Old 12-30-2010, 10:24 AM   #16
digdesign
Hack
digdesign's Avatar
Oddometer: 151
Dave this sounds great. Sounds like you're going to address all of the little issues I see with the currently available options. I especially like that you recognize the lean angle issue. Count me in.
2010 F800GS
2009 Buell XB12Scg FOR SALE
1990 E30M3 track rat
digdesign is offline   Reply With Quote
Old 12-30-2010, 10:49 AM   #17
3Rrr
Read Ride Reflect recycle
3Rrr's Avatar
Oddometer: 170
Thumb
How about having two different sizes (heights) available - maybe simple with spacers.
It would accomodate for having the 140/80 taller sidewall and stiffer rear spring that I believe both make the bike lean more.
Kyle
3Rrr is offline   Reply With Quote
Old 12-30-2010, 11:38 AM   #18
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,683
Great idea
I prefer not have spacers but differing thicknesses would be great.
Kyle
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 12-30-2010, 01:52 PM   #19
toowheels OP
on a mission...
toowheels's Avatar
Oddometer: 963
Kyle
It's a thought. How much more height do you think is needed? The current version adds about 2mm to the height.
I'm running a 140/80 K60 (stock spring though) and I find it's perfect. Although there are always times when I'm not parking on level ground and then sometimes it's too long and sometimes it's too short I'd rather er on the shorter side cause it's easier to put something under it than to try to make it shorter...err obviously.
Thoughts?
Motoriley, how much height do you think is needed?
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline   Reply With Quote
Old 12-30-2010, 02:02 PM   #20
Motoriley
Motoriley's Avatar
Oddometer: 2,683
Fat foot
My homemade one adds about 10mm. That seems to work for me although a few mm less wouldn't make a difference.
Thoughts?
Dave
Old 12-30-2010, 06:31 PM   #21
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Griz: What are you using how? Could you give me dimensions? Obviously the ground softness can vary a lot but how has yours worked?
Thanks,
Dave
I'm not using anything right now, other than your standard rock or stick, because every side stand footprint enlarger I've seen is a lot of money for not much of a gain in footprint size.
Old 12-31-2010, 05:41 PM   #22
Bushav8r
Bushav8r's Avatar
Oddometer: 121
I was going to make my own using multiple layers and sections of metal, but yours is a much more elegant solution. I will definitely buy one as long the price isn't outrageous.
Bushav8r is offline   Reply With Quote
Old 01-03-2011, 01:13 AM   #23
toowheels OP
on a mission...
toowheels's Avatar
Oddometer: 963
Anyone else out there had problems with their side stand foot disappearing?
Any other thoughts on a higher version and how high it should be?
Happy New Year to all and best wishes for a great riding year!!
See you out there!
Dave
Old 01-03-2011, 11:58 AM   #24
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
See you out there!
Dave
I would buy your sidestand footprint enlarger in a heartbeat if it meets this three points:
1) Cost, keep it low.
2) Diameter, make the footprint be as large as possible without interfering with center stand and/or other bits when the sidestand is up.
3) Height, make it as high or higher than the BesRest version.
Old 01-03-2011, 08:00 PM   #25
markymcd
markymcd's Avatar
Oddometer: 882
I disagree with point number 3. If the footprint keeps the bike from sinking then you don't need to have the bike more vertical.
I've found too many times that I've had to dig a bit of a hole with my heel to get the stand down. I'm thinking if your bike is leaning over too much then BMW might have the wrong stand on your bike. They made that mistake with mine.
Mark.
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 01-03-2011, 08:10 PM   #26
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,349
I agree with Mark if the foot print makes the bike stand too straight it makes it difficult to park on an angle or hill if you have to....even where I park at work with my TT foot print used to be interesting trying to get the bike to the stand. Now it is easy since I bent the footprint on my road trip this summer.
soph9 screwed with this post 01-03-2011 at 08:41 PM
soph9 is offline   Reply With Quote
Old 01-03-2011, 08:33 PM   #27
eddyturn
Wannabe
Oddometer: 1,904
I'll agree with others about the height. Don't want to have it be as high as the Best Rest Puck Up. Had one of those and felt it was too high. Have the TT one now and it works pretty well. Just make it so we don't have to tilt too far to the right to deploy the sidestand. I guess that would be the leading edge of the plate.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 01-03-2011, 08:52 PM   #28
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Well personally I like the height of the BestRest one, but if the majority doesn't then x #3.
Old 01-03-2011, 08:53 PM   #29
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
Just our o2 worth having now ridden the bikes fully laden for a while - note F798's. We have the Altberg foot enlarger and one of the issues is that it sticks out in front of the foot.
The result is that when putting the stand down the front of the foot tends to dig into the dirt and for Sally it's too hard to lean the bike over to the right far enough when it's fully laden with gear.
If I was designing one it would extend the foot only to the rear (and as much as possible) and leave the front (when viewed with the foot fully down) as close to original as possible.
We also find that even on level ground the bike has a lot of weight on the stand even though the Altbergs add about 4mm height, but that could be because we have a different stand completely... not sure.
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C is offline   Reply With Quote
Old 01-04-2011, 01:25 PM   #30
CycleRider
CycleRider's Avatar
Oddometer: 662
Another Idea
Below is another type of foot that I found on Amazon.com.
It wasn't exactly what I was looking for, but I thought the idea of having extensions that can be collapsed, under the foot, could allow for a larger "foot print". I know that I am not explaining myself very clearly, bit having additional layers that can be rotated out would prevent it from interfering when it is in the "up" position, and optional layers that can be used only when you need them.
I think what you have done so far is classy. It has that quality look like the rest of your products.
T...
CycleRider is offline   Reply With Quote
Times are GMT -7.   It's 01:13 AM.
