01-07-2011, 09:34 AM
#1 |
Oddometer: 371
New AMA Vintage Rules and Classes for 2011
2011 AMA Racing National Vintage Dirt Track Championship Series
Supplemental Regulations The 2011 AMA Racing Rulebook Governing Pro/Am, Standard, ATV and Youth Competition and these Supplemental Rules will govern these events. AGE AND ELIGIBILITY 1. To compete in the 2011 AMA Racing National Vintage Dirt Track Championship Series, participants must be at least 18 years old on the date of the event. Please see the 2011 AMA Racing rulebook for regulations regarding rider eligibility. GENERAL 1. AMA Pro Racing license holders must wait one full year after their pro license expires to be eligible for Amateur National competition. 2. If one or more main events cannot be run, results will be awarded based on heat and/or semi results. 3. Three entries minimum are required to make a class. 4. Limit of four classes per rider per meet. 5. Knobby tires will NOT be permitted. 6. Only riders who qualify for main events will receive points. 7. All riders who qualify for a main event but are unable to start will receive nine points which is equal to a 12th place finish position. 8. Riders who are disqualified from a main event will not receive points. 9. Points Scale Pos Pts Pos Pts Pos Pts 1st 30 10th 11 19th 2 2nd 25 11th 10 20th 1 3rd 21 12th 9 4th 18 13th 8 5th 16 14th 7 6th 15 15th 6 7th 14 16th 5 8th 13 17th 4 9th 12 18th 3 10. Ties in the final standings will be broken for 1st, 2nd and 3rd places only. The first tiebreaker is the better finish in the final main event in the class; the second tiebreaker is the better finish in the next to last main event in the class, etc. If the main events are run in an order different than originally scheduled, e.g. because of a rain delay, the actual order in which the races took place will apply. 11. The machine the rider brings to the starting line for his/her first heat is considered the qualified machine for that day’s event. EQUIPMENT 1. Standard flat track front spools and real knock off wheels are allowed on all no brake machines. 2. OEM, like make and model = parts or accessories from the same make and model motorcycle. No mixing or matching different makes or model parts or accessories. Different year parts from the same make and model are allowed. 3. Era correct = parts or accessories that were made in the time period or similar reproductions. 4. 1969-1976 any brakes – 2 pistons max. 5. No hydraulic clutches in any classes. 6. No pumper type carburetors are allowed in any class. 7. All drain plugs must be safety wired. No exceptions. 8. All axles and swing arm pivots must be steel. 9. All 2-stroke machines must have a packed silencer. 10. No front fenders allowed on any machine. 11. No electrical engine monitoring or management systems. 12. Restrictor requirements for all RS750 Honda s and XR750 Harley-Davidsons must be equipped with restrictor plates, one per cylinder the restrictor plate is a 1/8 (0.125" or 3.175mm) inch thick plate, containing a round 33mm (1.299") hole in the center of the air path. the hole must have square corners (no radius or chamfer on either side) the minimum size for carburetors is 38mm. the restrictor plate must be installed directly at the rear end and in contact with the carburetor casting the manifold on the cylinder head side of the restrictor plate must have a minimum inside diameter of 35mm for a distance of 1" in contact with the restrictor plate. CLASSES FACTORY WARS (BRAKELESS) CLASS: PRE 1951 750cc side valve or 500cc over head valve 4 stroke only No brakes in oval competition. Brakes in TT racing only Front tire-2.70x7.0 or 4:00 maximum Front rim-wm-3 2.15" maximum spoke type only. No mag type wheels Rear tire-2.70x7.0 or 4:00 maximum Rear rim-wm-3 2.15" maximum. Spoke type only. No mag type wheels Forks-OEM. Era correct stiffening allowed. No adjustable triple clamps Gas tank-OEM Frame-OEM. Era correct stiffening allowed Seat-era correct Oil tank-OEM Motor-mfg. Must match frame and forks. Like, make and model Head-OEM, like, make and model Cylinder-OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model Ignition-era correct. Aftermarket ignitions allowed, but must be hidden Carburetor-era correct OEM or Linkert m&s series, amal type 29, 76, and 276 TT, RN no Mikuni's or Kehin's Restrictors-none Transmission- OEM, like make and model. 