Old 03-30-2014, 03:25 PM   #3811
DutchVDub
Oddometer: 1,310
Is there a build thread for that? Its very much along the lines of what I have in mind.
2008 Honda Shadow 750 Spirit
2013 Victory Cross Country
DutchVDub is offline   Reply With Quote
Old 03-30-2014, 03:26 PM   #3812
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,311
^No belt, no cush drive, no thanks.
HapHazard is offline   Reply With Quote
Old 03-30-2014, 03:49 PM   #3813
Randy
Randy's Avatar
Oddometer: 2,358
Yeah, it's one of my main inspiration bikes for one of these days...
No build thread. It's a bike built by Wrench Monkees...
http://www.wrenchmonkees.com/motorcycles/monkee-28.html
"some might call it a 'midlife crisis', I prefer to call it a renaissance of thought and action"... "Life is too short to do anything other than that about which you are absolutely passionate."..."Adventure is a frame of mind, set upon by action, not defined by equipment."..."It all boils down to your ability to say "SCREW IT" and really mean it"....Randy
Randy is offline   Reply With Quote
Old 03-30-2014, 04:59 PM   #3814
woodnbow
woodnbow's Avatar
Oddometer: 1,813
It's surprising how much of an issue this isn't...
"Be polite, be professional, but have a plan to kill everybody you meet." General "Maddog" Mattis
woodnbow is offline   Reply With Quote
Old 03-30-2014, 05:35 PM   #3815
DutchVDub
Oddometer: 1,310
I'm looking at all sorts of builds for inspiration. I really like these two Burly Brand bikes
I want to combine the two and add some XR750 into the mix.
Old 03-30-2014, 05:50 PM   #3816
Randy
Randy's Avatar
Oddometer: 2,358
This was discussed a while back...
I'm still not 100% sure it's not an issue. Maybe it isn't, then again maybe it could be. I know that chain conversions are commonplace. Then again, I know that my old XR600 that I converted to D/S use didn't have a cush drive either (the factory D/S XL600 and XR650L did), and it grenaded the tranny. Cush drives on street bikes do serve a purpose, and one of them is to isolate the transmission from shock loads.
I forget the details of the earlier discussion, but I think I remember that if you are concerned about it, there's is a cush drive hub available....
Old 03-30-2014, 05:51 PM   #3817
DutchVDub
Oddometer: 1,310
Is that what the clutch is for?
Old 03-30-2014, 05:52 PM   #3818
Randy
Randy's Avatar
Oddometer: 2,358
Yep, since I don't have the funds for a build right now, I've just been researching, collecting inspiration pictures, and dreaming....
I assume that you've found the build threads for the Burly bikes? Both of them are in my pic folder.
Old 03-30-2014, 05:52 PM   #3819
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,639
Go Sportsters
I've not had any issues, I only have about 20,000 on the chain conversion. which isn't long term proof, but I'm comfortable.
johnwesley is offline   Reply With Quote
Old 03-30-2014, 05:55 PM   #3820
DutchVDub
Oddometer: 1,310
That's how I found the bikes, by looking up Sportster Café build and Sportster Scrambler build on google.
Burly Scrambler
Burly Café Build
Old 03-30-2014, 05:55 PM   #3821
Randy
Randy's Avatar
Oddometer: 2,358
Yeah, some bikes have the cush drive built into the hub and some have it built into the clutch. But no, a standard non-cush clutch or hub doesn't isolate the transmission from shocks like a cush system does. If it did, there would be no need for cush drive systems and bike designers wouldn't bother with them.
Old 03-30-2014, 05:56 PM   #3822
DutchVDub
Oddometer: 1,310
How is the new dual sportster coming?
Old 03-30-2014, 06:01 PM   #3823
Randy
Randy's Avatar
Oddometer: 2,358
Yeah, I haven't seen any real evidence that it's an issue on a Sportster. Maybe it isn't. Just from my experience with my XR and similar stories of others, as well as my understanding of cush drives, I'm a little less comfortable with it. Maybe I'm just overly cautious, IDK....
Old 03-30-2014, 06:05 PM   #3824
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,639
Slow, if I could just focus a couple of days to it, I'd be riding. Well I think that's all. I need to take about 10 thousandths off a spacer to center the front brake, wire the tail lights, blinkers and work out the chain tensioner.
Old 03-30-2014, 06:09 PM   #3825
DutchVDub
Oddometer: 1,310
And you're using a KTM 525 fork/clamp setup?
I don't think I'm going for that amount of travel. I just want to be able to run down fire roads and similarly maintained dirt roads, not go full off-roader with it.
Times are GMT -7.   It's 01:01 PM.
