Old 12-18-2010, 01:07 AM   #1
fullmetalscooter OP
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 2,866
Anyone make motorcycle Tire chains?
Anyone ever make winter motorcycle tire chains for thier bikes? Post a picture please and some info.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 12-18-2010, 01:27 AM   #2
asphaltmueller
nomad acc. 2(3)AVV
asphaltmueller's Avatar
Oddometer: 1,006
we use those quite regularly
http://motorang.com/staudacher/index_english.htm
now the "Winter-Rider Tipps in German; a bit down the page you find a picture series of how to build a chain yourself; maybe some software can help with the german
http://motorang.com/motorrad/winterf...#fraenkyketten
have fun
andi
asphaltmueller is offline   Reply With Quote
Old 12-19-2010, 08:39 PM   #3
hdpusher
Lunch box repairman
hdpusher's Avatar
Oddometer: 19
asphaltmueller Those are awesome. Way better than the one we've made from old drive chains and cable.
hdpusher is offline   Reply With Quote
Old 12-20-2010, 10:51 PM   #4
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,222
Here is one way. http://www.advrider.com/forums/showt...ht=snow+chains
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 12-21-2010, 06:23 AM   #5
Spaggy
Spaggy's Avatar
Oddometer: 836
kijiji Canada
I saw these on Kijiji in Alberta. $375.00. That's pretty tall coin if you ask me.
http://reddeer.kijiji.ca/c-ViewAdLar...AdId=248735023
Spaggy is offline   Reply With Quote
Old 01-04-2013, 05:01 PM   #6
mikesova
mikesova's Avatar
Oddometer: 1,853
Originally Posted by trailrider383 View Post
I really like the simplicity of making those, so I stopped at the hardware store on the way home from work and bought some supplies to try it out.
After about 10 minutes, I had this:
I didn't rivet the strap to the cam buckle, I just used safety pins to mock it up. To do it like Allgo did, you would need 8 sets of this for each wheel. I made this one for the rear, however, if I was making a whole set, I would probably shorten the chain portion. In the picture, the chain is about 8", but that leaves some of the chain on the sidewall, which probably isn't necessary. For the record, this was on a D606.
Here is a breakdown of what I (would) have into 1/8 of a set.
(1) cam buckle- $1.49ea.
(1.25") 1" nylon webbing- $.29 per foot
(2) D-Rings -$.50 ea.
(6") twisted 3/8'' chain - $2.29 per foot
So, about 4 bucks per "chain"
However, this setup isn't using the vbar snow chain, this is just regular chain. I don't think the regular chain would be very helpful on my rear, though, since the chain sits lower in the tire than the knobs.
It would also be nice if the cam buckles would fit between my spokes, but they don't very well, so they would have to be offset more on the side of the rim. This probably wouldn't be too big of a deal, since with the chains, one would be riding at slow speed and you could balance them out by having 4 favoring one side and 4 favoring the other.
The regular twisted chain that I have, may work ok on my front, since it does stick out slightly more than the knobs.
For the chain, I did find this set of ATV vbar snow chains for 20$ shipped, which seems pretty reasonable, if they will stick out beyond the knobs enough to catch.
2009 Kawasaki KLX250S
2001 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
For Sale: 2004 Husqvarna TE510 (Michigan)
mikesova is offline   Reply With Quote
Old 01-07-2013, 09:59 AM   #7
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,527
http://www.advrider.com/forums/showthread.php?t=536330
Check above out
scooteraug02 is offline   Reply With Quote
Old 01-07-2013, 11:41 AM   #8
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 11,469
Old timers used to wind 1/2 manilla rope around their Model A wheels, eventually circling the entire wheel/tire . . . .
it worked well, and would self-uninstall when dry pavement was hit ;-}
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 01-07-2013, 11:45 AM   #9
mikesova
mikesova's Avatar
Oddometer: 1,853
I would mainly like mine to help with traction so I could ride snow covered single track and possibly play on the ice.
2005 Yamaha FZ6
Old 01-07-2013, 12:02 PM   #10
scooteraug02
Dog Rancher
Oddometer: 4,527
Ice studs?
http://www.gripstuds.com/Motorcycle_Ice_Racing.php
http://www.kevinscycleracing.com/tires.htm
3/4 of the way down the page.
http://dr650.zenseeker.net/Tires.htm
http://www.snowmobiletrails.com/moto/index.html
Old 12-03-2013, 07:15 AM   #11
gervais
Oddometer: 42
on the center picture,i think it is an BMW GS,where do you find these snow chain?
they looked no1 for me.
thanks
gervais
gervais is offline   Reply With Quote
Old 12-03-2013, 11:22 AM   #12
MrPulldown
MrPulldown's Avatar
Oddometer: 3,060
You can buy bigger twisted link chain. You can also find used chains with V bar cross links off of craigslist used for cheap. Though right now is the "HOT" season for used tire chains.
MrPulldown is offline   Reply With Quote
Old 12-03-2013, 01:36 PM   #13
jon_l
jon_l's Avatar
Oddometer: 3,038
Mikesova - those D rings look weak, as they aren't welded on the flat side where the ends meet. Are you confident that they won't pull open? A tire chain flung off while moving could be dangerous, especially if into your drive chain.
'09 Honda CBF1000
jon_l is offline   Reply With Quote
Old 12-03-2013, 05:42 PM   #14
MiteyF
MiteyF's Avatar
Oddometer: 1,977
I got about 75% of the way through making a set out of old car chains last winter... then it never snowed (WA) and I never got to try them. Then this summer I moved to MI and figured I should finish them, only to find out it's illegal in MI to use chains OR studded tires, as if there's any possible way to do MORE damage to the bullshit that passes as "roads" here
So as of now, I've got a front and 1/2 a rear chain sitting in a case in the garage. Guess that's one more welding project to add to the list of shit-to-do this long cold winter!
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 12-04-2013, 05:03 AM   #15
trailer Rails
trailer Rails's Avatar
Oddometer: 3,387
Grip studs, just select your size and be done with it.
trailer Rails is offline   Reply With Quote
Times are GMT -7.   It's 01:06 AM.
