Old 12-17-2010, 09:16 AM   #1
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
F800GS Fork Clack Noise/Feel Demistified
I have recently seen a lot of random mentions within other threads regarding the fork clacking noise/feel on the front end of the F800GS. Most of the mentions unfortunately have shown misinformation on the subject and/or shown someone altering components on their bike that have nothing to do with the actual instigator.
The fork clack noise/feel is absolutely without a shadow of a doubt not from the plastic x shaped spring guides that ride on the damping rods inside the forks! Those black plastic x shaped spring guides do not move on the damping rod, and do not make contact with anything other than the inside of the springs. I've been inside my forks 4 times. The black plastic x shaped spring guides "snap" into position on the damping rods as to not move. They don't move therefore do not hit the fork tube cap therefore do not make a clacking noise. I've marked up a parts schematic to point out the facts:
#3 is what certain people claim is the clack-making culprit. It is the back plastic x shaped spring guide. It has a small steel ring that sits inside it in a groove (#4). #3 with #4 inside it slides onto the damping rod. The damping rod, as you can see, has a groove where the spring guide "clicks" or "snaps" into position, FIRMLY. I suspect that there MIGHT be some forks that are coming from Marzocchi without one or both of the spring guides snapped into place. If you open up your forks and the back x shaped plastic spring guides move up and down on the damping rod, this means simply that they are not snapped into place on the groove on the damping rod. Snap them into place and you're done (it requires some elbow grease to snap them into place, but this is a good thing and how it was designed. Once they're snapped into place you will not ever have to remove them again. They should have been snapped into place at the factory). No little rubber pieces or other voodoo needed.
All of that said and demistified, I'd like to point out that I have gone for rides with both of the black plastic x shaped spring guides both unsnapped and loose on the damping rod and snapped into position. No difference. No change. Sounds and feels the same either way.
Why?
This is because the clack sound and feel does not originate from these spring guides! Or anything inside the forks for that matter!
It originates from the Brembo floating front brake rotors. Nothing else. The rotors float a bit more than others designs. So when you go over bumps you hear and feel "clack clack".
This is absolutely fact here folks. I've been experimenting with it for two years. I've opened up and altered fork components many times, tightened steering head bearings many times, etc, etc... The only thing that has ever cured it is removing or hindering the "float" in the stock Brembo front brake rotors. If you don't believe me, test for yourself. CAREFULLY go for a slow ride away from traffic with both of the front brake rotors removed.
Or, as a safer option, use some zip-ties to inhibit the excessive floating motion within the rotors:
What's that? Silence? Exactly.
If you want to permanently fix it, buy and install some aftermarket rotors of a different design (non-floating), or with less "float". Two companies I have found that make them: Braking and Lucas.
http://www.wunderlichamerica.com/mot...S/8130021.html
http://f800depot.com/twalcom-wave-front-disc-p-467.html
This is not "The Griz's theory" on the subject, or my "opinion". What I've stated above are the facts. Heed them and welcome to a clack-free world. Cheers.
The Griz screwed with this post 12-17-2010 at 09:58 AM
Old 12-17-2010, 09:30 AM   #2
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Originally Posted by AlanI View Post
Very nice Griz.......the only problem being that your first link (Wunderlich) shows only a rear disc and I don't see one available for the front unless I've missed it.
Oops, sorry. Corrected in OP.
Old 12-17-2010, 09:36 AM   #3
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
That said, for the price shown for the wave I'll live with my clacking.
That's what I've chosen to do as well! Didn't bother me anymore once I knew what it was!
Old 12-17-2010, 12:03 PM   #4
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Hey Griz,
Thanks for going through the effort and posting your results!
Less clacking or at least knowing exactly what it is will hopefully lead to less
I wonder if the disc mounting "pins" (rivets or whatever) could be compressed tighter to eliminate some of the slop?
Hmmm...
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline   Reply With Quote
Old 12-17-2010, 02:17 PM   #5
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Originally Posted by toowheels View Post
Hey Griz,
Hmmm...
Dave
No prob! I love to help the forum out, especially with correct information!
That's a good question about compressing the pins or rivets or whatever they are. Let me know if you figure something out.
