01-07-2011, 04:15 PM
#16 | |
Oddometer: 683
The site has this: Bohrung 70mm Hub 64mm 500ccm. Visually the pistons look like a large bore and w/ a shorter stroke. So is it a 1/2 liter or 1 liter engine? Time for an e-mail to the builder. Carl |
01-07-2011, 04:42 PM
#17 |
Along for the ride
Oddometer: 912
Using the translator built in to Firefox, the first page of the site lists the bore as 64mm and stroke as 70mm (64*700= 448cc per side). Maybe something lost in the translation? Bill.
__________________________________________ "There's a fine line between a skinning and a shearing" |
01-07-2011, 06:51 PM
#18 |
Oddometer: 1,465
That's how "/2" engines are assembled. The crank and rods go into the crankshaft tunnel, then the assembly gets rotated onto its back, then finally goes vertical to drop through the rear bearing counter bore. Just to add pleasure to the job, the case has to be hot enough for the rear bearing to drop in.
01-08-2011, 02:09 AM
#19 |
fine beer sampler
Oddometer: 1,534
Thanks Wrench! I could not see how they would fit. I've never seen a /2 motor up close, I will need to fix that!
1978 R100/7 Build thread 1915 Boardtrack racer replica (Electric Powered) Lots of bicycles Hemp: The strongest natural fiber in the world, and the most nutritious plant on earth.....why is this illegal again?
01-08-2011, 05:15 AM
#20 |
Loose nut behind h/bars
Oddometer: 4,510
I'll tell ya what's wrong with those pictures.............
they weren't taken in MY garage! ![]() That thing is sweet.
http://www.theshining.info/ KTM 950 Adv. "S"...'06 KTM 525 EXC... '76 MV Agusta 750 America S...'84 Honda VF1000... '90 Kawasaki ZX11...'76 Kawasaki 900 Z1...'01 VOR 400E |
01-08-2011, 07:21 AM
#21 | |
Oddometer: 871
A wonderful bit of work. I am in awe. Do you think that is a whole custom head casting? I have had dreams of boring a four inch whole through the middle of an R50 head, shrinking in a big piece of billet and starting over. These thing keep we awake at night. Somehow, I don't think I would get this through tech as a "vintage modification". Thanks for posting! |
01-08-2011, 09:04 AM
#22 |
Homely Adventurer
Oddometer: 452
maybe the undersize thing is for racing class rules to make up for the unfair advantage of the 4valve heads.
When you create with your brain, it is work When you create with your heart, it is craft When you create with your soul, it is art |
01-08-2011, 09:14 AM
#23 |
Wacky Bongo Boy
A local aluminum foundry would probably love to have the business. There's one in St Louis that will cast anything you want in any quantity you want.
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
01-08-2011, 09:19 AM
#24 | |
Along for the ride
Oddometer: 912
01-08-2011, 09:41 AM
#25 |
Oddometer: 683
Carefully and closely inspect those heads. They have many secondary ops done to them after they were cast. It appears to include gasket surfaces, combustion chambers, exhaust threads and most probably the plug threads, valve guide bores, valve seat c'bores and rocker arm features. Plus, there is the sourcing of the valve train parts. Then there are the secondary ops to complete (inserting seats and guides, seat cutting and/or grinding) the assembly of the heads w/ the valve parts.
You'll be spinning your wheels by attempting to modify a stock set of R50/60heads to do what they have done. I'd recommend you have lots of time and money before starting from scratch. Carl Carl screwed with this post 01-08-2011 at 02:45 PM |
01-08-2011, 11:10 AM
#26 |
Oddometer: 683
Vierified by the builder
Vierified by the builder:
Carl |
01-08-2011, 11:18 AM
#27 | |
Horizontally Opposed
Oddometer: 5,294
The "Flip"
![]() bearing to the back, webs down, rods up... ...tip into the crank housing and feed the rods up through the cam housing... once in place....the rods will protrude through the respective cylinder housings... there's a few pictures of the process on the smuggy below ![]() ...and a fresh stock head.... ![]() There's NO way you're gonna fit 4 valves in this thing.... Like Carl said... totally custom from scratch
'65 R60/2 '68 R60US '74 MG Eldorado '95 R100M danedg screwed with this post 01-08-2011 at 11:25 AM |
01-08-2011, 11:37 AM
#28 | |
Oddometer: 871
That is, I am sure, an understatement
Notice the intake ports are not angled in toward the rider, but parallel to the frame. The exhaust ports are angled out a bit. Really lovely. I wonder about the "window panes" in the case around the flywheel, beside "holes is faster". The castelated flywheel either. I wonder if he would share his cam specs. Eric |
01-08-2011, 11:52 AM
#29 | ||
Oddometer: 683
Not really, you can count the secondary ops from when the raw casting was completed.
Carl Carl screwed with this post 01-08-2011 at 12:04 PM |
01-08-2011, 12:25 PM
#30 | |
Oddometer: 36
"Bohrung" means "bore", so the displacement calculates (7cm)²* Pi/4 * 6.4cm * 2 = 246.3 cm³ * 2 = 492,6 cm³ Best regards Sven |
