Old 01-03-2011, 02:11 PM   #1
lenny6753 OP
Oddometer: 87
Need help with mounting HB crashbars.
I ordered set of Hepco Becker crash bars for my Christmas present to me for my '10 Adventure. I'll try to keep this short but I just spent over an hour trying to mount just one side(left side) to the motorcycle. Between the bolt, spacer, washer, lining up the holes for the upper engine guard(i think that is what it is called), then trying to screw the bolt into the hole without stripping the bolt or bolt hole it is not working. I don't know if the crash bars are slightly off alignment wise or what but I had to stop before I started throwing tools. Does anyone have any suggestions or pictures that would possibly make this easier? Any help would certainly be appreciated
lenny6753 is offline   Reply With Quote
Old 01-03-2011, 02:44 PM   #2
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,185
Send a message via MSN to grinns
Don't worry you will get good at putting them on and taking them off.
Mine were a pain to at first.
2012 300 EC Race
2010 690 R
2007 990 S
grinns is offline   Reply With Quote
Old 01-03-2011, 04:13 PM   #3
KTMandu
Adventurer Wannabe
KTMandu's Avatar
Oddometer: 316
http://www.touratech-usa.com/media/Y...370-0310-1.pdf
Hope this helps. Mounting the bars can be a PITA but you'll get it.
I start with the lower bolt first and just thread the bolt in a few turns, then do the same for the bolt over the battery compartment and then move to the bolt that clamps the CB to the frame. Once all three bolts are loosely threaded in, then you can tighten them all a little at a time.
06 950 Adv
06 400 EXC
03 200 EXC
00 300 EXC
KTMandu is offline   Reply With Quote
Old 01-03-2011, 04:20 PM   #4
RozzyCat
Bleeds orange
RozzyCat's Avatar
Oddometer: 291
I faced the same ordeal recently. I found it much easier to do one side first while keeping the other side intact. This held the guard pretty much in place. Do the lower bolt (engine guard) first and then one going into the tank. That last one - that attaches to the frame - aaaargh!
I'm not looking forward to that next oil change. But practice makes perfect, eh.
RozzyCat is offline   Reply With Quote
Old 01-03-2011, 04:24 PM   #5
killurtv
free range moron
killurtv's Avatar
Oddometer: 608
+1 on this routine. Just rebuilt my water pump and changed oil, put crash bars back together as described above, perfect.
one day I will learn, until that day... fuck it.
2007 990 ADVENTURE
killurtv is offline   Reply With Quote
Old 01-03-2011, 05:45 PM   #6
lenny6753 OP
Oddometer: 87
Thanks for the replies. I had to step away from it for the evening as I was thinking some evil thoughts. I'll try again tomorrow.
Old 01-03-2011, 06:01 PM   #7
jeveretts
Oddometer: 320
+2 this is exactly how I do mine and it works perfect.
jeveretts is offline   Reply With Quote
Old 01-03-2011, 08:05 PM   #8
AdvRat
AdvRat's Avatar
Oddometer: 175
Send a message via AIM to AdvRat
I am getting ready to deal with the same issue for my new 2010 990 Adventure - I hope you don't mind if I ask a question that kind of relates to this situation, and maybe not? What made you decide to go with the H&B crash guards and not the SW or Touratech? I'm trying to decide on the 2 companies (H&B or SW's) and even thou they are very similair - I guess there is a decent weight and/or build difference. So I'm not sure which ones to go with. I guess SW have much thicker tubing, and weigh a little more, H&B use thinner tubing, weigh less and cost a little more. Sorry if this is a little off track/thread. Thanks & good luck, I'll be there in a couple weeks myself if I ever decide - they will be my Christmas present also from my Christmas farkle money.
AdvRat is offline   Reply With Quote
Old 01-03-2011, 08:59 PM   #9
Iwantabikesobad
Iwantabikesobad's Avatar
Oddometer: 1,001
reply
Someone a few weeks ago posted about using studs inplace of the 2 bolts holding the battery cover. This makes a lot of since and is on my list of stuff to do. This will really help with installing the bars
Good safe riding to all.
Yes it's my Bike, No I wont help ya move!
Proud member of Father & Daughter riding club
09 KTM Adv. The Orange ones are faster!
Iwantabikesobad is offline   Reply With Quote
Old 01-03-2011, 10:57 PM   #10
Subutai
Oddometer: 555
What are you crying about, I removed the chain guard, or whatsamacallit, well the plastic thing between the swingarm and the rear wheel on the chain side. Two screws on top, one under. The screw on the underside did not strip, THE FUCKER CAME OUT WITH THE THREAD! Great, brand new '10 bike. Guess did it line up when I put it back together? ..and trying to make the screw seat on the thread what was left in there was great. Prolly have to glue it on with thread locker or something.
I've got SW Motech bars coming, let's see if they are such an ordeal as yours.
Subutai is offline   Reply With Quote
Old 01-04-2011, 07:45 AM   #11
kirb
should be out riding
kirb's Avatar
Oddometer: 1,352
Having the studs in the area under the radiator is ideal. You first hook that hole up, rotate the bars, get the lower hole over the side tank, and then line up the frame clamp. Put the lower bolt in a few turns, and push the frame clamp up the frame to get the correct alignment. Clamp the frame down, then tighten the lower bolt, then put the nut on the studs.
Takes me about 5 minutes to install both sides now and saves the threads in that cast part.
'13 Moto Guzzi Stelvio NTX, '07 Moto Guzzi Griso, '08 KTM adventure, '00 EH Super X, '48 Indian Chief (in resto)
kirb is offline   Reply With Quote
Old 01-04-2011, 08:24 AM   #12
skipman
skipman's Avatar
Oddometer: 171
You definately get better with practice. One problem i was having was the bottom bolt on the tank. I use a allen or screwdriver inserted behind the threaded clip(prying it outward and holding it steady) when starting the bolt it's helped me alot. Just a thought.
skipman is offline   Reply With Quote
Old 01-04-2011, 06:01 PM   #13
ten_fiver
ten_fiver's Avatar
Oddometer: 1,456
Crash-bar stud mounts. This will help you prevent the inevitable stripped threads above the battery box.
http://www.advrider.com/forums/showthread.php?t=626041
'08 KTM 990 Adv.
ten_fiver is online now   Reply With Quote
Old 01-04-2011, 06:17 PM   #14
lenny6753 OP
Oddometer: 87
Thanks for all the help. I haven't got around to working on 'em again but will this week. The stud mounts are a good idea.
AdvRat - The only real reason I chose the HB bars over SW was I liked the look of the HB's better, for what that is worth. I cannot comment on the design or sturdiness of one vs the other.
Old 01-04-2011, 06:38 PM   #15
ten_fiver
ten_fiver's Avatar
Oddometer: 1,456
Advrat: can't really compare the other brands, but I have the SW's. They are very solid, and I like the cross-brace by the radiator.
About the mounting studs: trust me, those bolts on the battery box are the ones that are the trickiest to get in (imo) and the threads will strip in a heartbeat. There were a few thrown tools when I stripped my first one.
'08 KTM 990 Adv.
Times are GMT -7.   It's 06:26 PM.
