Old 03-28-2014, 08:36 PM   #3796
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 501
Originally Posted by r1oors View Post
Nice! And I know the feeling about putting your own touches on it. Due to our extended winter season, I've only put maybe 5 miles on my 883R since I got it in January. But I've already spent about $150 and planned another couple hundred on it, making it mine.
$150???........Spending money on a bike, any bike, is done in the minimum increment of $500........
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 03-28-2014, 08:43 PM   #3797
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,844
I've only put maybe 5 miles on my 883R since I got it in January. But I've already spent about $150.
Thats $30 of farkles for every mile ridden! We're gonna need you to work on that ratio.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 03-28-2014, 09:05 PM   #3798
pvt joker
Latebird
pvt joker's Avatar
Oddometer: 158
My sportster is as about as far from an investment as you can get but my cost so far has been about 45 cents/mile, minus gas, including the cost of the bike and all I've put into it. And its still worth roughly what I paid for it.
The blast I get out of riding it = priceless.
pvt joker is offline   Reply With Quote
Old 03-29-2014, 09:32 AM   #3799
r1oors
Oddometer: 46
Cool2
Yeah, well those are under-the-radar dollars.
r1oors is offline   Reply With Quote
Old 03-29-2014, 11:59 AM   #3800
Redclayrider
Long time gone
Redclayrider's Avatar
Oddometer: 927
Thursday night GP8 are back! More fun than a hot woman, a gallon of moonshine, and a barrel of Wesson oil!
Well, all most as much fun.
The XR did not do to bad......the old fart riding it is another story.
Redclayrider is offline   Reply With Quote
Old 03-29-2014, 02:31 PM   #3801
jzink0883
Oddometer: 1
Alkay191's 14.5" shocks?
Alkay191,
I saw your post about the extended-length shocks on your Sportster.
Questions:
- Any modifications needed to fit 14.5" shocks to a rubber-mount Sportster?
- Are you using stock 883R/1200R forks?
- Any fork-wiggle issues with the reduced rake?
Thanks,
jzink0883
jzink0883@me.com
jzink0883 is offline   Reply With Quote
Old 03-29-2014, 09:58 PM   #3802
Scot229
Oddometer: 14
1st and 2nd ride of the year
First ride was a couple weeks ago it was only 31 degrees but I couldn't wait any longer. Did a 36 mile loop out and back chasing a tag for the GLMC photo tag game looking for an Irish pub. Someone else beat me to the tag but it was good to get out riding for the first time this year.
Might not sound like much but I put 130 miles on my 1200 today. This is Minnesota in the end of March. Temperture ranged from 38-42 degrees.
I like Sportsters
2005 XLH 1200
2003 XLH 883
1974 XLH 1000
1996 FLHTCU
Scot229 screwed with this post 03-29-2014 at 10:07 PM Reason: add another picture
Scot229 is offline   Reply With Quote
Old 03-30-2014, 03:27 AM   #3803
gus
gus's Avatar
Oddometer: 918
Nice 1974 XLH. I have a '74 XLCH. I bought a '74 XLH when I was in High School in 1975.
I took my MC license test on it when South Carolina started with the motorcycle endorsement about seven years before it was mandatory. I had many good memories on that bike.
gus is offline   Reply With Quote
Old 03-30-2014, 06:54 AM   #3804
AlKay191
AlKay191's Avatar
Oddometer: 327
Originally Posted by jzink0883 View Post
Alkay191,
Questions:
Thanks,
jzink0883
jzink0883@me.com
My Sporty is rigid mounted and I didn't have any isuues. Not sure if rubber-mounted are any different. I doubt it.
Stock 883R forks are not adjustable like 1200r or 1200S. Mine have Race Tech springs and Emulators.
You would not notice any difference from reduced rake by installing taller shocks. It is not that radical that wou;ld cause any ill effects. MAYBE you will notice slight improvement in "turn-in".
I always use fork braces and steering dampers on any bike I put on the track. I don't know if they need it, but its just something I know that helps me go faster. Even if only in my head.
I'm the root of all thats evil, but you can call me Cookie.
AlKay191 is offline   Reply With Quote
Old 03-30-2014, 07:58 AM   #3805
DutchVDub
Oddometer: 1,349
That's good to know, I'm looking to pick up a Sporty this summer to wrench on and was going to use some Burly Brand 15" Stiletto shocks on the rear. I was concerned about the fork rake changes. I'm going for a Café Racer and Scrambler mix. Kind of a home made XR1200 type bike I guess, I haven't fully nailed down the plan.
