Old 03-16-2013, 08:35 PM   #2341
mazeppa
b00n
mazeppa's Avatar
Oddometer: 3
Originally Posted by Randy View Post
So, you're running 14" shocks on a rubbermount, with no interference between the lower run of the belt and the rear master cylinder linkage?
My shocks are 14” center to center. With the bike supported on a lift and the rear suspension at full drop (rear tire in the air), there is a minimal clearance with the rear master cylinder linkage to the rear brake pedal. This clearance does increase as the rear suspension compresses. I have about 9K miles using these 14” shocks and there is no visual evidence of any rear drive belt rubbing or wear.
The rear OEM mufflers like I am using is something else to consider when lengthening the rear shocks on a rubbermount. To the best of my knowledge the Roadsters and the standard XLs were unique where they came stock with 13-1/2” rear shocks, and they also had a unique rear muffler with an indention for clearance of the rear axle bolt. Notice on the OEM lowered Sportsters the rear axle is visible above the rear muffler, their rear mufflers do not have this indention for the axle bolt clearance. So at full rear suspension drop my rear axle bolt BARELY clears the muffler in this indention area, I am sure there would be a clearance problem with non-Roadster OEM type rear mufflers. With an aftermarket exhaust system like everybody else runs except me; there may not be this exhaust clearance consideration.
mazeppa is offline   Reply With Quote
Old 03-16-2013, 10:45 PM   #2342
JerryH
Vintage Rider
Oddometer: 1,653
The performance of all FI Harleys can be improved, easily, but not cheaply. You have to buy what is called a Screamin Eagle Race Tuner (Harley's version of the Power Commander) I was told by someone who should know that the Screamin Eagle tuner is specific to Harley, or rather the Harley system is specific to it, so other tuners will not work. They call it a "race tuner" for legal reasons, because after you use it to remap the FI system so the bike will run right, it is no longer street legal. Other than making their system specific to their tuner, which I assume was purely for profit, they had no choice but to make the system too lean to begin with, because of the EPA, That evil organization that is trying to take away your right to ride and drive what you want.
I'm looking for a carbed Sportster, because I want to tinker with it, I unnderstand carbs, and jets are cheap. We have motorcycle emissions testing here (at least for now, it was outlawed in '08, but still here) and I have to have two carbs for my XT225. One for riding (runs great) and one set up for emissions testing (runs like shit but will pass the stupid test) I swap them out once a year. Not going to mess with the one I have set up perfectly.
"I refuse to give up the thrill of living for the relative safety of existing" Nick Ienatsch
"Life is not a race. Don't treat it as such. If you don't believe me, just have a look at the finish line"
JerryH is offline   Reply With Quote
Old 03-17-2013, 03:02 AM   #2343
waveydavey
happy times!!
waveydavey's Avatar
Oddometer: 8,030
You know JerryH, the bullshit and misinformation you spew actually could cause people some grief if they are actually naive enough to believe you. You should start doing a lttle research before you post. (If you are trolling, as has been suggested, you are an even bigger jerk than you first appear to be. Google Dynojet, Thundermax and TTS for starters, they all have systems that work quite well on Harleys. You are not even close to being an expert, you have no experience with these bikes so please stop giving out bad advice that could cause some folk to waste money.
FUCK CANCER!!!!
waveydavey is offline   Reply With Quote
Old 03-17-2013, 05:21 AM   #2344
studad
studad's Avatar
Oddometer: 421
Yep, beware the JerryH! I've seen a lot of his posts just being generic regurgitated bs but this one is simply wrong.
studad is offline   Reply With Quote
Old 03-17-2013, 08:32 AM   #2345
Randy
Randy's Avatar
Oddometer: 1,377
I would guess that "someone who should know" doesn't....
Actually, the SE tuner is not only not the only one available, it also is not the best one available. Currently, the "best" tuner for the Sportster is the Dynojet Power Vision. It is not a piggyback system that tricks your ecm into adding more fuel like most others. It actually reflashes your ecm with a completely new tune, and can then be removed from the bike. It also has many parameters that are adjustable and can be reconfigured anytime you like, or need to in order to address any further mods you make to your bike.
Another nice thing is that you can store many different maps, so if you have emissions tests its a simple matter to temporarily reinstall your factory map for the test and then reinstall your custom map once done.
They are not cheap though. You can expect to pay around five bills for the PV, and then you can spend even more if you want to get the autotune feature which gives it even more flexibility and simplifies tuning.
BUT, if you have emissions tests... rather than having to buy another carb, and swap them out back and forth, or rejet your one carb every year... yeah, plugging in the PV and hitting a few things on a touch screen would be MUCH easier and quicker. I sorta like carbs myself, but if I were in your shoes I wouldn't even consider a carbed bike for that reason alone...
I'm definitely not an expert, but there is a wealth of tuning knowledge on the Power Vision available over on XLForum.
