Old 01-07-2011, 09:54 AM   #1
herb28 OP
Oddometer: 46
r100gs front master cylinder question
I have a question on the front master cylinder on my r100gs. Is that thing really all one piece with the throttle and switchgear housing? It sure looks that way, even with my cheaters on.
I am wanting to swap out the bars and add real hand guards. Also might do the caliper swap with a 6 piston GSXR thing that I have laying around which might require a different master. Figured I'd ask before i started unscrewing stuff.
Looking at the exploded view of a one of those chain drive throttle things really scares me!
is that a watermelon?
herb28 is offline   Reply With Quote
Old 01-07-2011, 10:12 AM   #2
The Raven
The Raven's Avatar
Oddometer: 4,811
The MC is held on the throttle housing by two allen bolts. Not as scary as it seems
The Raven is offline   Reply With Quote
Old 01-07-2011, 10:53 AM   #3
walkingbear
walkingbear's Avatar
Oddometer: 3,602
caliber switch
you will need an adapter for the switch. I still have one left..
Let me know if you need it.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 01-07-2011, 10:56 AM   #4
The Raven
The Raven's Avatar
Oddometer: 4,811
Adapter? I just took it out with a pair of pliers, came out fine w/o damage.
Old 01-07-2011, 11:07 AM   #5
scarygary
Drawing blanks
scarygary's Avatar
Oddometer: 388
This is pretty much what you get (minus the fluid tank and throttle tube)
scarygary screwed with this post 01-07-2011 at 11:09 AM Reason: played with letters.
scarygary is offline   Reply With Quote
Old 01-07-2011, 11:17 AM   #6
The Raven
The Raven's Avatar
Oddometer: 4,811
Yep, that's about it....not a lot to it
Old 01-07-2011, 03:47 PM   #7
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,839
Your earlier style master cylinder (g/s 181-86, gs 87-90) has more bore diameter options than the later. 12-16mm bores. The early ones are female threaded the later ones have a banjo fitting.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-07-2011, 04:43 PM   #8
One Less Harley
Oddometer: 4,839
Look at twisted throttle for some real guards. I'm pleased w/ the way mine have held up though a crash or two. Very sturdy and fits stock bars.
More picts here.
http://www.twistedthrottle.com/artic...view/254/1/32/
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-08-2011, 07:09 AM   #9
herb28 OP
Oddometer: 46
Thanks for the help, I need better cheaters!
Times are GMT -7.   It's 12:19 PM.
