Old 05-04-2011, 08:52 AM   #286
Wanna Ride
Oddometer: 84
Garandman - if money is no object, set your suspension up like mine. See the "7 Pages of Suspension" on the XL Forum for more information. Heavier, more aggressive riders, and riders more aware of what really good suspension is will like the Works fork spring, Intiminators with Amsoil 5w oil better. You also need better tires and fork brace.
Bloodweiser, you are referring to the "Whittlebeast Hybrid" shocks. Make sure to put the spacer on the bottom of the shock so the spring does not rub on the shock body. You will be amazed how good that shock is for your weight. Get the Custom spring. Whittlebeast and I worked together to figure out good Rubber mount suspension set ups. Again, more details in the "7 Pages of Suspension", or at least to links located there.
Wanna Ride is offline   Reply With Quote
Old 05-04-2011, 10:15 AM   #287
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Originally Posted by Wanna Ride View Post
How do you know the Works damping mechanism is similar to Ricor Intiminators?
I meant that they are similar, in that they are made to work in conjunction with the stock damping unit.
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 05-04-2011, 11:07 AM   #288
Bloodweiser OP
honestly
Bloodweiser's Avatar
Oddometer: 2,628
Yup. Pretty psyched to try out this option, I really want to be satisfied with something cheap
So, are the 09 springs worth holding out for? I've stumbled on lots of custom springs, but none from 2009+
Bloodweiser is offline   Reply With Quote
Old 05-04-2011, 03:32 PM   #289
garandman
Wandering Minstrel
Oddometer: 6,340
Garandman - if money is no object, set your suspension up like mine. See the "7 Pages of Suspension" on the XL Forum for more information. Heavier, more aggressive riders, and riders more aware of what really good suspension is will like the Works fork spring, Intiminators with Amsoil 5w oil better. You also need better tires and fork brace.//
I've ordered or received Intiminators, SuperBrace, Metzler ME880's, and Ricor shocks.
Presumably I need a heavier front spring. I'm also going to have a seat built up to more like a bench.
Also have an eyebrow fairing and drag bars wrinkle-coated black. And the wheels are being powedercoated black as well. Should have it on the road in about two weeks.
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 05-04-2011, 05:13 PM   #290
LostViking
Oddometer: 1,043
My contribution..
"Sailing hard for Vigrid Plain"
LostViking is offline   Reply With Quote
Old 05-04-2011, 05:45 PM   #291
pescatore
Wanderer
pescatore's Avatar
Oddometer: 44
Garandman, do you have a plan for the seat built up more like a bench? I want something like that too, probably will try to hack up an extra stock seat. I'd much rather find something pre-built though...
pescatore is offline   Reply With Quote
Old 05-04-2011, 07:41 PM   #292
Wanna Ride
Oddometer: 84
Before 2009, everybody complained about Sportster suspension on all the models. Starting in 2009 and after, the complaints about stock suspension went down dramatically, so I assume Harley finally got the spring rates and damping curves right. That's probably the reason you see so few shocks from 2009 and later for sale. Since 2009, the most frequent complaint I read about Sportster suspension is from someone trying to ride two up on a model with short travel suspension.
I don't know if there is any difference in different years of Custom springs. Either way, I would be sure to get one with low miles. It depends on how long you want to wait to find a 09 or earlier Custom spring.
I'm 6' 3". I bought a Harley Sundowner seat which moved me forward 1", but then added 2" extra padding and a Air Hawk seat cushion on top of that. Go up and forward, not backwards, with the seat.
That may be true, but I doubt the damping mechanism and characteristics are similar. I'll have to wait until I read ride reports about the Works insert. My suspension testing days are over, at least until I buy another bike.
Wanna Ride screwed with this post 05-04-2011 at 07:47 PM
Old 05-05-2011, 06:18 AM   #293
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,857
I will be working on a bench seat for my Sporty in a couple of months. If it comes out like I hope it will I may be willing to build 2. Here's a Photoshop drawing I did.
Ginger Beard is offline   Reply With Quote
Old 05-05-2011, 06:43 AM   #294
garandman
Wandering Minstrel
Oddometer: 6,340
I'm going to take a stock solo seat and the pic wishing4woods made to the local auto/marine upholstery shop and say "build this!"
They did a great job building up an SV650 saddle for $100.
Old 05-05-2011, 01:34 PM   #295
Terrytori
Namaste
Terrytori's Avatar
Oddometer: 1,837
Nice design.
terry
2014 Triumph Bonneville Scrambler, 2015 KTM RC390
Terrytori is offline   Reply With Quote
Old 05-05-2011, 02:00 PM   #296
pescatore
Wanderer
pescatore's Avatar
Oddometer: 44
Originally Posted by Terrytori View Post
Nice design.
Yeah, that looks about right. I might try the same trick with a local shop. I have an extra stock seat that's just screaming for some experimentation.
Old 05-05-2011, 02:45 PM   #297
Ginger Beard
I have no soul
Oddometer: 6,857
Do it and don't forget the pics!!
Old 05-05-2011, 06:00 PM   #298
garandman
Wandering Minstrel
Oddometer: 6,340
It's at the shop but will take two weeks.
I asked them to make a seat with a bench shape and the top parallel to the seat base. They are going to use some high density foam to build up the dip, but aren't really sure how it will look just yet.
Old 05-06-2011, 10:14 AM   #299
nachtflug
infidel
nachtflug's Avatar
Oddometer: 46,952
Originally Posted by Kirk the Jerk View Post
Wanted to resurrect this thread a bit... Added some "goodies" to my motor recently...
Built for "Go-Fast"
Probably gonna swap the tires to something a bit less aggressive now that I've got an Enduro
that bike is a set of pro taper handle bars from me sending you a blank check.
love it.
nachtflug is offline   Reply With Quote
Old 05-07-2011, 09:58 AM   #300
garandman
Wandering Minstrel
Oddometer: 6,340
Here's the front wheel with the semi-gloss black powdercoat and new Metzler. I'll have the other wheel this afternoon.
Now if the RMV would just un**** the title situation, I would be able to ride it!
Times are GMT -7.   It's 11:50 PM.