"Life is too short to do anything other than that about which you are absolutely passionate."..........."Adventure is a frame of mind, set upon by action, not defined by equipment."..........."I didn't get a Sportster because I wanted a Harley....I got a Harley because I wanted a Sportster."..............."It all boils down to your ability to say "SCREW IT" and really mean it".....Randy
Randy screwed with this post 03-17-2013 at 10:09 AM
Randy is offline   Reply With Quote
Old 03-17-2013, 10:29 AM   #2346
waveydavey
happy times!!
waveydavey's Avatar
Oddometer: 8,030
I concur. The Power Vision definately fit my needs (2008 Softail, but a HD product as well). It was easy to use, even by a mechanically challenged guy like me. My bike runs great and any future engine modifications I do can be accomidated easily. I really like fuel injection, carbs suck. (literally)
FUCK CANCER!!!!
Old 03-17-2013, 12:02 PM   #2347
hhkiwi
hhkiwi's Avatar
Oddometer: 60
I use the Zippers Thundermax with auto tune on my 07 Sportster and it works very well. It is easy to set up and program - I would personally never want to go back to a carb'ed bike.
My experience is that the Thundermax will make the bike run better BUT it won't make it a rocket. If you really want more power you'll have to invest in engine work, such as new camshafts.
Regarding emissions testing (not required for bikes in California) I would think that you're much better off with an EFI bike and an aftermarket tuner such as Thundermax because all you'd need to do is hook it up to your laptop, load a stock fuel map, get it tested, and then reload the performance map again - voila.
hhkiwi is offline   Reply With Quote
Old 03-22-2013, 03:24 PM   #2348
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 2,771
So, after the very kind salesman (Bob) at Scottsdale Harley took me for a few miles on the 72, I'm having a really hard time NOT buying one. But for one thing, the seat is hideous! Of course, the range is only about an hour at any speed at all, so I might even get past the seat. Anybody else totally in lust with the 72?
Lyle
skysailor is offline   Reply With Quote
Old 03-22-2013, 03:34 PM   #2349
tree88
tree88's Avatar
Oddometer: 38
I love that little bike
Lyle
would make an awesome lil hotrod (88" kit and headwork) but, I really have no "need" for another barhopper... but I damn sure do want one lol
tree88 is offline   Reply With Quote
Old 03-22-2013, 03:35 PM   #2350
eliotsajerkface
eliotsajerkface's Avatar
Oddometer: 197
Lyle
I have the 48 but put higher bars on it. It's basically a blacked out 72. I picked up the lepera cherokee and it should be here in a week or so. I've read good things, and it would look awesome on a 72.
1996 R1100GS
2013 HD '48
eliotsajerkface is offline   Reply With Quote
Old 03-22-2013, 03:57 PM   #2351
eliotsajerkface
Oddometer: 197
I don't think I've gone to one bar on my 48 yet. I put 1000 miles on in the first month and got a shocked look when I went into the dealer to pick up oil for my 1000 milke tune-up.
1996 R1100GS
2013 HD '48
Old 03-22-2013, 04:09 PM   #2352
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 2,771
I really like the Iron 883 as well. If they still made the Nightster, I'd already own one.
Lyle
Old 03-22-2013, 05:36 PM   #2353
JerryH
Vintage Rider
Oddometer: 1,653
"I really like fuel injection, carbs suck. (literally)" So does fuel injection. How do you think the air/fuel mixture gets into the engine? That's right, it gets sucked in by engine vacuum just like with carbs.
I'm so tired of looking at junk, I'm about ready to buy a new 883 Iron or SuperLow, and fix it up myself over the next few years. You can get all the parts you need from the aftermarket, and not have to give more money to Harley. Harley dealers here love to sell 883s. People buy them, spend a small fortune at the dealer for parts to fix it up the way they want it, then get tired of it and come back in and trade it in on a big twin. Local dealers get as many of them as they can. They are a huge money pit for the owner, and a cash cow for the dealer.
Old 03-22-2013, 07:53 PM   #2354
tree88
tree88's Avatar
Oddometer: 38
thats how it was after I bought my dyna
I put almost 3000 miles on it in a month, and 22k the first year. Then I blew the motor (twice- both times my stupidity) re-did that, got hit on it, and deployed twice. have only managed about 3000 in the last 4 years. Been riding my sportster everywhere I go, but, with no job... that isn't very far (I did however manage to pick up a nail in a brand new tire grrrrrrr). I used to wonder how people could have bikes for years with next to no miles- I recon Mr. Murphy decided to teach me.
Old 03-22-2013, 11:02 PM   #2355
Tripletreat
Oddometer: 408
When did they get the vibes under control?
Can someone tell me the year HD began building the rubber-mounted engines in the Sportster line? TIA
For all we know, this may all be just a dream; we come, we go like the ripples in a stream.
Tripletreat is offline   Reply With Quote
Times are GMT -7.   It's 11:03 PM.
