Old 05-13-2011, 08:32 AM   #331
Bloodweiser OP
honestly
Bloodweiser's Avatar
Oddometer: 2,617
crack - sporster sport shocks are supposed to be super cool for light riders.
http://cgi.ebay.com/ebaymotors/98-Ha...item2c5ca1b783
Bloodweiser is online now   Reply With Quote
Old 05-14-2011, 10:32 AM   #332
Wanna Ride
Oddometer: 84
The Sundowner seat moves you forward because it has a flatter seat area. The stock seat has a depression you sit in, and forces you back. I can't compare the two directly because I added foam to my Sundowner. Another plug for the Sundowner is women really like them, especially if they have a back rest to lean against.
When I wrote the "7 Pages of Suspension" on the XL forum, the site would not accept all 14 pages, so I had to break it up. They are in the suspension sticky section, and have links to each others, so they are easy to find. I just wanted a unique name to avoid getting mixed up with other suspension threads.
Over the years, Whittlebeast, myself, and others tested most of the common shocks and different suspension set ups. There are options that range from cheap to the most expensive. It is your responsibility to do your research and decide which direction you want to go.
Since 2009 Harley improved the stock shocks enough that few people are changing them out. That's why they are so hard to get now.
My general recommendation is to start with Ricor Intiminators in the forks, regardless of rider weight, riding style, or bike. They are that good, and make the single biggest improvement. That has been verified by many different people, and on many different bikes / forums. There have been people who added them and did no other suspension modifications.
A 170 lb rider may well be good with the stock fork springs and shocks after adding the Ricor Intiminators, especially with the 09 and later bikes. After adding Intiminators, it is common to reduce shock preload, which is what a 170 lb rider needs. The Intiminators reduce the phenomenon called front to rear coupling which occurs when a stiff fork transmits the force of road bumps back to the shocks and puts additional preload on them.
If you have the money, buy everything at once and then you only have to do things once. However, it is also possible to do one step at a time, test ride for awhile, and not do anything else if you're happy with it. There have been people with the short suspension doing just that, but not stopping until they replace the forks and shocks with full length components.
Riders at the extremes of weight, 140 lbs or 260 lbs will likely need to change springs to better match their weight.
I forgot to mention, Harley offers (or did offer) a two up shock for the low bikes. I have only read a few reports about it, but they appeared to work well.
The 1200S shocks are also getting hard to find, and they are now old, so getting a good pair with low miles is even harder. They have a light spring which is good for lighter riders on the rubber mount bikes.
I also tried the FXDX shocks, but I don't know the year. The final spring rate was too stiff for my 270 lbs. They scared me a few times when the tire skipped out over a series of bumps in a corner because the spring was too stiff.
The Works Dual Rate fork springs are actually 2 different springs sitting on top of each other. There is a "cross over spacer" in the shorter spring. The cross over spacer is a metal tube that limits the travel of the shorter spring. You can change the length of the cross over spacer to adjust the point in fork travel where the spring transitions from the soft initial spring rate, to the harder final spring rate. By adjusting the crossover spacer length, the same springs can work for a 300 lb aggressive rider on a Roadster, to a 140 lb rider on a Nighsters. It is the most versatile spring available.
Progressive Suspension offers different fork springs now. The standard spring is good for riders in the 180 lb range with the long forks. The Drop In Lowering Spring Kit is designed to lower the full length forks. Be careful to not get them mixed up. Last I checked, they don't have a specific spring for the short forks. They do recommend their standard spring, but short forks don't have enough travel to allow the spring to transition to the harder final rate, so it may feel to soft for heavier, more aggressive riders.
Any questions I missed?
Wanna Ride screwed with this post 05-14-2011 at 10:50 AM
Wanna Ride is offline   Reply With Quote
Old 05-14-2011, 11:28 AM   #333
gumshoe4
Oddometer: 855
First let me say to WannaRide that I appreciate the detailed information. I have also reviewed it over on the Sportster website, but I must admit I'm still a bit confused. It's awesome that you guys have put that much work and effort into the matter and I, for one, really appreciate it.
So I weigh about 285 with gear on and ride solo all the time. I don't currently own a Sportster, but have been checking them out for a long time and I'm drawn to the Nightster, in particular and the Roadster also. The sales folks in the dealerships keep shoving me away from the Sportys because of my size, but I like the Sportys and I have to believe they can be made to work for someone like me...
I know a lot of this (how the ride feels to me, for example) is subjective, but I'm looking for reasonably good handling and a ride which won't jar the fillings out of my teeth. Sounds like Initiminator front, but still not clear on what to put on the back...want to have reasonable travel in the suspension, so it doesn't bottom out or throw me out of the saddle.
