Old 12-18-2010, 08:46 AM   #82
jdrocks OP
Gravel Runner
Oddometer: 4,551
We have the Versys here but i'm damned if i've ever seen a v-twin Ninja.
old build thread is over here mixed in with a ride report. don't go in there unless you have plenty of time on your hands...maybe snowed in somewhere.
http://www.kawasakiversys.com/forums...ead.php?t=5480
no vtwin ninjas. the "V" in V649HP is for Versys since the bike is built around the versys frame, while the 649HP is the sportbike engine.
so it's really a rat versys with a cop motor.
Old 12-18-2010, 08:52 AM   #83
jdrocks OP
Gravel Runner
Oddometer: 4,551
both the bikes in the photo are based on the Ninja 650R model designation in the States, but otherwise known as the ER6F, or EX650.
Old 12-18-2010, 10:47 AM   #84
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,709
I don't believe I know Sheila JD but I'd sure like to see her bike. With the damage to my back, I've shrunk near two inches and shorter is better.
Mike -
Old 12-18-2010, 11:35 AM   #85
jdrocks OP
Gravel Runner
Oddometer: 4,551
you would have met them at jeffs place in bedford, but she didn't have the bike then. mike was the rider who broke his new connie in half that day.
2" ain't nuthin', now you can tuck right in, probably worth 10-15mph on the top end.
PM for contact info if you're interested. they're top notch and would enjoy showing you the bike.
Old 12-18-2010, 02:41 PM   #86
jdrocks OP
Gravel Runner
Oddometer: 4,551
probed around that gap at the frame stem with a length of wire, and there's nothing behind that glob of weld.
there's an even larger opening on the underside of the same assembly, also with a puddle of weld in front of it.
an assumption, but they must not have intended to weld these joints. i decided to leave them alone. they would require multiple passes to close and i don't want that much heat.
clipped everything off the frame that doesn't have something specific mounted to it.
my weight reduction program starts off with a total of 6.6oz, big deal.
the welds were ground flush with a 120 grit disc. you can't just grind away on these welds, it takes a light touch on the frame tubes.
the exposed metal gets smoothed with a little filler, and then primed. looks better already.
Old 12-18-2010, 06:15 PM   #87
SamM
Jeep Overlander
Oddometer: 1,471
A paddle wheeled sanding disc would smooth that right out. No filler required.
SamM
SamM is offline   Reply With Quote
Old 12-18-2010, 06:36 PM   #88
jdrocks OP
Gravel Runner
Oddometer: 4,551
SamM
i think that procedure only works on KLR frames. these cool Versys frames require something a little different.
Old 12-18-2010, 11:59 PM   #89
BSR
Happy at the back
BSR's Avatar
Oddometer: 232
I'm with you, thanks for the clarification.
Just got in from work, wife hasn't got up yet and it's -12c outside and i've got a nice beer so i'll start through the other build thread!
Old 12-19-2010, 04:56 AM   #90
tragerbon
tragerbon's Avatar
Oddometer: 131
I like the direction you are going with this, after modding my new bike and reading all of the converted to dual-sport threads, I wanted to start over with just a versys frame, cut off the crap I did not need...etc...etc.. Good luck with the build.
My guess on the two machined parts are, the forks !
Bike free : (
tragerbon is offline   Reply With Quote
Times are GMT -7.   It's 01:03 AM.