4 speed max. No foot shift or hand clutch Conversions on bikes originally hand shift No military hand clutch conversions Shocks-rigid rear suspension only Exhaust-era correct TT brakes front-OEM, like make and model drum only TT brakes rear-OEM, like make and model, mechanical drum only 80ci limit in TT racing only OEM mfg. Bore and stroke 250 IRONMAN (BRAKELESS) CLASS: 1952-1968 0-250cc 2-stroke or 4-stroke No brakes in oval competition. Brakes in TT racing only Front tire-2.70x7.0 or 4:00 maximum Front rim-wm-3 2.15" maximum. Spoke type only. No mag type wheels Rear tire-2.70x7.0 or 4:00 maximum Rear rim wm-3 2.15" maximum. Spoke type only. No mag type wheels Forks-OEM or era correct. 35mm max dia. Conventional design only No adjustable triple clamps Gas tank-era correct Frame-OEM twin shock or rigid. Aftermarket rigid frames only Seat-OEM or era correct Oil tank-OEM or era correct Motor-mfg. Approved for competition Head-OEM, like, make and model Cylinder- OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model Ignition-era correct. Aftermarket ignitions allowed, but must be hidden Carburetor-era correct 32mm maximum for singles 28mm for twins. Linkert m,l&stillotsen, del 'orto ssi, amal mono block, concentric, gp and TT. Irz 32mm. Mikuni vm flange mounts or spigot mount round slides. No flat slides Restrictors-no reed valves Transmission-OEM, like make and model. 5 speed max. Shocks-OEM or era correct. No piggy back shocks Exhaust-era correct TT brakes front-mechanical drum only. Era correct TT brakes rear-mechanical drum only. Era correct 750 IRONMAN (Brakeless) CLASS: 1952-1968 251cc-750cc 4 stroke side valve or 251cc-500cc over head valve, 2 Or 4 stroke No brakes in oval competition. Brakes in TT racing only Front tire-2.70x7.0 or 4:00 maximum Front rim-wm-3 2.15" maximum spoke type only. No mag type wheels Rear tire-2.70x7.0 or 4:00 maximum Rear rim wm-3 2.15" maximum spoke type only. No mag type wheels Forks-OEM or era correct. 35mm max dia. Conventional design only No adjustable triple clamps Gas tank- era correct Frame-OEM twin shock or rigid. Aftermarket frames rigid only Seat-era correct Oil tank-era correct Motor-mfg. Approved for competition Head-OEM, like, make and model Cylinder- OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model Ignition-OEM or era correct. Aftermarket ignitions may be used but must be hidden Carburetor-OEM or Linkert m,l&s, tillotsen, del'orto ssi, amal monoblock and concentric, gp, TT, irz 2mm. Mikuni vm flange mount or spigot mount round slides. No flat slides allowed restrictors no reed valves Transmission-OEM, like make and model. 5 speed max. Shocks-OEM or era correct. No piggy back shocks Exhaust-era correct TT brakes front-mechanical drum only era correct TT brakes rear-mechanical drum only era correct TT racing 900cc maximum displacement 250 HOTSHOE CLASS: 1969-1976 175cc-250cc 2 stroke singles only. 4 stroke singles and twins allowed Rear brakes mandatory. No front brakes in oval competition Front tire-2.70x7.0 or 4:00 maximum Front rim-wm-3 2.15" maximum. Mag or spoke type allowed Rear tire-2.70x7.0 or 4:00 maximum Rear rim wm-3 2.15" maximum. Mag or spoke type allowed Forks-OEM or era correct. 