RK air springs? Progressive longer travel tuned to my size? The two-up springs?
gumshoe4 is offline   Reply With Quote
Old 05-14-2011, 12:12 PM   #334
Wanna Ride
Oddometer: 84
I weigh 270 in gear and typically have additional 30 lbs of back rack and tools. Being an old dirt biker / racer, I know how to set up suspension correctly and have the riding skills to pass the "slower" sport bike riders in the twisties while on my Roadster. Most of them have never been passed by a Harley (XR riders excluded) and seem to get a bit confused when they hear the Harley noise coming up from behind. When they turn around to look, I know I have them beat. In addition, my Roadster is comfortable enough to ride all day, I frequently ride 300 miles a day, most all back road twisties. I could easily double that if I stayed on highways, but I always end up home at the end of the day.
So, despite what most people think, the rubber mount Sportster can be set up to be a really good all 'round bike. The real problem with rubber mounts is the junk suspension Harley and the aftermarket suspension companies have been selling throughout the years. Don't take my word for it, there are many guys on XL forum who have learned the same lessons. Most dealers know surprisingly little about how to make a Sporster, or any other Harley, how to handle well.
It should be your decision, not theirs. If you decide to go with a Sporster, and cannot find a Roadster, you should give serious consideration to putting longer forks and shocks on, especially if you expect any significant handling performance. The bikes with short forks have problems with low cornering clearance, and there is no way around that except raising the bike. It depends on how much you want to spend and how much you like working on bikes. Keep in mind, only the Roadster and XR have dual disc brakes in front.
The RK air shocks will work for you. Be sure to get the long version, 13 1/4", I think. Lots of people like them, but they are not nearly as good as a Ohlins or Ricor set up correctly for you.
Progressive Suspension does not do any custom shock set ups, your only choice is standard or heavy duty springs. You will need the heavy spring. The cheapest 412 with heavy spring should be OK for a cheap shock, but if you consider their more expensive shocks, you might as well spend a bit more and get the Ricor shocks, custom tuned for you. You can find a lot of used Progressive Supension shocks on ebay, not everybody likes them.
I would also highly recommend Ricor Intiminators and Works Dual Rate fork springs which can be used in any rubber mount fork.
The beauty of the Sportster is its versatility to be set up in so many different ways. It is a rough bike by modern standards, but that's the character that guys love about it. By contrast , I rode a Yamaha Warrior. It is perfect, I could not find a single thing to complain about it. But I did not buy one.
To be honest, some of my friends who bought Sportsters sold them after a few years and moved on to other bikes better designed to meet their particular riding style. Sport tourers like the Honda ST 1300, Ducaties for track days, Adventure bikes for light off road work. Other people intend to keep their Sporty forever, its the other bikes that come and go.
I don't want to take anything away from this forum, but there is just too much to explain about suspension set up to repeat everything I have already put on the XL Forum. If you want to spend the money, all you really have to do is duplicate my suspension set up, which is detailed in the "7 Pages of Suspension" over there. At your weight, no stock suspension on any brand middle weight bike will work well without serious modification. At least I have never found one.
Wanna Ride screwed with this post 05-14-2011 at 12:37 PM
Old 05-14-2011, 12:20 PM   #335
treysmagna
Bald is beautiful
treysmagna's Avatar
Oddometer: 684
Sportsters in the Yukon
This is a pic of my 1200S and my friends 1200Custom when we rode them from Houston to the Artic Cricle in 2005!
treysmagna is offline   Reply With Quote
Old 05-14-2011, 12:55 PM   #336
Crack Monkey
Crack Monkey's Avatar
Oddometer: 148
Nope, I think you got them all.
I do have two additional questions...
How much of an effect does riding two up have on the required fork spring rate? Suppose I'm fine solo with the stock, full length fork and spring, w/ Intiminators. Once I add a 150lb of wife and gear to the back of the bike, is it safe to assume the stock fork spring is now overloaded (and I should probably just go ahead and install some progressive rate springs while I have the fork caps off to do the Intiminators)?
Also, once Intiminators are installed, is there any significant gain to be made by adding air valves to the forks? Or, is that mostly for running stock forks?
For the rear, I'm pretty sure I'll skip the less expensive options and save for some Ricors or Ohlins.
Crack Monkey is offline   Reply With Quote
Old 05-14-2011, 01:17 PM   #337
Crack Monkey
Oddometer: 148
They get a larger commission on bigger ($$$$) bikes. They did the same to me and I'm 5'7" and 170lbs (so the big bikes are BIG to me). The anti-Sporty vibes from most Harley guys was almost enough to put me off the bike. Only in American is a 883cc, 50hp bike considered a chic bike.
But, I'm glad I went with it over the other standards I was considering (SV650, Bonneville). It was less expensive, less maintenance, and probably less likely to get me in trouble (slower, lower, the engine doesn't feel like it needs wound up to get moving - overall just a more relaxed ride).
I'm the only one of the my friends with a Harley. But, of all the bikes, it's probably one of the best all-around bikes. The only other bikes that are similar are the modern Bonnevilles. Sure, the supermotos are fun hooligan bikes, but they suck for actually going places on pavement. The dual-sports are better on trails, but too tall for stop-go traffic and buzzy on the highway. The crotch-rockets are better on the super-slab, but they aren't cheap, and they're really easy to get into trouble (legally and physically).
