Old 08-27-2012, 02:10 AM   #46
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 409
Originally Posted by tfitch03 View Post
Does the fuel pump on your 990 make any noise when you turn the key on? Mine doesnt make a peep and my bike wont start. I have never heard it make noise but now it wont start and I fear the pump may be out. Even when I put my hand on it I cant feel anything when I turn the key. Thoughts?
Hi, this thread is for the 950 external fuel pump, the 990 has a completly different setup not prone to fail like the 950, but in other ways!
If you put the kill switch on and nothing happens, the pump is not producing the necessary pressure to feed the fuel injection system.
Either bad electrical connections of clogged filters but i'm more inclined to the first option then faulty pump.
690R & 990Adv
Old 08-27-2012, 05:45 AM   #47
tfitch03
Turkey
tfitch03's Avatar
Oddometer: 106
Thanks! I didnt realize it was dedicated to 950's, my apologies. The filters are brand new so I am going to check all the connections and then I guess start looking for a replacement.
tfitch03 is offline   Reply With Quote
Old 09-04-2012, 07:39 AM   #48
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 73,601
Okay, I've moved all the Dr. Bean's posts to vendors. Please use this thread for all sales of fuel pump kits. Thanks.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
2010 Latin America Route
Misery Goat is offline   Reply With Quote
Old 09-06-2012, 01:47 PM   #49
charlie264
charlie264's Avatar
Oddometer: 5,008
I bought this pump from these guys on flea bay.
KTM 950 R Superenduro '06-08' Fuel Petrol Pump Type 2 | eBay
Firstly yesterday when I ordered it, was 79 quid...today 95 quid. This pump is not a direct replacement for the SE. The pipes for the fuel line are for 16mm 8/16 fuel pipe and the orientation is 180 degrees different. So you have to re-plumb the T piece with a straight bit of pipe and shorten the hose with the snap connector, thought it was hard disconnecting the fuel line on the SE!!!...well try now.... You can’t spin the pump around cos the breather nozzle won’t fit up against the tank because of the design of the mounting plate on the tank.
They drop ship from this company. http://www.hilevel1.co.uk/cpg14/menu.php
Have to say she's running much better...the dip mid throttle has gone..so pump was on its way out.
Old 10-14-2012, 07:36 PM   #50
Bgunn
Sand seeker
Bgunn's Avatar
Oddometer: 1,104
Fuel pump removal
Getting ready for the Dr Bean upgrade. Looking through the shop manual I didn't see anything on the fuel pump removal.
Any trick for getting to the connector for the fuel pump wires?
Last ride before the upgrade, and my bike died 2 miles from home.
Everybody's on the run
Bgunn is online now   Reply With Quote
Old 10-15-2012, 02:52 AM   #51
roookie1
Oddometer: 40
I did the install with the pump mounted to the bike, just hanging in the fuellines (yeah I´m lazy)
Laying on my back soldering, it was ok. If You have acces to a lift It will be easier though
roookie1 is offline   Reply With Quote
Old 10-15-2012, 11:38 AM   #52
Dr_Bean
Dr_Bean
Oddometer: 68
Send a message via ICQ to Dr_Bean
I think you should be able to get to the pump, fuellines and connector by just removing the engine-protection guard (bashplate).
But I think you have to remove the left-tank if you do not want to remove the original (1xuse) hose-clamps on the pump.
For me it is difficult to tell, because I modified my 950adv so much that most of these things are different (I have a home made bashplate, fuelfilter in the line and battery, starterrelais and regulator below the seat-bank).
http://forum.lc8.nl/modules.php?set_...view_album.php
Dr_Bean is offline   Reply With Quote
Old 10-18-2012, 08:06 PM   #53
Bgunn
Sand seeker
Bgunn's Avatar
Oddometer: 1,104
Mission accomplished
With a little help from Dr Bean
Times are GMT -7.   It's 09:59 AM.
