12-01-2011, 07:37 PM
#136 |
Oddometer: 36
2008 990
Been running mine for 6 months now with no problems. 40's is the coldest and no issues. Turned over a little slower but still started.
12-02-2011, 02:26 PM
#137 | |
Isn't that dangerous?
Oddometer: 1,222
I don't think I let enough current flow before trying to start it initially. I have to remember to let it sit for a minute before trying to crank it.
EastSideSM: '06 950SM Black, '01 Honda RC51 |
12-02-2011, 05:28 PM
#138 | |
Potius Sero Quam Numquam
Oddometer: 4,398
My usual procedure on these freezing and subfreezing commute days: - 1st starter try, barely spins, like it's almost dead. Turn the key off, wait 30 sec - 2nd starter try, turns over a bit harder, but not enough to start. Key off, let sit another 60 seconds (hard to do, I know) - 3rd starter try, leaps to life! (usually). If not a few more starter trys, with 60 seconds between usually gets it. Trying a bunch of starter cycles in rapid fire won't work. No time to heat up. |
12-12-2011, 07:27 AM
#139 |
Oddometer: 41
Last week I have put my FZ outside to conduct another cold test. Prior test was only for a couple of hours in the freezer and I wanted a real deal. Over night temp got into a single digits. Morning it was only 12. I turned my heated grips on my light does not come on just like yours. While grips were not enough or maybe I did not waited enough only 1-2 min. Bike has started on the 4th try. I know I did not give it enough time to heat it up. For my next test I will plug my heated liner.
WHat was interesting is that I have been checking the voltage as I was going. Evening 13.4 morning before trying 13.3 after first start - 11.8 2nd - 12.4 3th - 12.7 4th - 12.9 and it fired right up Unlike regular AGM batteries, Shorai just gets stronger.
Alex - 06 FZ1 Certifiable MSF Instructor MishaCycles, Inc. OEM parts and accessories MishaCycles on Facebook |
12-12-2011, 07:37 AM
#140 |
Spherical Bastard
Oddometer: 332
First initial failure to start happened a couple days ago (30°F). Attempted to start, engine turned over, failed to light. Let it sit a minute. Started right up. Prior to this, the bike had always started immediately.
Yesterday (upper 20s), after reading the Shorai cold starting notes, I let the bike sit with the high beam light on while I geared up (a couple of minutes), prior to attempting to start. Then I switched the bike off for a minute. Fired right up after that.
Chris |
12-12-2011, 09:23 AM
#141 | |
Oddometer: 1,222
12-12-2011, 11:30 AM
#142 |
High Roller
Oddometer: 5,128
Had a few cold nights in a row (low 30s) strange for SoCal.
Shorai wouldn't turn it over so I pulled the headlight fuse then she fired right up. Hooked it up to a battery tender jr. but thought better of it when I saw red and green flashing lights. Going to read the 1000+ posts on charger compatibility. |
12-12-2011, 09:39 PM
#143 |
el semental negro
Oddometer: 228
Has anyone considered these Shorai's might cut short the life of the starters with such starting and cranking procedures? What about the dry cell batteries in cold weather? I used one in my (now gone) 1100GS, but it was a larger size than whats called for in the KTM. Im ready to replace the OEM battery and dont want to waste money.
12-12-2011, 10:05 PM
#144 |
Agnostic and Orange
Oddometer: 1,230
He is my ktm 450 story. I had to rebuild engine. After reassembly I accidentally connected stator and voltage regulator wrong way, I didn't figure it out until 2 weeks later. Shorai was sitting at this point for 6 weeks, no charging.
I was able to fire up freshly rebuild engine and go ride, restart multiple times over entire weekend. A week later I went for another dirt ride. Bike started in the morning(may be 40F) but wouldn't later in the day. That's when I pullout voltmeter and started troubleshooting. It was only 7.4 volts and no charging with engine running.. At this point I figured out that something wasn't right - and found that I screwed up wiring , corrected it and battery was fully charged after couple of minutes of riding. Holly cow.
2006 KTM 950 ADV 2004 KTM 450EXC Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109 |
12-13-2011, 08:26 AM
#145 | |
Spherical Bastard
Oddometer: 332
Chris |
12-14-2011, 02:26 PM
#146 |
Unwounding
Oddometer: 4,318
I had a smaller case 14a battery in my 950. Seemed Ok when new but it shat itself and they replaced it quickly. That one lasted a day, they are sending me the larger case battery as replacement. My 570 Husaberg has the same 14a smaller case Shorai and in 40f today it couldn't turn the bike fast enough after warming up and started to drop off again. 30 minutes on a charger and it starts but I can't count on a battery charger everytime it gets cold. The bike was ridden the day before for an hour, needed to warm up the batt before it would light but it did start it.
I've been thru turntechs, ballistics and now 3 returns on 4 Shorais and the 4th isn't working great at this point. Great idea, just not up to the reliability of a good quality lead acid by my experience. As I re-read the warnings I also note if you drain it, like by leaving a light on overnight, the battery is done. Going back to the heavy but good Yuasa batteries. I've not had as many battery issues in my lifetime as in the last 18 months trying these new tech doorstops, and they ain't even good doorstops! |
12-15-2011, 06:11 AM
#147 |
AKA; Mongo-E
Oddometer: 1,748
Check this out,
I bought a new Husaberg FE 570 and with no kick starter, I was worried that if my battery died I would be in serious trouble. So, I bought a new Shorai battery and I carry in the Giant Loop Mojavi saddlebags, don't even notice it! Haven't had to break out with it yet, but when it is time, I am covered!!
"If my Technique Improves, so will my riding"! |
12-15-2011, 12:37 PM
#148 |
Oddometer: 41
I am shocked to hear that you went through 3 batteries. It is highly unusual. Out of all that I have sold I think I only saw 4-5 that had to be replaced. And frankly half of them were replaced by Shorai because they figured that bike could use bigger battery even so client only paid for smaller and wanted a smaller at a purchasing time.
As far as they are dead if you drain it I can personally attest to it that it is INCORRECT statement. I have, by accident, drain mine lfx18a1 fully twice. Each time it took only about 45 min on a Shorai charger to bring it back to life and even now after couple of freeze tests it still shows 13.5 after seating in garage and bike hasn't been ridden since early Nov.
12-15-2011, 04:37 PM
#149 |
Bleeds orange
Oddometer: 291
+1 on Shorai replacement. They've been very responsive to my inquiries. Sending me a new battery this month. I believe the current model is receiving an upgrade this month.
KTM 990, 300XC-W, 200XC-W |
12-15-2011, 09:49 PM
#150 | |
Oddometer: 4,398
I replaced the too small, always marginal lead/acid battery in my Aprilia RXV550, which was a tough starter, with the small Shorai, and it started that bike super strong! Was very pleased with it in that application. Just sold the RXV, and having fun with the Berg, and my 990S continues to be my everyday commute workhorse, even in Winter, with the Shorai. |
