Old 01-06-2011, 04:11 PM   #1
bikecat OP
bikecat's Avatar
Oddometer: 1,122
Dry fuel filter
I observed that if my bike is not ridden for a few days, the fuel filter will be drained of fuel (I keep the petcocks off when parked). Is this normal or indicative of something not right with my 32mm Bings?
Appreciate the education here.
bikecat is offline   Reply With Quote
Old 01-06-2011, 04:17 PM   #2
P B G
Oddometer: 10,001
Well it goes somewhere, I usually let my bike idle petcocks off till it sputters slightly.
Old 01-06-2011, 05:06 PM   #3
uraldog
vagabond
uraldog's Avatar
Oddometer: 405
the fuel [ now with increased alcohol content ] is evaporating through the carb vents
uraldog is offline   Reply With Quote
Old 01-08-2011, 12:41 AM   #4
bikecat OP
bikecat's Avatar
Oddometer: 1,122
Just to complete the education. So If I leave the bike alone long enough, the carb bowls will dry up?
Old 01-08-2011, 06:14 AM   #5
rufusswan
rufusswan's Avatar
Oddometer: 962
Well, yes they will. However you will not appreciate the result. They will dry sooo slooowly they will deposit unwanted crap in the bowls. If it's to sit an appreciable amount of time, then drain the bowls into the tank and re-install them dry. Only takes a minute.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Times are GMT -7.   It's 12:18 PM.
