Old 01-01-2011, 08:42 PM   #1
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,151
dirt floor build
My '76 Convert has acquired a attachment that I'll be able to load my wife in her wheel chair and take a ride. It's a long way from being finished but I was able to take the first test ride today. I found that the goose needs shocks with stiffer springs on the rear and a change in the front forks but it can be ridden.
I built a sub frame that attaches to the front motor and center stand mounts.
Here are pics after first ride.
I'm thinking of building my own leading link forks if I can find the right tubing.
Thanks to all the builds here I was lead to build my first hack and am looking forward to going the rest of the way.
cleatusj is offline   Reply With Quote
Old 01-02-2011, 01:39 AM   #2
brstar
brstar's Avatar
Oddometer: 442
Thumb Sidecar
Way to gocleatusj
Will be watching this thread.
Cheers Bruce
brstar is offline   Reply With Quote
Old 01-02-2011, 05:28 AM   #3
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,151
If I remember correct the wheel track is 45" with 10 1/4" lead and the width of the top frame is 30 1/4". The floor deck is 48" before the nose is added.
Old 01-02-2011, 12:12 PM   #4
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,894
Right on brother !!.EVERYBODY should be able to enjoy the wind in there hair !!!!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 01-04-2011, 08:26 PM   #5
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,151
Here's a shot of the subframe mounted on bike. I used the same type brackets on the opposite motor and center stand mounts except longer so that I could bolt through and into the 1/2" plug welded nuts inside the 1" sq. tube. There are also plug welded nuts in both the front and back ends of this to attach the car frame.
And another view (blurry)of swing arm from bottom.
Old 01-04-2011, 08:48 PM   #6
Toompine
Toompine's Avatar
Oddometer: 111
Sidecar
Nice of you to do that for your wife. Hope you are going to put a gate on the back of that and a few tie down loops to keep her chair in there. A gate can work pretty good as a ramp too. Enjoy those rides together.
Toompine is offline   Reply With Quote
Old 01-04-2011, 09:11 PM   #7
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,151
Yes there will be a hinged gate/ramp and tie downs for all 4 wheels. I'll be building a nose and windshield.
Old 01-05-2011, 04:56 PM   #8
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,151
After reading thru Clancy's build and most others I decided that I mite just be able to complete something that would get the job done and be safe also. Can't let those lower blokes have all the fun.
Old 01-05-2011, 08:04 PM   #9
boxertwin
Oddometer: 1,022
CleatusJ,
You are a good man and a VERY good husband. This is a blessing for your wife.
"If there's one thing I'm grateful for in life it's my sunny disposition." -Harry Pierce, MI-5
boxertwin is offline   Reply With Quote
Old 01-08-2011, 01:33 PM   #10
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,151
Spent the morning fabricating up a fender out of .090 anodized aluminum.
Still need to add a bunch of rivets.
Old 01-09-2011, 12:55 AM   #11
NitroMax
NitroMax's Avatar
Oddometer: 674
Nice, rear part of fender would make good storagespace ?
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Old 01-09-2011, 12:23 PM   #12
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,151
Nitro, I've had the same thought. The way it sits in that pic with 12- 18 pound bars of steel on the floor, was how it was when I marked the radius for cut out.
Old 01-10-2011, 02:23 AM   #13
RVDan
RVDan's Avatar
Oddometer: 2,599
awesome.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 01-10-2011, 03:19 AM   #14
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,907
How far are you from Austin? I met a cool dude who was paralyzed from the waist down in an MC accident. He then built himself a hack like yours so he could wheel himself up and ride from the right side!
He later got into a slight accident and a while later was informed by the police that Texas law states the rider must actually be on the bike. so he build another where he wheels himself up, then climbs aboard the bike.
Real cool dude. He hangs out at Lovejoys on 6h street like all the time. Maybe give the place a ring and ask the owner [Eric] if he wouldnt mind giving you his info or taking down your info to hand to him next time he comes in. I'm sure he'd be down to help ya out with your build if need be.
I'll see if I can find some pics of his rig and post back
HaChayalBoded is offline   Reply With Quote
Old 01-10-2011, 03:20 AM   #15
HaChayalBoded
Brooklyn Bored
Oddometer: 7,907
Wow check this out.
http://www.str8shot.com/
http://forum.disabledbiker.co.uk/index.php
Times are GMT -7.   It's 08:23 AM.
