11-27-2012, 09:21 AM
#1936 |
Crunkin' with crackers
Oddometer: 6,910
Somebody was a fan of High Anxiety judging from that front wheel...
rubber side down, derek http://azbiker.smugmug.com Got SmugMug? If not, save some cash and use my code: McYdbycdcvM5Q |
11-27-2012, 10:46 AM
#1937 |
Oddometer: 4
![]() ![]() just traded her in .
11-27-2012, 10:47 AM
#1938 | |
Also if the time comes, I think I can make it into a 1200 not to expensively. So another question, how are the brakes? That would be something I could consider important. and can you put a 4.5 gallon tank on it? Thanks for the info. Damasovi
A motorcycle or scooter always turn a bad day into a great time! KLR 650, Honda Beat scooter!! |
11-27-2012, 01:06 PM
#1939 | |
Oddometer: 60
If brakes are a concern to you, get a Roadster (XL 1200R, also available as a XL 883R) with tiwn front discs. You can always put a 4.5 gal tank on but to many it ruins the look of the Sportster - and used 4.5 gal tanks are expensive! Even dented ones regularly fetch in the order of $300 on Ebay. |
11-27-2012, 02:16 PM
#1940 |
Oddometer: 134
I commuted 150 miles a day on a Sportster for about 7 years and 120K. Probably the root of my back problems now. I tried a couple of different Harleys and a Buell but then a VStrom spoiled me and I eventually sold the Sportster. Now my daily commuter, play bike, tourer is an F800GS and it does it all well, but I found myself jonesing for that old Sportster again especially after RTWDoug did his ride last year.
Well I recently couldn't sell my old suburban so I traded it for a 96 Sportster. I forgot how much fun it is to ride such a primal motorcycle. Now I keep spending money trying to make it fit me.
Ratchdaddy 2010 F800 GS 1988 NX250 |
11-27-2012, 02:45 PM
#1941 |
Oddometer: 1,378
I like everything about that bike except the seat and the forward controls. The seat looks uncomfortable for actual riding and I would prefer mid controls. Sharp bike, nonetheless.
2009 Kawasaki KLX250S 2001 Yamaha TTR125 (Wife's bike) 2005 Yamaha FZ6 |
11-27-2012, 05:58 PM
#1942 | |
I have no soul
Oddometer: 5,592
Braking is subjective. I have a 1200c and have never had a "Wish I had better brakes" moment even 2 up with luggage. It isn't a sport bike and if you ride it more like an old standard it will always do what is asked of it. Power is also subjective. I have ridden an 883 and a Bonneville and they have similar power outputs (very different power delivery though). Neither felt under powered even at freeway speeds. As hhkiwi said the 4.5 gal tank is relatively expensive as an add on. the good news is that they make a couple models with the 4.5 from the factory. It may be cheaper to buy one of those then swap other parts to give it what ever look/ function you want. It all depends on what you want. Also remember that an 883 with a 3.3 will have similar range to a 1200 with a 4.5. A friend of mine has an 883 and regularly sees between 55-62 mpg average. An 883 with a 4.5 gal tank will have a very good fuel range.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~ My HD Scram-ster build Help Save a Pit-Bull |
11-27-2012, 07:55 PM
#1943 | |
Oddometer: 134
Beautiful bike. I love the way that Sportsters used to be built to be more comfortable. Love the seat and I have thought about getting one at the swap meet to adapt to my 96.
11-27-2012, 09:45 PM
#1944 | |
THe reason I would go with a stock tank and then change it, it is for the fact that it would be cheaper, if I buy the bike in the USA I have to pay import fees so it would be like $500-1000 to import it. The higher the cost of the bike the more I pay, if I just put on the tank it would cost just that, no additional fees, but I would buy the tank ONLY if I wanted to go on tour with the sporter, and maybe that would not be the case (at the begging), and I know that tanks are on the expensive side, but anything HD is on the expensive side... Thanks Damasovi
11-28-2012, 09:46 AM
#1945 | |
Oddometer: 189
![]() Or, for a snazzier look, with a tank from an '88 XLH. That's one nice thing about the '82-'85 Sportster - a lot of body parts and suspension components from later-year Evos will fit them because of the shared frame design.
