Old 03-11-2011, 01:50 PM   #106
ep!c
Pannier Manufacturer
ep!c's Avatar
Oddometer: 210
Originally Posted by BergDonk View Post
On my last ride, just before pulling the bike down to get the bracketry plated, the bike developed a bit of a rattle, and the fuel tank seemed to be moving about a bit, especially when full.
I found the aluminum bracket that connects the two tank 'wings' together and centres on the frame broken.
I decided to make a new one out of steel. Better now than in the Simpson. Pity the plating is finished, so I guess I'll just paint it for the time being.
I collect all the racks and bits tomorrow from the zinc platers.
Steve
Same thing happened to my stock aluminum brace, so I built a new one out of 3/4" square stock. I went a step further and incorporated my useless passenger pegs into the design; by turning them into folding highway pegs that are now attached to the ends of the new brace.....Kind of nice to be able to change up my seating position on longer freeway stretches...
Solobox
360-840-7139
gosolobox@gmail.com
ep!c is offline   Reply With Quote
Old 03-11-2011, 03:08 PM   #107
BergDonk OP
BergDonk's Avatar
Oddometer: 3,359
So perhaps we have a chronic problem with Safari tanks too? Not sure I could get my feet up that high if I had pegs there though, but I do have the option of moving my feet up to the bash plate.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 03-11-2011, 08:27 PM   #108
ep!c
ep!c's Avatar
Oddometer: 210
Steve
Yeah, the stock part is pretty weak. Maybe it's designed to flex and "give" in the event of a crash?? not sure, but I do like the tank. 7+ gal. on a DRZ is kind of overkill though. For off-road riding, I usually only put a couple of gallons in it. Kind of nice to have the fuel down low near the engine, so as to gain a lower center of gravity....
Solobox
360-840-7139
gosolobox@gmail.com
Old 03-11-2011, 08:46 PM   #109
AdventureXR650
Esquire
AdventureXR650's Avatar
Oddometer: 147
Bluhduh Trying to fit stabiliser
Blokes
Got a box of bits for the might XR and pulled of the top triple no worries. Fitting the new stuff is a bit different though. The spigot for the stabiliser goes FORWARD to the place where the speedo would be AND is 20mm lower than now. Raising hangers is not as simple as a Ballards bit as the spigot length is set and reversing the spigot (pointing back to tank) is a lot of filing, the oil filler cap won't fit and it will probably hit on the tank.
Not happy Jan!
Need some beer to do some brainstorming
AdventureXR650 is offline   Reply With Quote
Old 03-12-2011, 06:10 AM   #110
rowdy_im
KTM 625 Snowy Mountains
rowdy_im's Avatar
Oddometer: 378
Originally Posted by AdventureXR650 View Post
Blokes
Not happy Jan!
Bring it down to Jindy a nite in the shed will fix it
just spent 5 hours putting the orange girl back to gether
Rowdy
rowdy_im is offline   Reply With Quote
Old 03-12-2011, 03:29 PM   #111
BergDonk OP
BergDonk's Avatar
Oddometer: 3,359
I doubt its designed to flex. What I also noticed that with it broken, the tank spread a bit and is not fully supported on the stock frame top tube rubbers. I suspect that more riding with it broken could be a real problem. Should be fixed now though.
A mate recently purchased a new DR and Safari tank for it and I sent him the pics. He said that his bracket is completely different to the one I had, so maybe its sorted now?
And the size is still a bit small. For the Simpson we need 600 km range in sand. Its 600 km now, but not in sand. But you're right, you don't have to fill it, and its then arguably better positioned on the bike than in the stock tank.
And I found my VSM chain catcher has broken too. I'm trying to decide whether to repair it, or do what i should have done in the first place, and make my own. I'll post a pic later.
Still, this was the idea, get a bullet proof bike, and set it up for a big trip, and test everything before I go so I know what works and doesn't. Hopefully no more surprises
Steve
BergDonk screwed with this post 03-12-2011 at 03:34 PM
Old 03-12-2011, 03:31 PM   #112
BergDonk OP
BergDonk's Avatar
Oddometer: 3,359
Blokes
Not happy Jan!
I got a new angle grinder the other day if you want a lend. You can pick it up on the way through if you like
Old 03-12-2011, 04:10 PM   #113
Bushmechanic
Bushmechanic's Avatar
Oddometer: 70
Trying to keep it a bit simpler than Snowy, maybe, and I don't want a broken bit in the Kimberly or Simpson later this year, so some 5 mm and 3 mm plate, and someone who knows 6061 ally and TIG, and voila:
The bearings were removed, and the plates were fitted over the existing welds. The arm was held in a jig while it was done. No material was removed. Notice how little heat was used, the only clear coat removed was done mechanically, none burnt.
