Old 06-06-2011, 07:57 PM   #526
christoz
Oddometer: 11
Originally Posted by bobbed06 View Post
Look for signs of wrenches on the cylinder bolts. The 883 was way slower than the 1200 so if yours is fairly quick its a good chance it has the 1200 cylinders in it. Snag a ride on a 883 and compare?
Other than that, you could remove a rocker box and measure one cylinder.
Thank you. This bike was sitting in a box this time last year. It has been touched by a lot of hands. Lots of tool marks everywhere on it!
I would say this bike is sluggish. I guess I was expecting this bike to kinda scare me if I really wound it out if it was a 1200. I only have a few hundred miles on the street, might have been expecting a bit much.
Any idea about my carb comment?
christoz is offline   Reply With Quote
Old 06-06-2011, 08:45 PM   #527
83XLX
83XLX's Avatar
Oddometer: 426
If you can see the top of the piston well enough through the spark plug hole, many 883 to 1200 conversions are done with dished pistons (concave). If you see that, it's a 1200. If it has regular flat top pistons, it still could either size.
83XLX is offline   Reply With Quote
Old 06-06-2011, 09:41 PM   #528
Wanna Ride
Oddometer: 84
I don't know the actual dimensions, but I have read that if you put the piston at bottom dead center, then use a straight rod to measure from the spark plug hole to the opposite side at the bottom of the cylinder. That dimension will be different for 883 and 1200.
Wanna Ride is offline   Reply With Quote
Old 06-07-2011, 07:13 AM   #529
garandman
Wandering Minstrel
Oddometer: 6,276
Wild...
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 06-07-2011, 12:36 PM   #530
Berto
Berto's Avatar
Oddometer: 1,538
Thats cool,
Berto is offline   Reply With Quote
Old 06-07-2011, 12:42 PM   #531
Richy
Richy's Avatar
Oddometer: 515
You guys got me motivated for a tank bag, so I looked at Craigslist today.
Joe Rocket Manta-$25 It should fit my needs, except my cane doesn't fit in it with the zipper closed all the way.
Richy is offline   Reply With Quote
Old 06-07-2011, 12:51 PM   #532
bobbed06
Cavalera Conspirator
Oddometer: 1,236
No Idea on that carby, The last sportster I jetted was a 1200S with a stock carb. Completely different animal.
That bike looks very nice. You should committ and cutoff those old fender struts, unless you need them for saddlebags or something else...
bobbed06 is offline   Reply With Quote
Old 06-07-2011, 01:46 PM   #533
Richy
Richy's Avatar
Oddometer: 515
Nah. You don't see those old Screaming Eagle fenders anymore, I'm not cuttin' it.
Old 06-07-2011, 02:41 PM   #534
Terrytori
Namaste
Terrytori's Avatar
Oddometer: 1,833
Originally Posted by garandman View Post
Wild...
That velocity stack looks like it would suck the neighbor's cat off it's porch.
2013 Ninja 300 ABS, '11 883 Iron ( kicked to 1200), 2013 KTM 690 Duke
http://www.secordgallery.com/gallery...2_itemId=35642
Terrytori is offline   Reply With Quote
Old 06-07-2011, 02:57 PM   #535
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,736
You must have a little southern red neck in you man! Thanks for the laugh bro.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is offline   Reply With Quote
Old 06-07-2011, 03:32 PM   #536
bobbed06
Oddometer: 1,236
Are you saying that the tailsection thats on that is a HD part that requires the rear struts? Just wondering. I have been thinking of building a Sporty for a while now.
Old 06-07-2011, 04:37 PM   #537
Richy
Richy's Avatar
Oddometer: 515
Yes, actually. The seat has the Sportster logo branded into it. That isn't the frame struts you see there, it's part of the seat. It could be done differently, sure, but HD designed the part to cover the struts. They don't go for any frame cutting, as a rule.
Storz and others make different parts that look like this one, but lose the fender struts. If I find a cheap 1200S, I'll be needing them.
Old 06-07-2011, 06:43 PM   #538
bobbed06
Oddometer: 1,236
Good Luck on finding a S model. Its a great bike for a Cafe style build for sure. Thanks for the info on that tailsection.
Old 06-07-2011, 07:12 PM   #539
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,339
Originally Posted by bearcat1 View Post
garandman,
There is a penny tech fix to keep from losing your battery cover. Take a small screw and install it between the plastic tabs on clip that goes throught the frame. The screw forces the plastic tabs apart and effectively locks the clip into the frame. The plastic clip is known to pop out of the frame and you think your battery cover is locked in and it is not, thus the cover flops over. I did this to my Sporty and it works. Supposedly HD has a new improved clip but I'm not so sure it's actually improved and worth the $$. A 2 cent screw solves the problem.
The updated clips fix the problem. They don't cost but a few bucks.
Screws? Wire ties? Jesus. What year is your KLR?
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is online now   Reply With Quote
Old 06-07-2011, 07:18 PM   #540
Crack Monkey
Crack Monkey's Avatar
Oddometer: 148
Also, I had a super e carb installed and it has been jetted as if it was a 1200. Would it even run if it was an 883 with a carb set up like that?
On cold mornings, will the bike start and idle without the choke? That's usually a sign that the jetting is rich.
I imagine the bike would run, but down on power, if it was an 883 and jetted for 1200. But, the stock jetting (CV carb on the 2006 XL anyway) isn't all that far apart between the two - I think the 1200 is just one size larger on the pilot and main and uses the same needle as the 883. But, I've never played with the super e and don't know anybody who has (the CV seems to work pretty well for mildly modified engines).
Crack Monkey is offline   Reply With Quote
Times are GMT -7.   It's 04:37 PM.