83XLX screwed with this post 11-28-2012 at 10:10 AM |
11-28-2012, 01:33 PM
#1946 |
t00 0ld 2b n00b
Oddometer: 1,294
^ I gotta say it again - it's impossible to take a bad picture of 83XLX's bike (no matter which look he transforms it to).
11-28-2012, 02:17 PM
#1947 |
Oddometer: 1,214
I've had two Sportsters. Bought a new 1984 XLX1000 that year, and recently had a 2008 XL883. I understand they have dropped the XR1200 now. Too bad. I worked at Destination HD in Tacoma, Wa. for five years, so am a bit out of touch now. I much prefer an XL with the longer "standard" length suspension. My two XLs didn't have much of a scraping of parts while cornering problem. A co-worker with a Nightster tried following me on the way to work one day on a nice curvy country road, and could not stay with me due to lack of cornering clearance. I was 58 at the time and he couldn't believe how far I leaned in the corners and the speeds I went.
All the Sportsters now have lowered suspension since the fine XR1200 and XL883R and XL1200R have all been dropped for the US market. These shortened models would have to have longer shocks and longer fork tubes installed. I think it's a dam shame, as a Sportster CAN be fun on a twisty road. Some prefer the older ridgid mount models due to their lighter weight, which can be as much as 75-85 pounds difference. Yes, they vibrate more, but depending on the bike and how it runs, some don't find the vibes that bad. That's why many "cafe" bikes that are Sportsters use the pre-2004 models. There should still be parts where you can convert your 883 to a 1200 using dished pistons available from HD. This way you can reuse the 883 heads. Your converted XL you will find, will be faster stop light to stop light than a factory 1200 as the gearing is lower on an 883. If I converted one I would stay with the 883 gearing, as my 2006 ran just fine at freeway speeds and got very good mpg. If you don't mind the shortened XLs, you might take a look at the "Superlow". It comes with radial tires and some nice radial wheels, and a bigger 4.5 gallon tank. I love the looks of the 48, Iron, Nightster, etc, but after riding the two that I owned, I don't know if I could live with a Sportster that shoots showers of sparks in the corners. I also don't like forward controls, as they can be another problem in the area of cornering clearance. I think a good, used "R" model would be hard to beat, and they made them before they went to the rubber mounted Sportsters also. They have dual front disk brakes, nice flatter handlebars, and longer suspension. The tank on the 48 is too small for me. I really enjoyed the two Sportsters I owned and wish I would have kept my 2006 and paid to have it shipped to the Big Island.
Jon in Keaau, Hi. USA 2008 SYM HD200 (wife's ride) 2009 Kymco People 150 and coming soon, another dual sport mc |
11-29-2012, 04:55 AM
#1948 |
STROMINATOR
Oddometer: 959
18" rear, 19" front helps, that and not having the back of the bike dragging on the ground. A low seat height does not make for better handling.
If you get far enough away, you'll be on your way home. Piss off, I'm in my Happy place. |
11-29-2012, 06:33 AM
#1949 |
Oddometer: 2,402
WTF? Braking can be measured and is not subjective but is objective. Even riding any bike (not Sportster hating here) as an "old standard" there will be times when good brakes are required.
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
11-29-2012, 06:55 AM
#1950 |
Tire Tester
Oddometer: 6,201
I would say that stopping distance from a given speed can be measured, but even then tires, road surface, and road conditions are all variables. Brakes can be grabbier than I like. Brakes can fade. Brakes can require more effort. Braking can be non-linear.
So while shortest stopping distance from a given speed is "objective", that is just the beginning. There are important "feel" considerations beyond that. As an example, brakes suitable for racing would probably not please me on the street even though they would be objectively "better".
Roll The Bones IV- What's coming next? http://www.rollthebonesrally.com/ "If you can't fix it with a hammer you can damn sure teach it a lesson".
