Old 12-22-2010, 10:48 PM   #121
mpowers
mpowers's Avatar
Oddometer: 738
Well now we know why we haven't heard from ya, lol. I still haven't fixed up the mrs enja from her first off road test weekend and your off building another one!
mpowers is offline   Reply With Quote
Old 12-23-2010, 04:29 AM   #122
jdrocks OP
Gravel Runner
Oddometer: 4,274
hey mike, ya better get that bike shined up, might have people banging on the door wanting to look at it after the holidays.
if PM count is an indicator, there's a lot of interest in your lower ride height version. then there's the gal yesterday who is rounding up all the parts to build tonymorr's version of the rat ninja for herself. hope she comes back with a photo.
so i should be painting some parts, but i'm still waiting on some things to show up so i can shoot it all at once.
at least i'm painting something...touching up the paint on canada goose decoys.
show and tell at McD this spring, look forward to seeing you both.
jdrocks is online now   Reply With Quote
Old 12-28-2010, 10:12 AM   #123
jdrocks OP
Gravel Runner
Oddometer: 4,274
i've had the parts bike in the shop for awhile now, and it's been a distraction. there was no opportunity to start it when i got it because of the damaged generator cover, so other than satisfying myself that it had compression, i didn't know 100% whether the damn thing would run.
i caught a break from holiday obligations and mounted a new cover and fixed some other stuff the PO damaged. some people are just plain dumb when it comes time to turn a wrench.
new oil and filter, charged the battery, added seafoam, and hit the starter. cranked for two seconds, then lit right up. nothing unusual, runs great. what a relief. let it idle for an hour, then changed oil again.
Old 12-31-2010, 03:25 PM   #124
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,668
Checking in to see how your doing JD. Hope you had a great Christmas and here's to a happy New Year!
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 12-31-2010, 05:15 PM   #125
jdrocks OP
Gravel Runner
Oddometer: 4,274
David
thanks, same to ya.
family headed home tomorrow, might have time to spray the frame.
Old 01-02-2011, 10:20 AM   #126
jdrocks OP
Gravel Runner
Oddometer: 4,274
frame painted hotrod black in acrylic enamel. i hate painting frames. all those tubes and brackets, hard to get real good coverage and i usually find a spot or two where i could have gotten a better blush. looks pretty good from ten feet...and has twice the amount of paint that the factory put on there.
now i can start bolting this thing together.
Old 01-02-2011, 12:39 PM   #127
squirley
punk in drublic
squirley's Avatar
Oddometer: 151
JDROCKS!!! Keep up the great work man, your an inspiration! If I owned Kawasaki, I would fire some people in the corner office to make room for you!
squirley is offline   Reply With Quote
Old 01-02-2011, 01:17 PM   #128
jdrocks OP
Gravel Runner
Oddometer: 4,274
that's a scary thought...besides, i'm supposed to be retired.
stay tuned, bolting this beast back together.
Old 01-02-2011, 02:46 PM   #129
KLRnit
KLRnit's Avatar
Oddometer: 61
great job guys on the builds
2009 Ebony KLR650
Wish list: KLX450 forks with Emig Racing front end conversion, KLE650 VERSYS engine swap,rear long travel shock, and a butt load of your typical "bolt-on's !!!!"
KLRnit is offline   Reply With Quote
Old 01-02-2011, 03:28 PM   #130
jdrocks OP
Gravel Runner
Oddometer: 4,274
thanks. you should be wishing for a 649HP swap instead.
Old 01-02-2011, 03:40 PM   #131
jdrocks OP
Gravel Runner
Oddometer: 4,274
i've used a Versys shock on the Ninja 650R builds previously where the Ninja frame was used, and that shock actually works pretty well. this Showa shock uses a 16kg/mm spring, is about an inch longer than the 650R shock, and has damping adjustment.
Ninja shock left, Versys shock right. you would never confuse the two.
i'm looking at some shock options, but until i settle on something, i'll mount the Versys shock. a full custom shock for this build is not in the budget, so the new shock has to be better than the Versys and cheap.
Old 01-02-2011, 04:19 PM   #132
SamM
Jeep Overlander
Oddometer: 1,471
Ohlins makes one!
SamM
SamM is offline   Reply With Quote
Old 01-02-2011, 04:29 PM   #133
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,668
Originally Posted by SamM View Post
Ohlins makes one!
- sorry this just tickled my funnybone for some reason.
David
Old 01-02-2011, 04:45 PM   #134
jdrocks OP
Gravel Runner
Oddometer: 4,274
David
ya really do need a riotous sense of humor around this place...
Old 01-02-2011, 04:56 PM   #135
jdrocks OP
Gravel Runner
Oddometer: 4,274
so, got the frame, got the swingarm, got a shock to tie things together and now it looks like this...new style Ninja swingarm on the Versys frame.
i needed to clearance the front lip of the lower shock mount about 2mm to ease the bolt through. they changed the shape of the mount just enough to make a tight fit. no problem.
now i need a front suspension and some wheels and i'll have a roller.
Times are GMT -7.   It's 09:57 AM.