35mm max dia. Conventional design only no adjustable triple clamps. Fixed aluminum triple clamps allowed Gas tank- era correct Frame-OEM, modified allowed or era correct replacement. Twin shock or rigid Seat-era correct Oil tank-era correct Motor-mfg. Approved for competition Head-OEM, like, make and model Cylinder- OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model Ignition-era correct. Aftermarket ignitions allowed, but must be hidden Carburetor-era correct. No mm limit. No Mikuni or Kiehin flat slides Restrictors-none Transmission- OEM, like make and model. 5 speed max. Shocks-OEM or era correct. No piggy back shocks Exhaust-era correct TT brakes front-OEM or era correct disc, two piston max. Brakes rear-OEM or era correct disc, two piston max 360 HOTSHOE CLASS: 1969-1976 251cc-360cc 2 stroke singles or 4 stroke singles and twins. 250cc twins in this class. Rear brakes mandatory no front brakes in oval competition Front tire-2.70x7.0 or 4:00 maximum Front rim-wm-3 2.15" maximum. Spoke or mag type allowed Rear tire-2.70x7.0 or 4:00 maximum Rear rim wm-3 2.15" maximum. Spoke or mag type allowed Forks-OEM or era correct. 35mm max dia. Conventional design only No adjustable triple clamps. Fixed aluminum triple clamps allowed Gas tank- era correct Frame-OEM, modified allowed or era correct replacement twin shock or rigid Seat-era correct Oil tank-era correct Motor-mfg. Approved for competition Head-OEM, like, make and model Cylinder-OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model Ignition-era correct. Aftermarket ignitions allowed, but must be hidden Carburetor-era correct. No mm limit. No Mikuni or Kiehin flat slides Restrictors-none Transmission-OEM, like make and model. 5 speed max. Shocks-OEM or era correct. No piggy back shocks Exhaust-era correct TT brakes front-OEM or era correct disc. 2 piston max Brakes rear-OEM or era correct disc. 2 pistons max 750 HOTSHOE CLASS: 1969-1976 335cc-750cc multi cylinder 2 or 4 stroke Rear brakes mandatory. No front brakes in oval competition Front tire-2.70x7.0 or 4:00 maximum Front rim-wm-3 2.15" maximum. Spoke or mag type Rear tire-2.70x7.0 or 4:00 maximum Rear rim wm-3 2.15" maximum. Spoke or mag type Forks-OEM or era correct. 35mm max dia. Conventional design only No adjustable triple clamps. Fixed aluminum allowed Gas tank- era correct Frame-OEM, modified allowed or era correct replacement twin shock or rigid Seat-era correct Oil tank-era correct Motor-mfg. Approved for competition Head-OEM, like, make and model Cylinder-OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model. Pre 1988 oil pump only on xr750's Ignition-era correct. Aftermarket ignition allowed, but must be hidden No motoplat or pvl ignition on xr750's Carburetor-era correct Restrictors-none Transmission-OEM, like make and model. 5 speed max. Shocks-OEM or era correct. No piggy back shocks Exhaust-era correct TT brakes front-OEM or era correct disc, 2 piston max Brakes rear-OEM or era correct disc, 2 piston max No 1989 or later engine components allowed on HD xr750's 250 MASTERS CLASS: 1977-1988: 250cc 2-stroke; singles only Rear brakes-mandatory no front brakes in oval competition front brakes in TT racing only Front tire-2.7x7.0 or 4:00 maximum Front rim-wm-6 3.50" maximum. Spoke or mag type Rear tire-2.75x7.5 or 4:00 maximum Rear rim-wm-6 3.50" maximum. Spoke or mag type Forks-OEM or era correct. Any diameter, conventional design only adjustable triple clamps allowed Gas tank-era correct Frame-OEM, stiffening allowed or era correct replacement twin shock or Roberts mono shock, early C&J mono shock (horizontal shock on top of motor) Honda factory dirt track, rs linkage frame or Panther-Bolger linkage frame Seat-era correct Oil tank-era correct Motor- mfg. Approved for competition Head-OEM, like, make and model Cylinder-OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model Ignition-era correct Carburetor-era correct Restrictors-none Transmission-OEM like make and model. 