Old 12-18-2010, 12:43 AM   #6
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 639
I noticed a lot of play with the rotors the other day putting my front wheel on. I was getting worried. Is all that play normal?
I'll have one if you do.....
bodhizafa is offline   Reply With Quote
Old 12-18-2010, 05:47 AM   #7
blender
Just another rider
Oddometer: 726
Uhmmmm, Griz? You're forgetting this is an Interwebs forum. You're not supposed to supply correct info, only vague answers gleaned off some other forum, or obtained while talking to a mechanic's brother's friend. :)
Steve
Madison, WI
blender is offline   Reply With Quote
Old 12-18-2010, 07:22 AM   #8
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
The play is normal. I have not seen or heard of a stock front rotor on an F800GS that doesn't have excessive play. It falls under the "they all do it" category.
Before keyboard jockeying it and claiming otherwise, go out to your F8, grab the rotors, and push/pull. Lots 'o play right?
Brembo, for some odd reason IMHO, puts an excessive amount of play in the front rotors for this bike. Far too much. So much so that they make a clunk/clack noise/feel when going over any bump. A certain amount play in the friction plate of a floating brake rotor is good. This minimal play allows the outer ring (friction plate) that makes contact with the brake pads to expand and contract independently from the hub, reducing warping under intense heat. There are other reasons as well, but this is the main and most important reason floating is better. But again, it's obvious that Brembo is putting far too much play in these rotors.
Old 12-18-2010, 07:25 AM   #9
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Old 01-05-2011, 06:44 AM   #10
Xskydiver
Xskydiver's Avatar
Oddometer: 256
That all sounds very convincing. I went out to the garage and gave my brake rotors a good shaking and didn't get much movement or any noise. I'm wondering now...If the klacking is definitely NOT from the forks, then why does everyone who installs the klack stoppers report the klacking to have stopped? I haven't tried either method yet. I pretty much don't think about it until I'm on the wash board.
Xskydiver is offline   Reply With Quote
Old 01-05-2011, 08:14 AM   #11
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
If you have the clack, the movement (play) in your rotors is there just enough, trust me. I've spent two years researching this.
I've not read or seen these results you speak of.
The black plastic x-shaped spring guides that ride on the damping rod ABSOLUTELY snap into place FIRMLY on the damping rod. Therefore, these black plastic x-shaped spring guides do not move on the damping rod. If they cannot move, then they cannot "clack" up against the fork tube cap, making the use of a rubber bushing between said black plastic x-shaped spring guide and the fork tube cap useless. If your black plastic x-shaped spring guides are snapped into place properly, they are ABSOLUTELY NOT the culprit.
If you're so bent on proving me wrong, check for yourself. Go out and zip-tie your rotors like in the picture above. Ride over "washboard". No clack.
Old 01-05-2011, 10:23 AM   #12
tmex
tmex's Avatar
Oddometer: 2,039
Yes, it is the rotors. A safe and simple way to prove this is to find a section of cobby pavement that produces the clack. Then ride over it with the front brakes lightly applied to keep the rotors from moving freely, and the clack will not occur. I posted this early on when Griz was "actively" pursuing the clack, but it apparently got lost.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 01-05-2011, 05:01 PM   #13
ebrabaek
Oddometer: 4,726
I`m with Griz on this one as well...... Before I joined this forum.... I bought the $10 "clackstopper"........Made no difference.......Investigating further.......Sure enough.....the rotors were it...... Does`nt have to be fancy...... Just go out and grap the rotor.... You can yank it up and down about 1-2mm.....
Erling
Old 01-06-2011, 05:40 PM   #14
Xskydiver
Xskydiver's Avatar
Oddometer: 256
Lighten up Francis
I'm not interested in proving anyone right or wrong. I don't care enough either way. I'll try it out. It's easier than the klack stopper and free. I'll try safety wire probably though. It might look better. A more permanent solution might be a little JB weld in the joints.
Old 01-06-2011, 06:28 PM   #15
TBickell
Oddometer: 187
so then we should go and kill the "klackstopper guy" ..
TBickell is offline   Reply With Quote
Times are GMT -7.   It's 01:34 PM.
