04-08-2012, 02:11 PM
#1426 | |
Gravel Runner
Oddometer: 2,837
yes, bring the photos...keep the snow. |
04-08-2012, 02:31 PM
#1427 | |
Gravel Runner
Oddometer: 2,837
04-08-2012, 02:48 PM
#1428 | |
Gravel Runner
Oddometer: 2,837
whoa there son, stop right there, i don't want any women in my shop that are big enough to compress a 16kg shock spring just from sitting on the bike. it was that factor, plus his use of 40 zip ties. if i remember right, nobody got killed. |
04-08-2012, 04:49 PM
#1429 |
Gravel Runner
Oddometer: 2,837
04-08-2012, 05:23 PM
#1430 |
Oddometer: 27
http://s1254.photobucket.com/albums/...t=DSCF2924.jpgmy shim for fork http://s1254.photobucket.com/albums/...3DDSCF2923.jpg lower bolt is stock bolt of versys middle bolt is stock bolt of drz upper bolt is my bolt of my versys adventure http://s1254.photobucket.com/albums/...roooooo006.jpg kit with 21 /17 in wheel stock fork sorry for pict ....adv rider system for put picture in post and my is not good ,,, 1
all have two wheels which deserves to be run |
04-08-2012, 05:30 PM
#1431 | |
Oddometer: 27
ist made with solo parts rim +heart of wheel, made all adaptor and put on bike this set up is 21 front and 17 rear
04-08-2012, 06:27 PM
#1432 |
Gravel Runner
Oddometer: 2,837
Mario, direct view photos from your photobucket. from the lower right under "links", select "IMG code", then paste into your ADV post. use "preview post" to make sure it's what you want.
takes some talent and the right equipment to safely machine the .5mm shim. $100USD is indeed a good price for two complete sets of these custom parts. ![]() good job on the custom axle (top).
04-08-2012, 07:43 PM
#1433 |
Oddometer: 27
![]() lh side ![]() rh side ha la la!!!!!! i am a good student and a good teacher
04-08-2012, 07:58 PM
#1434 |
Oddometer: 27
![]() front breake adaptor rear sproket adaptor ![]() front break adaptor use not same bolt to fixe adaptor to wheel and fix disk to adaptor ![]()
04-08-2012, 08:07 PM
#1435 |
Oddometer: 27
my klr ....same part are home made too ...
04-09-2012, 08:42 AM
#1436 |
Oddometer: 27
i probably sold and front adaptor kit ,spacer +bolt for fit a drz wheel on drz fork on versys,,this kit not include shim for fit fork and bolt if you want a sheet with spec for made a same of my bolt is possible
price are ??? i check am confirm this week
04-09-2012, 03:11 PM
#1437 |
Gravel Runner
Oddometer: 2,837
i'd like to see seperate prices for the DRZ400 forks to Versys clamps sleeves/shims, the DRZ front hub adapters/axle, and a set of adapters for a cush hub rear wheel with 20mm axle like the DR650.
04-09-2012, 03:49 PM
#1438 |
Oddometer: 383
04-09-2012, 04:14 PM
#1439 |
Oddometer: 27
![]() ![]() ![]() 3 parts on kit ,adaptor for disk breake,metric bolt long to fixe adaptor on wheel short bolt to fixe disk on adaptor, short spacer to put on bolt at lh side after stock drz shim shim am not shim to fit drz fork on versys clam lower and upper for bolt i put diameter and wide to made one ,its not on kit
04-11-2012, 07:21 PM
#1440 |
Gravel Runner
Oddometer: 2,837
i wore out the TKC i brought back from the Yukon, so i dusted off the Kenda Big Block i ran for awhile last year and remounted that tire. the Big Block looked like it had some promise as a blocky tread DS tire when it was introduced, but the tire just will not get the miles that you can with the TKC, at least 1500 less for the rear on the V649. the tire is a decent performer, and has about the stiffest tire casing of any bike tire i've encountered, they just wear quickly.