5 speed max. Shocks-OEM or era correct. Piggy backs allowed. No remote reservoirs Exhaust-era correct TT brakes front-OEM or era correct disc, multi piston allowed Brakes rear-OEM or era correct disc, multi piston allowed 500 MASTERS CLASS: 1977-1988; 504cc 4 stroke singles only Rear brakes mandatory no front brakes in oval competition Front brakes in TT racing only Front tire-2.7x7.0 or 4:00 maximum Front rim-wm-6 3.50" maximum. Spoke or mag type rim Rear tire-2.75x7.5 or 4:00 maximum Rear rim wm-6 3.50" maximum. Spoke or mag type rim Forks-OEM or era correct. Any diameter, conventional design only adjustable triple clamps allowed Gas tank -era correct Frame-OEM, stiffening allowed or era correct replacement twin shock or Roberts mono shock, early C&J mono shock (horizontal shock on top of motor) Honda factory dirt track, rs linkage frame or Panther-Bolger linkage frame Seat-era correct Oil tank-era correct Motor-mfg. Approved for competition Head-OEM, like, make and model Cylinder-OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model Ignition-era correct Carburetor-era correct Restrictors-none Transmission- OEM, like make and model. 5 speed max. Shocks-OEM or era correct. Piggy backs allowed. No remote reservoirs Exhaust-era correct TT brakes front-OEM or era correct disc, multi piston allowed Brakes rear-OEM or era correct disc, multi piston allowed 750 MASTERS CLASS: 1977-1988 375CC-500cc 2 stroke singles: 504cc-600cc 4 stroke singles: 501cc-750cc twins Rear brakes mandatory. No front brakes in oval competition Front brakes in TT racing only Front tire-2.7x7.0 or 4:00 maximum Front rim-wm-6 3.50" maximum. Spoke or mag type allowed Rear tire-2.75x7.5 or 4:00 maximum Rear rim-wm-6 3.50" maximum. Spoke or mag type allowed Forks-OEM or era correct. Any diameter, conventional design only Gas tank-era correct Frame-OEM, stiffening allowed or era correct replacement twin shock or Roberts mono shock, early C&J mono shock (horizontal shock on top of Motor) Honda factory dirt track, rs linkage frame or Panther-Bolger linkage frame Seat-era correct Oil tank-era correct Motor-mfg. Approved for competition Head-OEM, like, make and model no d port head on xr 750. Single plug only Cylinder- OEM, like, make and model .080 overbore and mfg stroke Cases-OEM, like make and model. No big oil pump on xr 750's. 1988 or older oil pump only Ignition-era correct no motoplat or pvl on xr750's Carburetors-singles, un-restricted. Xr750 and rs75 must have a 33mm intake restrictor and a 38mm or larger carb. All other twins no mm limit or restrictors required Transmission-OEM, like make and model. 5 speed max. Shocks-OEM or era correct. Piggy backs allowed. No remote reservoirs Exhaust-era correct TT brakes front-OEM or era correct disc, multi piston allowed Brakes rear-OEM or era correct disc, multi piston allowed Any single cylinder 4 stroke approved for AMA competition before 1988 can be bored (no stroking) up to 600cc's and run un-restricted in this class Any single cylinder 4 stroke over 600cc's must have a 38mm or smaller carburetor HD xr750 may not use any 1989 or newer engine components HOT ROD SINGLES OPEN CLASS: Pre 1988 Open Singles 2 Or 4 Stroke Rear brakes mandatory. No front brakes in oval competition. Front brakes allowed in TT racing only. Engine cases only must be from a 1988 or earlier AMA approved for competition motorcyc HOT ROD MULTIS OPEN CLASS: Pre 1988 Open Multi Cylinders 2 Or 4 Stroke Rear brakes mandatory in oval competition. No front brakes in oval competition. Front brakes allowed in TT racing only Engine cases only must be from a 1988 or earlier AMA approved for competition motorcycle 50+ AND 60+ VINTAGE OPEN ALL '69-'88 vintage legal and open legal bikes eligible Rear brakes mandatory in oval competition. No front brakes in oval competition. Front brakes allowed in TT racing only Engine cases only must be from a 1988 or earlier AMA approved for competition motorcycle |
