Old 06-29-2011, 05:07 PM   #661
Berto
Berto's Avatar
Oddometer: 1,494
Kirk, what front brake setup are you using? Also where did you get those bars?
Berto is offline   Reply With Quote
Old 06-29-2011, 05:19 PM   #662
nachtflug
infidel
nachtflug's Avatar
Oddometer: 46,669
question. anything post 2004 with the R Roadster designation will = juiced up engine from the factory with dual discs?
nachtflug is online now   Reply With Quote
Old 06-29-2011, 05:22 PM   #663
Bloodweiser OP
honestly
Bloodweiser's Avatar
Oddometer: 2,617
I just picked up a La Rosa solo bag just like that.
I was all set to place an order for a Lick's bag, but I ended up landing a cheap old Honda Dream around the same time.
So for the price of a Lick's I got a La Rosa and a motorcycle
Bloodweiser is online now   Reply With Quote
Old 06-29-2011, 05:24 PM   #664
Bloodweiser OP
honestly
Oddometer: 2,617
all R's have duals.
Motor is the same though. In 04 or 06 they came with thunderstorm heads.
The old solid mount Sport (S) models came dual plugged and a higher compression, I think.
Old 06-29-2011, 07:15 PM   #665
garandman
Oddometer: 6,163
2004-2006 R are "rubber mount Evo" bikes with carb. 07+ is FI.
R's have dual front disks, tachometer, and 13.25" shocks.
2004 Sportster model intro.
2007 Rider Magazine review.
However, the big news in the engines is mechanical. The new motors are still configured like previous Sportster engines, with the same layout, air cooling, bore and stroke, etc. However, they have been strengthened and massaged both to make a bit more power and to stand up to the added revs that riders are likely to demand now that they no longer risk having their fillings shaken out to enjoy them.
The changes start with better cooling. The heads and cylinders have bigger fins, and oil is now sprayed under the pistons to aid cooling. New rings extend cylinder life. Ignition timing is now cued off the crankshaft for more accuracy, though the traditional Sportster timing cover remains. Virtually all the gasket points in the engine have been improved to banish leaks. Both 1200s have the same engine, which makes about 15 percent more power than last year's standard 1200 mill. The new 1203cc engine gets hotter cams taken from the Buell XB engine, though, at 70 horsepower, the Sportster engine makes less power than the Buell's similar engine, largely because the Buell sucks through a much larger airbox (which the sportbike can use because styling convention isn't such an issue). Unlike the '03 Sportster 1200 Sport engine, this will not have dual spark plugs because its combustion-chamber design does not require them to inhibit detonation. The new 1200's compression ratio is 9.7:1, compared with 10.0:1 for last year's Sport and 9.0:1 for the other '03 1200s. Lighter pistons, rods and valve-train components allow the 1200 to rev 500 rpm faster to 6000 rpm.
Read more: http://www.motorcyclecruiser.com/roa...#ixzz1QimMeX3M
In 2005 they got 1" axles.
In 2006 they got powdercoated black motor.
garandman is offline   Reply With Quote
Old 06-29-2011, 09:08 PM   #666
tobiism
Oddometer: 13
My 2000 1200S Sporty
Howdy everyone, name's Matt. I ride a 1200S sportster that I built out of a lowly stocker. Here is a rundown of the specs.
Shorai 1.8lb battery(awesome)
17" Katana wheels 3 and 3.5 with Michelin Pilot Power rubber
ZRX 1200 shocks
RK chain conversion
CBR rear brake
Supertrapp 2-1
CBR daytona damper
fork brace
rearsets
Fly aluminum motocross bars
Plastic flyscreen
weighs 460lbs and goes like stink!
I love this bike. It is exactly what I wanted.
I have to say that if you are going to ride a sporty, do yourself a favor and get an "S" model. They are so smooth with the twin plug MAP ignition. At 80mph there is almost zero vibration in the bars.
Next upgrade is Works shocks and she'll be set.
tobiism is offline   Reply With Quote
Old 06-30-2011, 07:09 AM   #667
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,605
Nice bike Matt!
