Old 01-08-2011, 06:09 PM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,578
Bluhduh Cylinder-to-block leaking oilage...
Cylinder-to-block leaking...
1981 R100RS
What are the odds? I was sooo careful too.Made sure everything was spotless clean, did not use hylomar between the cyl and block per advise, new cyl seal.
Started her up and oil is bleeding out of the right side at the rear.
I mean like a stuck pig.
Left side is fine.
I guess I must have F'd up the new o ring. I did use the slightest bit of lube so that it would slip into the block without getting pinched...
What'r the chances...?
Good nudes is it started right up!
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 01-08-2011, 06:21 PM   #2
supershaft
because I can
Oddometer: 9,116
Who advises not to use sealant there??
I spread a VERY thin layer of Durko with a #11 Exacto blade on the cyl. base.
The trick is to retain the stud o-rings with a bit of sealant so that they do not fall out of their recesses while installing the cylinder. I double check right before the cyl gets snugged down all the way in order to make sure they are still where they should be. I have seen many a F'ed up cylinder from those o-rings getting pinched. It compromises the sealing surface big time!
Old 01-08-2011, 08:15 PM   #3
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,578
...you called it SS. Right side is fine and I used no sealant.
Right side pukking was a pinch o-ring...
Better building in the future...
Old 01-08-2011, 08:34 PM   #4
supershaft
because I can
Oddometer: 9,116
I hope your cyl and case are OK. Look real close. That pinched rubber very often makes the aluminum give and then you have an uneven sealing surface. Theoretically the oil won't get past the o-ring but I don't think that theory works very well outside of the drawing room.
Old 01-08-2011, 08:41 PM   #5
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,578
....no, it was definitely pinch, like in half...a real screw-up.
Old 01-08-2011, 09:17 PM   #6
supershaft
because I can
Oddometer: 9,116
I don't think you are following me RD. I am trying to warn that the pinched rubber o-ring will make the cylinder's and case's metal give way and ruin the flat sealing surface. Does that read right?
Old 01-08-2011, 10:01 PM   #7
fishkens
Further...
Oddometer: 5,149
SS, I get it. If the o ring wasn't in the groove it could deform the alu seating surfaces when the head bolts were torqued.
Here's hoping that didn't happen in this case.
FWIW, I've used Hylomar at the cylinder/case interface w/o problem.
If the OP's bike is leaking like a "stuck pig" something's definitely wrong.
Hopefully a correct reassembly will resolve the problem.
And I'd suggest using Hylomar unless I've missed the latest memo (which very well may be the case ).
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 01-08-2011, 10:12 PM   #8
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,299
I believe RD has already succeeded the second time around.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 01-09-2011, 09:11 AM   #9
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,578
Thumb
...I checked the mating surfaces, all good. I'm putting it back together this morning. I'll keep ya posted.
Old 01-09-2011, 10:18 AM   #10
supershaft
because I can
Oddometer: 9,116
Great. I really don't know if it makes any difference or not but I believe that the damaged surfaces that I have seen from pinched o-rings had been run with the o-ring pinched for some time. Good luck Rapid Dog!
Old 01-09-2011, 11:50 AM   #11
Country Doc
Wanderer
Oddometer: 2,758
FWIW, I battled with slightly weeping cylinders on my slash-5 for most of the year. Tried Hylomar, grey Permatex, Threebond, blah blah.
The only thing that worked well was Loctite 518. It's a case sealant for flush-mated aluminum surfaces. I believe it's an anaerobic cure and will not clump out in your oil like silicone-based sealants.
I know your bike is different RD, and may not require any sealant at the base due to the O-ring, but this is just another data point for someone looking for a decent cylinder base sealant.
dc
Country Doc is offline   Reply With Quote
Old 01-09-2011, 01:02 PM   #12
fishkens
Further...
Oddometer: 5,149
Have you had the jugs off since? Did they come off easily? Any nasty residue?
Old 01-09-2011, 05:19 PM   #13
outfit
outfit's Avatar
Oddometer: 661
1981 R100RS
Left side is fine.
Good oil pressure though
outfit is offline   Reply With Quote
Old 01-09-2011, 06:36 PM   #14
Country Doc
Wanderer
Oddometer: 2,758
I haven't had the jugs off, but I've had VW aircooled motors apart a few times using the same sealant, and it's easy to clean up. Brake cleaner and a shop rag.
A damn sight easier than the Permatex grey, which took FOREVER to painstakingly clean away.
The #518 is good stuff. Pricey for a small tube, but seems to work great.
dc
Old 01-09-2011, 07:27 PM   #15
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,578
Thumb
Well, a notch in supershafts knowledge belt...after pulling the cylider, I could feel a slight indentation on the block below and down from the rear o-ring. I wa spanicked for a moment. Weather my sanfu did it or someone previous, it was there.
Took my chances and threw the dice, got a fresh tube of Hylomar and brushed it lightly on both srrfaces and locked it down.
Hapy to say I took the bike out for a shakedown and no, but none, leakages.
Phew! Feel like I dodge a major bullet!
Bike runs great I must say, no smoke, no leaking, no popping or otherwise.
I'm a happy boy!
Times are GMT -7.   It's 04:31 AM.
