Old 02-07-2013, 02:32 AM   #2131
shunpiker
Oddometer: 7
They make a little lever that snaps on the "cruise control" star thingy so you can turn it on and off with the flip of your thumb. Makes it pretty functional.
shunpiker is offline   Reply With Quote
Old 02-07-2013, 12:02 PM   #2132
n8dawg6
krunkin'
Oddometer: 145
Originally Posted by Eye of the Tiger View Post
While polishing the chrome for the first time ever, I just noticed that my Nightster has a little star wheel to tighten the throttle down for cruise control. I didn't even know what it was until I played with it a bit. ARRRRRRGGHH!!! I suppose I am pretty happy, but why didn't anybody tell me this before? I sure could have used that a few times.
honestly, I'm scared to use the damn thing. couldn't tell you if it worked or not. I figure if I got in a panic stop situation, it might cause confusion.
'09 XR1200
'00 TT600
n8dawg6 is offline   Reply With Quote
Old 02-07-2013, 12:10 PM   #2133
Eye of the Tiger
Eye of the Tiger's Avatar
Oddometer: 68
Clutch in and ignore the engine bouncing off the rev limiter.
It shouldn't be so tight that you can't twist the throttle back, either. Just tight enough to hold the return spring.
2008 H-D XL1200N
Eye of the Tiger is offline   Reply With Quote
Old 02-07-2013, 03:13 PM   #2134
gus
gus's Avatar
Oddometer: 743
Almost all bikes used to have throttle tensioners. Sportsters have had them since they went to a quarter turn throttle in 1973.
gus is offline   Reply With Quote
Old 02-07-2013, 03:40 PM   #2135
Eye of the Tiger
Oddometer: 68
This is my first Harley, and the newest bike I've owned. If any of my old UJMs had throttle tensioners, I certainly didn't know about it.
2008 H-D XL1200N
Old 02-07-2013, 03:42 PM   #2136
Scrivens
Scrivens's Avatar
Oddometer: 294
Originally Posted by BobPS View Post
I replaced the rear supspension of my Sportster (2002 Sportster) with Progressive 13.5" and the front spring with Progressive springs. Made the bike handles so much better.
If you want to make it a lot sharper, raise the fork legs 1/2" up the triple-tree. Mine is an standard '07 - not a lowered one - and has the long RK rear shocks on. Raising the legs is common on VStroms for handling and stability issues, and I tried it on the Sporty more out of curiosity than anything. Works a treat and lightens the feel a lot. Takes about 5 minutes to do, can be done on the side stand, but (carefully) slacken the bolts only enough until the legs just start to move. Tighten the upper bolts first when the levels are correct, then bounce the front suspension a few times and tighten the lower bolts.
Scrivens is offline   Reply With Quote
Old 02-07-2013, 09:24 PM   #2137
DS Hobo
DS Hobo's Avatar
Oddometer: 17
Rode the 1200S today
I had a 2000 883C before, but this bike I REALLY enjoy.
DS Hobo is offline   Reply With Quote
Old 02-07-2013, 11:56 PM   #2138
BobPS
BobPS's Avatar
Oddometer: 90
I only used (and always used) this throttle tensioner when warming up the bike. Mine was a carb'd Sportster and it always cough when cold. So, every time I started the bike, I turned this tensioner so the engine ran a at a higher rpm than idle, while I put on my jacket, helmet,and gloves. Once I was ready (about a minute), and the engine warm to the touch, I loosened the tensioner and ready to go.
BobPS is offline   Reply With Quote
Old 02-08-2013, 09:34 AM   #2139
fastdadio
Still gettin faster
Oddometer: 950
Welcome to the club! I will never sell mine. Ever.
And to all you poor FF's that didn't jump on one when they were available, Neener-neener-neener!
fastdadio is offline   Reply With Quote
Old 02-08-2013, 11:13 AM   #2140
fastdadio
Still gettin faster
Oddometer: 950
About that throttle tensioner.
I think all Sportsters have a tensioner. I keep mine set to a neutral tension. Easy to open and close. If I let go of the throttle, it will slowly vibrate closed and begin to slow down. Easy to adjust on the fly. Switching between my other bikes with a return spring, I don't even notice the difference. From a safety standpoint, whether you realize it or not, you always manually close your throttle anyway. Also, the Sportster has a bank angle sensor. Meaning, if it tips too far over it will cut out the ignition. So next time you FF's are out for a ride, play with it. I really like mine.
Old 02-08-2013, 02:12 PM   #2141
shupe
Oddometer: 70
A little history: From the earliest days of twist grip throttles (before 1910), Harley throttles did not auto-close.
They had a solid (not braided) wire inside the throttle cable housing that ran inside the handlebar.
It pushed or pulled the carb butterfly open, and had to be twisted closed to close it. Otherwise the throttle stayed where it was. By the early 70's the carb had a light return spring but the friction of the solid cable, by design, was too much for the spring to close the throttle.
In 1974 the Feds mandated self closing throttles (and left side shifters, right side rear brake), so H-D complied, but put in the tension screw and it's been there ever since. As stated, adjust it so it keeps the throttle from closing, but not so tight you can't over-ride it and twist the grip. You'll do so not only to close the throttle but the make minor speed adjustments.
"Experience has shown that it is preferable to use a comparatively large
motor running at a moderate speed in preference to a smaller motor running
at high speed."
-Harley-Davidson sales brochure - 1905
shupe is offline   Reply With Quote
Old 02-08-2013, 03:34 PM   #2142
gusanito
Mindless Wonderer
gusanito's Avatar
Oddometer: 201
Put an 18" on the back, replace the fork oil with 270ml of 20w and raise the forks .7".
You'll be pleasantly surprised!!
gusanito is offline   Reply With Quote
Old 02-08-2013, 05:43 PM   #2143
Randy
Randy's Avatar
Oddometer: 1,410
Wow! Is that what that is? And all this time I thought it was some sort of cable adjustment! I REALLY should read my owner's manual, huh??
But after reading this just now, I went out and played with it a bit... Just seems to make the throttle sticky and sorta notchy to me. I quickly turned it back the other way. IDK, maybe mine's defective or something, but it's not for me.
"Life is too short to do anything other than that about which you are absolutely passionate."..........."Adventure is a frame of mind, set upon by action, not defined by equipment."..........."I didn't get a Sportster because I wanted a Harley....I got a Harley because I wanted a Sportster."..............."It all boils down to your ability to say "SCREW IT" and really mean it".....Randy
Randy is online now   Reply With Quote
Old 02-09-2013, 06:20 PM   #2144
BobPS
BobPS's Avatar
Oddometer: 90
It was the bike I wanted when I bought my Sportster ... unfortunatelly they didn't sell 1200 S here in Indonesia
Old 02-11-2013, 10:26 AM   #2145
Eye of the Tiger
Oddometer: 68
I just did a 400 miles highway trip, and had plenty of time to fool around with the thing. I got the hang of it pretty well. I only had a slight issue when a car suddenly decided to merge in front of me, but I forced the throttle closed manually. It definitely saved my hand from getting cramped up. Now I just need something to save my ass. These rear shocks are horrible
2008 H-D XL1200N
Times are GMT -7.   It's 11:51 AM.