2008 Honda Shadow 750 Spirit
2013 Victory Cross Country
DutchVDub is offline   Reply With Quote
Old 03-30-2014, 08:13 AM   #3806
Randy
Randy's Avatar
Oddometer: 2,442
Alkay191,
Questions:
Thanks,
jzink0883
jzink0883@me.com
About the longest shocks you can get away with, on a stock rubber mount is around 13.5". Any longer and you'll run into interference problems with the belt hitting the rear master cylinder linkage and the rear exhaust bracket. You can run a different exhaust that does away with the stock mounting bracket, but you'll still need to do something about the master cylinder bell crank issue. It's been done. Just be aware of the need to address these areas.
Reduced rake will depend on what fork length your bike has. It shouldn't present a problem with the longer fork models like the Roadster or Custom. It MAY be an issue on the factory lowered models with the shorter forks. But, if your bike does have the lowered forks, it isn't too difficult to modify them so that they'll have the same travel as the longer forks. I've posted how to go about this earlier in this thread.
The Sportster has fairly relaxed geometry so I wouldn't think it will present a problem, but any time you make a significant geometry change it pays to start out slow and test for stability issues before just accepting that all will be ok. You don't want to discover a handling quirk while leaned way over in a bumpy corner.
"some might call it a 'midlife crisis', I prefer to call it a renaissance of thought and action"... "Life is too short to do anything other than that about which you are absolutely passionate."..."Adventure is a frame of mind, set upon by action, not defined by equipment."..."It all boils down to your ability to say "SCREW IT" and really mean it"....Randy
Randy screwed with this post 03-30-2014 at 08:58 AM
Randy is offline   Reply With Quote
Old 03-30-2014, 10:59 AM   #3807
Birdmove
Birdmove's Avatar
Oddometer: 1,814
I believe that the Custom model Sportsters came with the longer fork tubes, but had shorter shocks. I'm not talking about the model they now call the Custom. I'm talking these:
http://i11.photobucket.com/albums/a1...3/P1010542.jpg
They came with a 4.5 gallon tank, forward controls, 21" front spoke wheel, different headlight, kind of a flat handlebar, etc. Has a solid rear wheel. I rode one that had rear mounted pegs and brake, and shifter, and liked it a lot. I think this model really started with the rubber mount and new frame. But They had a Custom model before that, but they used the peanut tanks. This would be another model that a guy could buy, put on longer shocks, maybe mid controls, and have a decent cornering Sportster. I like the bigger tank all right, and would appreciate the longer range.
If I'm wrong on the dates of this model, Bueller will know, and please correct me.
Jon in Keaau, Hi. USA
2008 SYM HD200 (wife's ride)
2009 Kymco People 150 and coming soon, another dual sport mc
Birdmove is offline   Reply With Quote
Old 03-30-2014, 12:17 PM   #3808
Randy
Randy's Avatar
Oddometer: 2,442
Yep the Custom had the same longer fork damper rods as used on the Roadster. I discovered that when I was researching the part numbers for increasing the fork length/travel of my factory lowered 48 forks. Of course you can get that length out of any of them with just a change of damper rods. The Custom did come with the largest Sportster tank, but it also came with a sorta funky bar riser set-up. Not a huge deal if you like it, but it does add to the cost of changing things if you don't. And then there's the 21" front/16" rear wheels. Again, just depends on what you like and want to do with the bike...
Old 03-30-2014, 03:10 PM   #3809
rodteague
Enjoying the ride
rodteague's Avatar
Oddometer: 510
If you put rear shocks greater than 13.5" on a rubber mount sportster; you'll have to put a REAL belt tensioner on the swing arm or mounted low on the frame. The Burly scrambler has a tensioner along with their 15" Stilleto shocks. Probably can give Burly a call and they should be able to step you through the modification.
Rod
All I do is muddle thru life, making sense of only a portion of it.
http://libertytreeblogs.blogspot.com
My Multi Purpose Sportster (MPS)
rodteague is online now   Reply With Quote
Old 03-30-2014, 03:22 PM   #3810
Randy
Randy's Avatar
Oddometer: 2,442
Rod
OR, relocate the exhaust and rear master cylinder....
Also, if you go too long you may run into issues with the upper run of the belt/chain rubbing on the top of the swingarm pivot.
Here's a pic showing how one builder addressed both issues....
Times are GMT -7.   It's 09:20 PM.