Lefthand brew, a weber grill and the rocky mountains,...it all goes away!
Utah Bones is offline   Reply With Quote
Old 06-30-2011, 07:12 AM   #668
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,605
Your bike is an evil one....your post 666!
Old 06-30-2011, 07:30 AM   #669
hockeygoon
Oddometer: 542
Man what a first post!
I was scouring for an 'S' model but never could find one, so I got my R and have been happy after undoing the PO's mods to turn it into every other cruiser on the planet.
2000 Kawasaki W650
2006 Harley 883R
2001 Ducati M750 (sold)
hockeygoon is offline   Reply With Quote
Old 06-30-2011, 08:03 AM   #670
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
The rotor is a full floater HD setup, and the caliper is a Tokico 4 piston off a GSXR.
Bars are from a guy who used to run "Rocks Chops." Made them to my specs, but he's no longer making moto parts.
ALL 2004 and up 1200 heads are the same as the Buell XB / 1200R heads, better than Thunderstorms. They are the best performing head on a Sportster.
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas screwed with this post 06-30-2011 at 08:09 AM
Aaron from Texas is offline   Reply With Quote
Old 06-30-2011, 08:39 AM   #671
pescatore
Wanderer
pescatore's Avatar
Oddometer: 43
2006 XL1200R upgraded
Before: (sometime in 2008)
During: (a couple of months ago, loaded for touring)
And after: (a couple of days ago)
Some of the visible changes:
HD large capacity gas tank (4.5 gallons! Just finished this last night and I can't wait to use the new 200 mile range)
Progressive 412s
SuperBrace fork brace
HD pillow top touring seat (not crazy about this, but the stock seat doesn't fit the new tank. I will do something about this soon)
Buckhorn bars - will probably go back to lower bars this winter.
Saddlebag supports will soon be replaced with givi-style racks and a set of E21s on order and the topcase bracket for a JC whitney trunk will be reinforced so I don't have to use a bungee to keep the trunk from bouncing...
Next up heavier fork oil and a steering stabilizer. Maybe some better slip-ons if I can find something I like. And maybe a quarter fairing.
Also, she needs to be washed BADLY.
pescatore is offline   Reply With Quote
Old 06-30-2011, 09:24 AM   #672
Mr Natural
Really tired
Mr Natural's Avatar
Location: Monterey, CA/San Felipe, Baja,MX/Iowa City, IA
Oddometer: 1,435
Originally Posted by gusanito View Post
Changing the rear 16 for a 18 and adding the fairing made a big difference, along with fine tuning the front end. I think it's where I want it to be, so now I'm thinking about what color to paint it. Orange, maybe?
Great day for a ride today in north Fl. on the back roads.
George
I like this, but needs a spoked front wheel. Some other things also that aren't that important, such as rear fender/seat.
I'd powder coat the frame a color other than black. Maybe leave the bike black with an orange frame?
Basic crazy life stuff, Clearanced Navy VN Vet, Army Vet, Walking by credit of VA, Met John Walker, Jerry Whitworth, Chilean riots, Pinochet troops, Cults/MK Deprogramming, Never seen a UFO so nothing I can blame drinking on, but enough about you, what about me?
Mr Natural is offline   Reply With Quote
Old 06-30-2011, 09:36 AM   #673
garandman
Oddometer: 6,163
What windshield is this?
Old 06-30-2011, 09:53 AM   #674
pescatore
Wanderer
pescatore's Avatar
Oddometer: 43
HD Sport windshield, smoked.
*looks around on h-d.com*
This one: http://www.harley-davidson.com/gma/g...bmLocale=en_US
I like it ok. It's a good balance of coverage and style. I think I'd like one of the bigger quarter fairings (Rifle Roadster or Viper, for instance) a little better. I could hide more stuff behind them, they'd probably give a little better wind protection and they'd look better. We'll see.
Old 06-30-2011, 02:15 PM   #675
USGunRunner
Oddometer: 77
I noticed the windshield too. Thanks for posting a link. Looks good.
USGunRunner is offline   Reply With Quote
Times are GMT -7.   It's 09:24 AM.
