Old 02-04-2011, 02:18 AM   #31
brstar OP
brstar's Avatar
Oddometer: 455
Thumb Progress
Wall to wall sidecars. They are my shed walls at the moment. But a proper wall/door would be good if I can sneak it on without the council complaining about me converting the patio into a lean to shed. . Only recently I seem to be missing a nice little Kingchrome 3/8 drive socket set. So need to be doing something soon I think.
Bracket to bolt to the unused lower engine mount. This picks up the front lower mount on the CJ sidecar and seems to put it just about right for chair axle lead. 230mm/9" or so.
Bolted on with only a 10mm/3/8" high tensile bolt but it clamps both ends of the engine casting so sideways should be very strong. Told my boss the 40x10 flat bar here is left overs from the work blacksmith shop.
brstar is offline   Reply With Quote
Old 02-04-2011, 03:07 AM   #32
brstar OP
brstar's Avatar
Oddometer: 455
Eh? legislation
The rules here. It seems I need an inspection and a park brake (mechanical) Will the centre stand do???
Dont know how to load this type of file.
http://www.infrastructure.gov.au/roa...Jan2011_v2.pdf
brstar screwed with this post 04-30-2011 at 10:12 PM
Old 02-04-2011, 03:12 AM   #33
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,718
Centre stand as a park brake! You can only try. It's mechanical & it will stop it from rolling.
Is there anything that says it has to be operated from the rider's seat?
rayb Crash Dummy (no testing involved)
Old 02-04-2011, 03:39 AM   #34
pops
Oddometer: 1,582
Nice threaded balls there Bruce.
pops is offline   Reply With Quote
Old 02-04-2011, 05:51 AM   #35
IsAnOzzie
Oddometer: 261
Take a look at the "handbrake" on the new Urals.
a half turn shaft with a bolt attached that contacts the back of the foot brake holding it down.
so if you put your foot on the foot brake, then look where you can wedge something behind it to hold it on, thats basically it.
The Extinguished gentleman.
Do or do not. There is no try. Yoda
IsAnOzzie is offline   Reply With Quote
Old 02-05-2011, 05:50 PM   #36
brstar OP
brstar's Avatar
Oddometer: 455
3 points
3 mounting points to connect old tech to new.
The 4th mount is the big challenge with al sorts of things that move underneath there. Swinarm, shock, linkage, centrestand etc.
Old 02-05-2011, 07:17 PM   #37
03gixxerpilot
Oddometer: 36
looking good so far
Born again Juvenile delinquent
03gixxerpilot is offline   Reply With Quote
Old 02-05-2011, 09:53 PM   #38
pops
Oddometer: 1,582
Looking good bruce. You are nearly there.
You might have to make up a subframe for the rear .
Cathy finally took HER sidecar for a run today.
"After 2 full days of pulling it apart and cleaning it".
She even let me ride it .
Unreal to ride compared to the GSA.
Cheers Ian.
Old 02-06-2011, 03:51 AM   #39
brstar OP
brstar's Avatar
Oddometer: 455
Laugh Her sidecar.
Thanks Ian.
Good to see the outfit with a decent shine again.
I also can still see the rub marks on the front tyre from the swingarm bolts. Another washer be good there?
Can't see the whites of the eyes though.
Must be a great girl your lady cause that is some machine she has got there.
Do you proud i'd say.
Cheers Bruce
Old 02-06-2011, 03:48 PM   #40
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,053
Originally Posted by pops View Post
Cheers Ian.
Hey Pops, is that Ian Souters old outfit? Ian used to own Premier Sidecars here in Vic before he sold up and went bush.
I remember it was a brilliant outfit too!
Mrs pops looks very happy
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 02-07-2011, 04:58 AM   #41
brstar OP
brstar's Avatar
Oddometer: 455
Talking Today's
The underside is going to be a bit of do what you can with what you can. Bit like the rest really. Having decided to leave side and centre stands the going is tight. But flat bar seems to fit in and through some funny places. It is just a matter of triangulating in 2 planes or 3 as required to arrive at a fixed point to fix to so to speak. I just have to make some of it bolted connections or else it will be service by cut and weld. As some may not be able to be dismantled otherwise for maintenance etc.
The crashbar come top front mount. Fixes with 4 bolts 8mm.
May stiffen the plate at some point. Maybe after I bend it .
A piece of 65 x 6mm flatbar bolted to the sidestand bracket. with 2 x 12mm bolts quite secure. This will give fore aft stability to the lower rear mount and stop the front lower from twisting when I bolt it there. Somehow .
The same piece comes through to barely miss the centre stand and the drive chain. May trim it a bit here. But it is still nearly a foot short of the rear mount location. Hmm maybe the diagonal brace from the right rear footpeg mounts will do that.
We shall see in a future installment kiddo's.
Cheers Bruce
Old 02-07-2011, 02:12 PM   #42
TouringDave
Tri Moto Veritas
Oddometer: 7,053
Bruce, good to see another Strom outfit on the way!
Looking good.
K7 Strom with Chair
Old 02-11-2011, 05:24 PM   #43
brstar OP
brstar's Avatar
Oddometer: 455
Little bits.
2 little brackets.
Old 03-05-2011, 09:15 PM   #44
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,993
SOOOO,Any progress???.You started before me,don't let me beat you.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 03-06-2011, 07:23 PM   #45
TouringDave
Tri Moto Veritas
Oddometer: 7,053
Actually, we haven't had a sidecar completion race for a while.
Come on boys, first to the finish line!
K7 Strom with Chair
Times are GMT -7.   It's 07:13 AM.