Steve
Awesome Steve !
good preemptive strike, I like the tapered ends of the patches lining up with the shock mount
2008 Husaberg 700F 104kgs all fluids no fuel
frame build http://www.husaberg.org/forum/viewtopic.php?f=8&t=13268
engine http://www.husaberg.org/forum/viewtopic.php?f=5&t=12131
Bushmechanic is offline   Reply With Quote
Old 03-12-2011, 04:26 PM   #114
BergDonk OP
BergDonk's Avatar
Oddometer: 3,359
Originally Posted by Bushmechanic View Post
Awesome Steve !
It will not break where Snowy has broken it
Yeah, not only have I got to test the DR to destruction before the off, but I'm setting up 2 support 4wds with long range tanks, water tanks, suspension, awnings, CBs etc etc.
Gotta go out to the shed now and buld a new chain catcher.
Steve
Old 03-12-2011, 11:32 PM   #115
ep!c
ep!c's Avatar
Oddometer: 210
Steve
One thing I've learned to love/hate......There will ALWAYS be more surprises Have a good trip and ride safe!
Solobox
360-840-7139
gosolobox@gmail.com
Old 03-12-2011, 11:39 PM   #116
nolana
what's that skip?
Oddometer: 8
Rewa's one broke in exact same spot after dalhousie somewhere and we got in touch with aqualine once in alice. Defo a prob with orig design. He sent the new part to alice for us foc (which was great) and we had no probs with the new one for the remaining 3-4000 km that we had the bike. Can't remember the exact difference to be honest, but I'm sure your will be strong.
2008 Husaberg FE650
2008 Sherco 290 Trials
nolana is offline   Reply With Quote
Old 03-13-2011, 09:31 PM   #117
BergDonk OP
BergDonk's Avatar
Oddometer: 3,359
Chaincatcher.
I always use a clip master link on my dirt bike drive chains and have never had a problem. Nevertheless, I like the idea of a sold chaincatcher to reduce the chance of a broken case if something goes wrong.
I got a VSM catcher sprocket cover http://www.vincestrangmotorcycles.co...ase_saver.html
Unfortunately the top monting tang has broken off. Its 4 mm aluminum sheet with a sharp crease so a stress induced fatigue failure perhaps. There is a lso a witnes mark on the underside from the chain contacting it which wouldn't have help. Probably related to the top chain rollers coming out. I did lose mine so when reinstating it, raised it a couple of mm, so this probably didn't help either.
There is not a lot of space in front of the sprocket with a 16t c/s sprocket, and the VSM unit handles a 16t. Having decided on a 15t, I had a bit more room to play with.
I cut up a bit of 10 mm plate to suit. Its spaced 4mm from the cases and centres on the chain. The cover plate is spaced 11 mm from the 10 mm plate.
I used a hole saw to shape the inner circle, and a aluminium cut off disc in an angle grinder to trim the outside. The 4 mm spacers are captive, ie some sheet screwed to the inside, and the cover is 4 mm sheet spaced off the plate that's been drilled and tapped for 6 mm bolts. Spacers were a bit of tube I had lying about, pared off in the lathe. All scrap I had in the shed.
I used the original as a template, and because its flat, its pretty straightforward.
Hopefully this sorts it.
Now to fit the upgraded swingarm. Notice its being cleaned too
Steve
BergDonk screwed with this post 08-12-2011 at 08:06 PM Reason: more detail requested on how
Old 03-20-2011, 01:24 AM   #118
BergDonk OP
BergDonk's Avatar
Oddometer: 3,359
Got the racks and other bits and pieces I've fabricated from steel zinc plated and fitted back up. Also got the upgraded swingarm fitted too. Any takers for the standard one?
Steve
Old 03-20-2011, 01:36 AM   #119
rowdy_im
rowdy_im's Avatar
Oddometer: 378
Looks all nice there Berg Donk, wish i had the time to tinker like you
I am getting there sub frame and rear suspension all overhauled and refitted ,just need to make that safari tank bracket and change the oil ,fit pannier racks and the bashplate /water tank
then double check all equipment to take
cheers
Rowdy
Old 03-20-2011, 01:38 AM   #120
BergDonk OP
BergDonk's Avatar
Oddometer: 3,359
Not the best picture, but here is the LED driving lights.
They came from ebay and are 1500 lumens and 30w each, 3 x 500 lumens LEDs each. $150 for the pair. When I initially looked I interpreted the specs as 30 w total, not each, wrong.
I did a test and found that with high beam and the grips on low it was OK but with the grips on high I dropped 0.3 v. Not terminal, but not ideal. Bump starting in the desert isn't first choice.
Back to ebay and a 35 w HID H4 conversion for $60 delivered and a LED tailight bulb and I've saved 25 w or so and its all good.
From what I can figure out, a stock 60/55 w H4 puts out about 800-1000 lumens and the 35 w HID over 3000. Whatever, its all a substantial upgrade in light, and although the LEDs pattern isn't wonderful, its heaps better than none at all and takes a lot of the guesswork out of riding at night. Recommended.
Steve
Times are GMT -7.   It's 03:59 AM.
