Old 04-04-2012, 09:40 AM   #1396
LukasM
Oddometer: 5,426
Hey JD,
Check out the new Adventure pegs from Fastway when you get a chance, we put them on the Bergs and absolutely love them. They have a way bigger platform and are actually lighter than the old ones while staying indestructible.
I'd put them on all of my bikes if it weren't for the price....
Old 04-04-2012, 11:28 AM   #1397
jdrocks OP
Gravel Runner
Oddometer: 4,569
Originally Posted by LukasM View Post
Hey JD,
hey Lukas, i saw in the 570 bike prep that you used those, but you hit on the central issue for these budget builds, they can't be found C-H-E-A-P, at least not yet.
the big SS Fastways are an excellent performer, and the last two sets i've used were just $40-50 a pair, new or like new.
where is the trip report from your high altitude adventure?
jdrocks is offline   Reply With Quote
Old 04-04-2012, 12:37 PM   #1398
Rodzilla
Horny as Hell
Rodzilla's Avatar
Oddometer: 1,612
JD I Love your bikes man. Just keep coming back
Now if you just put together this thread in a full step by step tutorial for us folks that are too timid to try to figure it out for ourselves, you know just a full parts list, fab list and a to do list....something quick and easy, ya know?
COHVCO/COTPA/BRC/USA-ALL/ARRA/AMA/Moab Parnership
COHVCO Supporter
Rampart Range Motorcycle Management Committee(RRMMC) Past President/VP
Certified SAE J1287 sound tester
Rodzilla is offline   Reply With Quote
Old 04-04-2012, 05:45 PM   #1399
bodie1
slightly unbalanced
Oddometer: 12
Yes JD the fold-up shifter and brake lever are on the list(that seems to keep growing) just undecided on the fast ways at this time. Now i just added the engine guards to the list so had to up my budget a bit.
bodie1 is offline   Reply With Quote
Old 04-05-2012, 04:50 AM   #1400
jdrocks OP
Gravel Runner
Oddometer: 4,569
Originally Posted by Rodzilla View Post
Now if you just put together this thread in a full step by step tutorial...
thanks. well, this is the step by step tutorial. a little fabrication, used parts, bolt it all together and you're riding some interesting places.
Old 04-05-2012, 04:54 AM   #1401
jdrocks OP
Gravel Runner
Oddometer: 4,569
i've seen the Motechs used for 50% off catalog, and you can find even less expensive footrests, but the used Fastways in that price range are a bargain.
Old 04-05-2012, 06:22 AM   #1402
Ridin'nFishin
Oddometer: 522
What a bike!
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin is offline   Reply With Quote
Old 04-05-2012, 07:09 AM   #1403
pjm204
Oddometer: 2,012
I've been extremely impressed with mine thus far.
I'm having a little trouble finding someone to swap the spring on the R1 shock though, any suggestions? Nobody seems willing to do it.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 04-05-2012, 02:33 PM   #1404
jdrocks OP
Gravel Runner
Oddometer: 4,569
Originally Posted by Multisurface Rider View Post
What a bike!
thanks. damn, that photo reminds me, better wash that thing, doesn't look even close to that right now. it's a big ball of mud.
Old 04-05-2012, 02:40 PM   #1405
jdrocks OP
Gravel Runner
Oddometer: 4,569
bum the strut spring compressor at your local auto parts store with the free "lend-a-tool" program, change your spring in the parking lot, give the tool back to them.
bring some padding material so you don't scratch the powder coat on your new spring.
Old 04-05-2012, 03:53 PM   #1406
MrPulldown
MrPulldown's Avatar
Oddometer: 3,412
Originally Posted by jdrocks View Post
true...so here's a shout out to a 2007 DRZ400S guy, anybody got the instructions for adjusting these forks?
an opinion on where the instructions can be found would work too.
I am in the process of installing a 98 RM250 fork on my DR350. The RM and the DRZ forks are pretty similar. These things adjust like any other showa fork. Compression danmpening is the top center screw. Rebound dampening is the center screw on the bottom. Each leg is independent of the other (meaning each leg has it both its own compression and dampening function).
Is this what you are asking. Or are you talking about revalving/springing.
I have been looking for a manual to figure out how to service these and have not been able to. I might break down and by the entire workshop manual jsut for the fork service section.
A little more detail I beleive the DRZ forks you have are 49mm single chamber forks. The DRZ did not get the dual chamber till 07(?). The RM got the dual chambers 96-98. But where USD before and after, as that is what the market wanted. The USB priors to 96 were so bad that they ran the conventional, till they got it right in 99.
If you get more fork info post it. I keep an eye on this thread.
Jsut noticed that you were looking for an 07...
MrPulldown is offline   Reply With Quote
Old 04-06-2012, 04:43 AM   #1407
jdrocks OP
Gravel Runner
Oddometer: 4,569
Originally Posted by MrPulldown View Post
If you get more fork info post it...
an inmate was kind enough to send me all the DRZ fork info i need. i'm going to check all the settings to see where they are, then tweak them a bit. i could continue running them as is and be happy with the performance, but i don't leave things alone for very long.
one more time, these forks work great in this application. big tall bike, the mirrors are at eye level.
Old 04-06-2012, 04:45 AM   #1408
pjm204
Oddometer: 2,012
I only have 2 issues with that suggestion. 1, where have you found a strut spring compressor for a car that will fit between the coils? 2, I know I tried using the harbor freight one on a 350lb KLR spring and the tool failed, this spring is over double that spring rate.
I'm too young and too beautiful to die.
The one shop I found that said they will do it wants at least $50
Old 04-06-2012, 05:34 AM   #1409
jdrocks OP
Gravel Runner
Oddometer: 4,569
i'm ancient, and got this old by staying away from Harbor Freight.
Old 04-06-2012, 05:50 AM   #1410
pjm204
Oddometer: 2,012
and 15 minutes later I get it done at straus auto....hahaha let's see how the R1 shock is now.
Times are GMT -7.   It's 02:54 AM.
