Old 01-05-2011, 06:48 PM   #1
The Raven OP
The Raven's Avatar
Oddometer: 4,811
R100GSPD R80G/SPD skidplate and fairing mountingsize
Hey Guys
After being the high bidder for a $50 GSPD skid plate for the last week, I was sniped at OEM cost.....
Well I can't whine too much, at least I made FF pay for it
So, after loosing it I've decided to try and make my own. I happen to have a 3-4 foot 1/4" thick aluminum sign that I got to "dispose" of after putting up a new one. I'm hoping I can get some measurements to make my own.
I also need to drill some holes in my Pod to mount a fairing. I really don't want to pay 8 bucks for the BMW template. Anyone have one to send? Or even better, a spare front pod they want to sell
The Raven is offline   Reply With Quote
Old 01-05-2011, 07:52 PM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,668
you've got the coffin fairing, where'd you score that? They're hard to find.
I think I've still got the template, I'll need to dig for it, plus I'd want it back.
Twin headlight Earnie sells a very nice center stand guard, I had to put a small half round notch in mine to access the drain plug. His sump guard isn't good for a G/S, ask Jenna.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-05-2011, 08:14 PM   #3
marksbonneville
marksbonneville's Avatar
Oddometer: 961
I made this skid plate out of 1/8" aluminum, I traced from a GSPD plate, PM me if you want a copy of the outline.
Mark
Originally Posted by The Raven View Post
Hey Guys
marksbonneville is offline   Reply With Quote
Old 01-05-2011, 08:43 PM   #4
Mugwest
Mugwest's Avatar
Oddometer: 6,050
Mark, that is a beautiful repro of the stock PD plate
And you did it right/crucial by countersinking the mount screws-- if that countersinking is not done and the bolt heads are proud of the plate, a log crossing turns into a log hang-up, every damned time
Raven, if you have grinding/maching tools and a big vise to use as a bending brake, get Mark's template and make your own. 1/4" alu is in the neighborhood of the 4mm stock plate. I've gotten free cast-off pieces of 4mm from the local welding shop-- made my centerstand skidplate from that
My stock PD plate shows how sweet Mark's copy is
Mugwest is offline   Reply With Quote
Old 01-05-2011, 08:59 PM   #5
marksbonneville
Oddometer: 961
Thanks, it has worked very well. The 1/8" aluminum was a pain to bend, I cant imagine bending 1/4". I need to build the centerstand plate next and had something already cut out but I like yours better so I need to make another trip to the scrap yard. I also made a bigfoot for the side stand out of the same material.
"Mark, that is a beautiful repro of the stock PD plate "
Old 01-05-2011, 09:25 PM   #6
Mugwest
Mugwest's Avatar
Oddometer: 6,050
those big dumbass rectangles in my centerstand plate were necessary b/c the R80G/S centerstand had the tang-loops for the springs proud of the fwd edge of the stand-- just like all previous BMW road bikes. My plate had to have those holes to accommodate the springs in both extended and stowed configs.
Your 100GS stand has the better design, where the springs are latched to tangs welded inside the stand geometry, so a center plate can be pretty much flush to the stand itself
I will say this: a centerstand skid works if you do any log crossings regularly. Momentum and whatever front wheel loft you can get and the skid plates let you slide/bang over some impressive logs. Otherwise it's just bling to look at and make people think GS's are dirtbikes
Old 01-05-2011, 09:35 PM   #7
marksbonneville
Oddometer: 961
I tend to use my skip plate often, big rocks like to jump up at me, I have been lucky so far with no center-stand plate but I don't want to press my luck.
[/QUOTE] I will say this: a centerstand skid works if you do any log crossings regularly. Momentum and whatever front wheel loft you can get and the skid plates let you slide/bang over some impressive logs. Otherwise it's just bling to look at and make people think GS's are dirtbikes [/QUOTE]
Old 01-05-2011, 10:29 PM   #8
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
The centerstand hangs lower than the sump on my G/S and it gets stuck on logs. It's only a 1/4" or so below the sump and it shouldn't be a problem, but make sure your bash guard is lower than that.
+1 on Mark's bash guard. Looks waaaay better than the one I'll make!
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 01-06-2011, 02:58 PM   #9
The Raven OP
The Raven's Avatar
Oddometer: 4,811
I'm no machinist, carpenter, or math guy. Just an Airhead
It's this thick;
From this sign... legitimately gotten :)
Old 01-06-2011, 04:18 PM   #10
One Less Harley
Oddometer: 4,668
Stock G/S sump guard and twin headlight Earnie center stand, no unsightly hole in it for springs.
More picts of the stock sump guard
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-06-2011, 06:57 PM   #11
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,298
ps Hi Richard.!
Old 01-06-2011, 07:25 PM   #12
One Less Harley
Oddometer: 4,668
Originally Posted by hardwaregrrl View Post
ps Hi Richard.!
aught oh, I'm in your cross hairs
hi ya Barbie....don't you hate nick names given to you by some drunk..
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-07-2011, 03:44 AM   #13
ghedo
ghedo's Avatar
Oddometer: 78
You can easily do it yourself as I did
http://www.advrider.com/forums/showthread.php?t=467077
bye
ghedo
ghedo is offline   Reply With Quote
Old 01-09-2011, 08:28 PM   #14
meijer's trails
meijer's trails's Avatar
Oddometer: 480
ghedo's plan made this
still available if you PM me.
3/16" thick. built using eMachineshop using Ghedo's plan, except i shaved a few mm from the back edge to reduce cost and i but 3 bends to round out the front angle a bit. eMachine shop makes recommendations to save cost thus the shaving at the rear.
i mount it with the mcMaster carr 6mm male-female shock mounts and consider those expendable. they will shear under very hard hits. touratech uses the same mounts and they recommend carrying spares.
oh, and make SURE to use a 90deg METRIC countersink, instead of 87deg sae. so the metric screws get the most surface area to pull on.
ive never broken a screw or damaged the sump or sump threads, only torn the rubber mounts in half.
meijer's trails screwed with this post 01-09-2011 at 08:40 PM
meijer's trails is offline   Reply With Quote
Old 01-10-2011, 06:59 PM   #15
meijer's trails
Oddometer: 480
mounted
Times are GMT -7.   It's 07:28 AM.