Sometimes I wish I bought a Bonneville instead. But, if I had, I'd probably wish I had a Harley.
Old 05-14-2011, 01:45 PM   #338
Wanna Ride
Oddometer: 84
[How much of an effect does riding two up have on the required fork spring rate?
Two up actually tends to lift the front end a bit because so much weight is so far back. The real problem happens when you hit the front brakes hard and get a lot of fork dive. Or hit a big bump and bottom out the forks.
If you rarely ride two up, don't go very far, stay on relatively smooth roads at moderate speeds, you might get away with stock forks. It also depends on what bike you have. For example, the 07 Nightster spring is too light for anybody. The 09 Roadster stock spring will probably be OK, especially after adding Intiminators.
Air forks are an easy way to compensate for too soft a fork spring, and are the easiest way to be able to adjust from solo to two up riding. The problem is they put more pressure on the seals, so it is better from that perspective to get the correct spring first and use the air valves as fine tuning.
What bike do you have? How much do you weigh, and how hard do you ride solo?
Old 05-14-2011, 02:05 PM   #339
Crack Monkey
Oddometer: 148
2006 XL 883 (plain-jane Sportster).
170lbs, usually don't carry anything but a rain jacket and a water bottle.
Average rider, not aggressive.
Two-up will be rare, and only local.
Old 05-14-2011, 02:49 PM   #340
Bloodweiser OP
honestly
Oddometer: 2,617
Old 05-14-2011, 04:20 PM   #341
gumshoe4
Oddometer: 855
Points taken and I appreciate the response.
It's kinda what I figured all along.
Time to start checking CL and stop fooling around with the dealers; then have enough money set aside to do the suspension upgrades.
Thanks again!!
Bob
Old 05-14-2011, 05:04 PM   #342
garandman
Oddometer: 6,163
Gumshoe, I paid less thsn $4k for an 05 Roadster - riders like those here or XL forums favor them but the Harley dood crowd does not.
The other "rider's bike" seems to be the FXDX but they have often been modified enough that it would be a lot of effort to take off all the gingerbread. And private sale 09 XR's have dropped below $8k.
garandman is offline   Reply With Quote
Old 05-14-2011, 08:25 PM   #343
Birdmove
Birdmove's Avatar
Oddometer: 1,740
An Xl883R or XL1200R was what I would have liked to have bought. But I work at an HD dealership, and we took a nice 2006 XL883 in on trade. I got an employee discount and got it for $4062 in Dec of 2008 with 3000 miles. Other than one slight rocker box gasket leak, it's been a model of reliability.I mistreat it by riding in rain all the time and in very cold temps too. My Sportster IS my transportation. It's got tank scratches from my tank bag; some rust here and there; some oxidation on the fork legs.
I'm happy to have another Sportster as my 20 somethingth motorcycle. I had missed my 1984 XLX1000 that I bought new that year. I've owned a lot of dual sports over the years and street bikes. My darn Sportster is just a great do it all street bike for me. I can count on it totally to get me to work and back every day.
Jon
Jon in Keaau, Hi. USA
2008 SYM HD200 (wife's ride)
2009 Kymco People 150 and coming soon, another dual sport mc
Birdmove is offline   Reply With Quote
Old 05-14-2011, 09:12 PM   #344
Wanna Ride
Oddometer: 84
First fix whatever bothers you the most. It depends on how much you want to spend in terms of money and effort.
Start off with setting front and rear rider sag correctly, 1/3 to 1/4 total travel. If you don't bottom out , you might be able stay with the stock springs. If you then want a better ride, try Intiminators in the forks. If you still want be better, get better shocks. Then fine tune the forks to better match the shocks.
Progressive fork spring and shocks will be a bit better than stock, even better with Intiminators.
RK air shocks are cheap and carry two up, but may be a bit stiff at your weight solo. The Whittlebeast hybrids will be good solo. Other aftermarket shocks are hit and miss, but standard springs should work fine for you.
Ohlins and Ricor are the best, and can be the most comfortable, but not cheap.
Then upgrade tires and add fork brace. Make sure the drive belt is not over tightened, it can jerk the engine backwards over bumps and cause nasty handling and wobbles.
Old 05-15-2011, 06:33 AM   #345
Bloodweiser OP
honestly
Oddometer: 2,617
What Ohlins model are you talking about? 36e? 745?
Right now, Ricors are $629 and cheapest Ohlins are $555.
I bet you're going to tell me that the Ricors are worth the extra dough at this price, but what when the ricors jump back up to $800+ ?
edit: and whats the preload adjustment on the ricors, screw type or clicks?
Bloodweiser screwed with this post 05-15-2011 at 06:51 AM
Times are GMT -7.   It's 06:22 AM.
